RE: Hostetler 33% Decathlon    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Hostetler 33% Decathlon
Page: <<   < prev  158 159 160 [161] 162 163 164 165 166 167   next >   >>
Login
RE: Hostetler 33% Decathlon - 12/14/2012 8:33 PM
tflyrc
Score: 100
Last Login: 5/20/2013
Status: offline
If you go to the Hostettler web site he lists sources for all of these parts, except the canopy. Fibertech N More (The old Stans Fiberglass I believe) was orignally where I purchased my 30% cowl. It fitted well w/ my Hostettler plans (scratch built and several threads in this forum). Could also check Fiberglass Specialties.
Regards, Tom
Hide Signatures
(in reply to martinwpb)
       Post #: 4001
RE: Hostetler 33% Decathlon - 12/14/2012 11:37 PM
Bobt2
Score: 100
Last Login: 5/19/2013
Status: offline
well, you don't need a 111. if you check on you tube, theres a nice flight on one with a zdz 80.
Hide Signatures
(in reply to tflyrc)
       Post #: 4002
RE: Hostetler 33% Decathlon - 12/15/2012 2:32 AM
ludfleet
Score: 100
Last Login: 5/3/2013
Status: offline
The ZDZ 80 has the power of most 100's it should fly it just fine.
Hide Signatures
(in reply to Bobt2)
       Post #: 4003
RE: Hostetler 33% Decathlon - 12/15/2012 12:35 PM
Bobt2
Score: 100
Status: offline
i have a zdz super 80 that i would like to use, but at 9 1/2 " long it would be a pita to make it fit.major firewall mods to start.
Hide Signatures
(in reply to ludfleet)
       Post #: 4004
RE: Hostetler 33% Decathlon - 12/15/2012 7:42 PM
martinwpb
Score: 100
Last Login: 3/14/2013
Status: offline
Hi guys,
Thanks for some feedback. Hostetler says the weight for a 33% is 25-30lbs. If my memory is correct a DLE-55 produces around 30lbs thrust right? So should that not be adequate enough?
Martin
Hide Signatures
(in reply to Bobt2)
       Post #: 4005
RE: Hostetler 33% Decathlon - 12/15/2012 8:27 PM
tflyrc
Score: 100
Status: offline
Martin: The 55 would be OK for the 30% but I agree that it would be pushing it for the 33%. You are not going to have unlimited verticle in either case.
Hide Signatures
       Post #: 4006
RE: Hostetler 33% Decathlon - 12/16/2012 12:36 PM
Bobt2
Score: 100
Status: offline
it,s not the weight only, it's a big airfame with lots of drag.i would think a 55 with a smaller prop would barely get it in the air
Hide Signatures
       Post #: 4007
RE: Hostetler 33% Decathlon - 12/16/2012 1:59 PM
Kellermann
Score: 105
Last Login: 3/1/2013
Status: offline
BobT which one are you building? if the 30%, a 55 would do fine, all my 30% SDs fly well with the 50-55cc.
If it is the 33%, I´d go for a 80 or 100cc. My 35% are a little larger than the WH 33% and were designed for the DLE-111 twin. Ken´s 33% flys with a ZDZ 80
Marcus
_____________________________
A good landing is one you could walk away from. A spectacular landing is when the airplane is reusable...!
Hide Signatures
(in reply to Bobt2)
       Post #: 4008
RE: Hostetler 33% Decathlon - 12/16/2012 3:18 PM
John La Belle
Score: 100
Status: offline
Hi Bobt; I would suggust the DLE111 if you plan to use fabric covering- automobile paint- scale cockpit- scale screw ribstitching- landing lights etc. ( this will make the plane weigh about 37 lbs) the DLE111 will be plenty of power. the plane will not notice the extra weight if you are inclined to build in the extras. The DLE55 should be fine if built lighter but as others have said the best compromise might be the 80 size engines. I like to add scale items and am very happy with the DLE111 and my 37 lb. Decathelon cheers John
Hide Signatures
(in reply to Kellermann)
       Post #: 4009
RE: Hostetler 33% Decathlon - 12/16/2012 3:41 PM
martinwpb
Score: 100
Status: offline
I wish there was a DLE in between the DLE-60 and DLE-111. Like the Zenoah GT-80 but the gt-80 only produces about 5.5hp which is the same as the DLE-55.
How does the DLE-111 fit in the 33% Hostetler?
Martin
Hide Signatures
(in reply to John La Belle)
       Post #: 4010
RE: Hostetler 33% Decathlon - 12/16/2012 4:23 PM
Bobt2
Score: 100
Status: offline
well, i,m lucky in that i fly imac style aircraft. i own several da's and have a 100 that would be perfect. not to be a snob, but no china engine for this old man
Hide Signatures
       Post #: 4011
RE: Hostetler 33% Decathlon - 12/16/2012 5:36 PM
Kellermann
Score: 105
Status: offline
Well, nothing against the DLE engines but if you have a DA-100 that would be the perfect one for your SD. Carefully check if the spark plugs + caps will fit inside the cowl.
Marcus
Hide Signatures
(in reply to Bobt2)
       Post #: 4012
RE: Hostetler 33% Decathlon - 12/16/2012 6:51 PM
Bobt2
Score: 100
Status: offline
probally not, as well as the mufflers hanging out the bottom. or i could add canisters thru the fuse.
Hide Signatures
       Post #: 4013
RE: Hostetler 33% Decathlon - 12/16/2012 6:59 PM
martinwpb
Score: 100
Status: offline
How does the DLE-111 fits in the 33%?
Hide Signatures
(in reply to Bobt2)
       Post #: 4014
RE: Hostetler 33% Decathlon - 12/16/2012 7:39 PM
John La Belle
Score: 100
Status: offline
The DLE 111 fits completly inside the cowl inc. plug wires with plenty room for landing light -batteries and light servo cheers John
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 4015
ludfleet
Score: 100
Status: offline
I have a DLE 100 in mine fits perfect.
Hide Signatures
       Post #: 4016
RE: Hostetler 33% Decathlon - 12/16/2012 7:55 PM
Kellermann
Score: 105
Status: offline
Guess BOBT answered that.
I designed my 35% scale exactly for the specs of the DLE-111. The 2 exhaust stacks length can be trimmed to be flush with the cowl underline, as the exhaust tunnel rear of it is functional, that is, you cannot see the stacks in level (flight) mode however they protrude enough no to mess with the underside of the plane.
Did that with the PItts-Style Muffler on my 30% powered by a Fuji 50, too.
Marcus
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4017
RE: Hostetler 33% Decathlon - 12/16/2012 8:00 PM
martinwpb
Score: 100
Status: offline
Thanks John.. Yours looks real nice! I like to color scheme.
Hi Marcus,
Is your kit comparable to Hostetlers 33% price wise? (national balsa $425,- full kit)
Martin
Hide Signatures
       Post #: 4018
RE: Hostetler 33% Decathlon - 12/16/2012 9:35 PM
martinwpb
Score: 100
Status: offline
John you have some more close up shots from your cockpit? It looks real nice!
Hide Signatures
       Post #: 4019
RE: Hostetler 33% Decathlon - 12/16/2012 11:42 PM
Kellermann
Score: 105
Status: offline
quote:
ORIGINAL: martinwpb
Hi Marcus,
Martin
Martin, mine is more expensive. USD 1250 + 15% S&H. Check my website Details, to see why my SD is different from others... If your browser is Google Chrome, be sure to have your automatic translator turned on.
Cheers Marcus
Hide Signatures
       Post #: 4020
RE: Hostetler 33% Decathlon - 12/16/2012 11:44 PM
ludfleet
Score: 100
Status: offline
Hello Marcus, How did you do the exhaust on the 35% or the DLE111? Do you have any photo's that you would share? Joe
Hide Signatures
       Post #: 4021
RE: Hostetler 33% Decathlon - 12/17/2012 12:10 AM
Kellermann
Score: 105
Status: offline
quote:
ORIGINAL: ludfleet
Joe the same as on the pitts style on the 30%. I didn´t yet build one for me, will have to check one of my customers. Will come back on this tomorrow.
Marcus
Hide Signatures
       Post #: 4022
RE: Hostetler 33% Decathlon - 12/17/2012 12:28 AM
Bobt2
Score: 100
Status: offline
ok, turns out the da 100 is actually smaller. fits in the cowl with a little room to spare, however i,m sure the front of the mufflers will poke out the front bottom.
Hide Signatures
       Post #: 4023
RE: Hostetler 33% Decathlon - 12/17/2012 11:09 AM
Kellermann
Score: 105
Status: offline
quote:
ORIGINAL: Bobt2
Here are flying shots of 2 of my 35%s - the white one is powered by a DA-100 and the pilot installed a 2 : 1 muffler with the stack coming out of the cowl thru the air vent. He did leave it protruding but didnt have to, could have cut if flush with the underside.
The Blue N White has a DLE-111 installed, and the stacks are hidden in the air vent opening like I described before,on my 30%.
NONE of them have the manifolds poking out of the front bottom. Well - I actually designed the plane at 35% instead of 33% to get that extra room on the cylinders. Perhaps the added bonus was the manifolds being hidden as well.
Cheers
Marcus
Click for fullsize
Click for fullsize
< Message edited by Kellermann -- 12/17/2012 12:12 PM >
Hide Signatures
(in reply to Bobt2)
       Post #: 4024
RE: Hostetler 33% Decathlon - 12/18/2012 12:42 AM
martinwpb
Score: 100
Status: offline
Ordered my SD (hostetler) Plans and kit are shipped Building start next week.
Will post pictures.
Martin
Hide Signatures
       Post #: 4025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.064RCU1
