hilleyja
WV, USA Status: offline
quote:
ORIGINAL: nemo_uk Hi hilleyja, The nVidia GeForce 7300LE is entry level graphics card (LE stands for light edition) Take a look at this comparison between and the 7300LE and the 9800 pro … http://www.gpureview.com/show_cards.php?card1=388&card2=31 Regards, Tony Thank you, that is the web site I needed access to. Well, it looks like I made the correct decision. This afternoon I ordered a Radeon X800 128 PCI-E card. I really did'nt want to spend a lot of money because Real Flight is the only application I have that needs a high-end video card. For less than $65.00 it looks like I have an even better card than the 9800 Pro is. (This info is for the x800 SE (AGP 8X) -- the card I ordered is an ATI RADEON X800 SE 128MB GDDR3 PCI-EXPRESS; Memory Clock Speed 450 MHz, RAMDAC Clock Speed 425 MHz .) ATi Radeon X800 SE Core Clock: 425 MHz Memory Clock: 400 MHz (800 DDR) Memory Bandwidth: 25.6 GB/sec Shader Operations: 3400 Operations/sec Pixel Fill Rate: 6800 MPixels/sec Texture Fill Rate: 3400 MTexels/sec Vertex Operations: 637.5 MVertices/sec ATi Radeon 9800 Pro 128MB Core Clock: 380 MHz Memory Clock: 340 MHz (680 DDR) Memory Bandwidth: 21.76 GB/sec Shader Operations: 3040 Operations/sec Pixel Fill Rate: 3040 MPixels/sec Texture Fill Rate: 3040 MTexels/sec Vertex Operations: 380 MVertices/sec
< Message edited by hilleyja -- 10/10/2006 9:44:48 PM >
_____________________________
Jim Hilley AMA #671825 RCCA# 758 Twist 150 Brotherhood #14
