RE: Hostetler 33% Decathlon    Gallery
Logged in as Guest
    Search This Thread
Printable Version
S&W 2-6S LCD Battery Capacity & Checker ***FREE SHIPPING US ONLY*****
Seller:  swgiantscalemodels
Details:   $19.89   |  4/2/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Hostetler 33% Decathlon
Page: <<   < prev  158 159 160 161 162 [163] 164 165 166 167   next >   >>
Login
RE: Hostetler 33% Decathlon - 12/25/2012 9:17 PM
Kellermann
Score: 105
Last Login: 3/1/2013
Status: offline
Great Martin! Keep the pix coming...
Merry Christmas to you too
_____________________________
A good landing is one you could walk away from. A spectacular landing is when the airplane is reusable...!
Hide Signatures
(in reply to martinwpb)
       Post #: 4051
RE: Hostetler 33% Decathlon - 12/26/2012 4:46 PM
martinwpb
Score: 100
Last Login: 3/14/2013
Status: offline
Hi Marcus,
Can you tell me what you used on the plane? Oracover? Also do you know which colors these are?
Thank You the plane is looking outstanding!
Martin
Hide Signatures
(in reply to Kellermann)
       Post #: 4052
RE: Hostetler 33% Decathlon - 12/26/2012 5:02 PM
Kellermann
Score: 105
Status: offline
Thanks Martin! That 35% Decathlon was my new flagship (built and delivered a year ago).
The covering I always use is Oracover.
The colors are Oracover (iron-on)
Standard Colors - 21-010 White and 21-052 Dark Blue
Orastick (self-adhesive)
Standard Color - 25-020 Red for Invasion and fuse stripes.
If you wish, I can send you a pair of scale ACRO stickers (they´re done in 35% but at 33% a little oversized nobody will notice the difference)
Paint on fiberglass parts is automotive enamel, I had the colors matched at a professional paint mixer. Clearcote is also automotive.
Hope to have helped.
Marcus
Hide Signatures
       Post #: 4053
RE: Hostetler 33% Decathlon - 12/26/2012 5:29 PM
martinwpb
Score: 100
Status: offline
Hi Marcus,
Thank you so much. The red at the bottom of the wing is self adhesive aswel? Do you remeber roughly how much you used? Oracover is sold in the USA under the name Ultracote.
Oracover = Ultracote
21-010 = HANU870
21-052 = HANU883
25-020 = ???
Martin
quote:
ORIGINAL: Kellermann
Marcus
Hide Signatures
       Post #: 4054
RE: Hostetler 33% Decathlon - 12/26/2012 5:57 PM
Kellermann
Score: 105
Status: offline
Martin
I assume Hangar 9 took over the Oracover collection and renamed them under own brand. If I was Oracover I would not allow that. After all, the brand is your most important asset, and in their case, stands for quality. Period.
You can use Ferri red instead of the Red I mentioned. It was sticking cote as well. But you can Iron-on the stripes as well. Roughly I use 4-5m of white, 6-8 m of Blue and 1,5-2m of red. Remember, all those pinstripes around the starbursts are also red. And it´s repeated 6 times on the entire plane. That´s why I used sticking folie instead of iron-on.
Hope that helped.
Marcus
Hide Signatures
       Post #: 4055
RE: Hostetler 33% Decathlon - 12/26/2012 6:55 PM
Bobt2
Score: 100
Last Login: 5/19/2013
Status: offline
see, thats what i said too oracover=ultracote here in the us. at least thats what google came up with.
Hide Signatures
       Post #: 4056
RE: Hostetler 33% Decathlon - 12/26/2012 11:24 PM
martinwpb
Score: 100
Status: offline
 What are you guys using for the wing tips? I want a little more scale then on the plans.
Thinking about shaping some urethane foam with the cnc machine then cover it with some glass.
any other ideas?
martin
Hide Signatures
(in reply to Bobt2)
       Post #: 4057
RE: Hostetler 33% Decathlon - 12/26/2012 11:33 PM
Kellermann
Score: 105
Status: offline
Martin, on mine they are FG parts screwed on just like the fullsize. Send me a scaled drawing of the wing profile, and the chord, and I´ll check if my tips would fit...
Marcus
Hide Signatures
       Post #: 4058
RE: Hostetler 33% Decathlon - 12/27/2012 1:02 AM
Bobt2
Score: 100
Status: offline
well, i said i,m not computer savy. i tried to post pics,, but i get file too large errors
Hide Signatures
       Post #: 4059
RE: Hostetler 33% Decathlon - 12/27/2012 1:46 AM
Kellermann
Score: 105
Status: offline
Martin, Ken built his carving and shaping balsa blocks, then hollowing them. Lotsa work but nice end result too.
Hide Signatures
       Post #: 4060
RE: Hostetler 33% Decathlon - 12/27/2012 2:39 AM
martinwpb
Score: 100
Status: offline
Hi Marcus,
See PDF for last rib shape. This drawing includes 1/8inch(3.18mm) sheeting both sides and trail and leading edge balsa. Measurements in drawing are in Millimeters.
Yeah was thinking balsa blocks as well but they are not locally available. Since i have a CNC machine it should not be so hard to make one from Foam.
But lets see if yours fit.
Martin
docs.google.com/open
Hide Signatures
       Post #: 4061
RE: Hostetler 33% Decathlon - 12/27/2012 11:43 AM
Kellermann
Score: 105
Status: offline
Hi Martin
considering my plane is 35% my wingtips would obviously be bigger.
Profilewise they´re more bulged as I use the original NACA 2412 profile, and WH uses a flatter profile.
Chordwise mine are 557mm against yours at 538mm... that gives you some 19mm difference to cut off at the end.
Means my wingtips would fit but not without some reworking on them: I´d suggest splitting them chordwise, trimming off "the excess (some 5mm or roughly 3/16 to 1/4")" and rejoining them to make them a little flatter. Also, before joining them, trimming off some 19mm (roughly some 3/4") on the rear (parallel to the slanted TE). Sand all edges flush and voilá, you got some nice pair of FG tips to screw onto your wings. Less fussing than carving molds and laminating.
Can be yours for USD 80,- a pair, S&H included (remember, I live in Brazil)...). You must have a PayPal account.
Would like to show a picture of my tip, but the server tells me repeatedly they have an internal error.
Marcus
Hide Signatures
       Post #: 4062
RE: Hostetler 33% Decathlon - 12/27/2012 10:00 PM
ludfleet
Score: 100
Last Login: 5/3/2013
Status: offline
Hey Martin, I made my wing tips out of that pink insulating foam(it also comes in blue ) that you get at a lumber yard. I cut the basic shape with the bandsaw, then worked down to the final shape with rasp and coarse sand paper, got them exactly how I wanted them, then glassed them . They came out good. I'll put some pics on sometime but today is not good as we got hammered with snow over night. They are reeasonably light not sure if as light as balsa would have been, but cheaper. Joe
Hide Signatures
       Post #: 4063
RE: Hostetler 33% Decathlon - 12/29/2012 11:56 PM
Bobt2
Score: 100
Status: offline
well only took me a few days to out how to resize photos.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ludfleet)
       Post #: 4064
RE: Hostetler 33% Decathlon - 1/1/2013 2:59 PM
Bobt2
Score: 100
Status: offline
fuse, stab and fin about done. now to start on the wings
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bobt2)
       Post #: 4065
RE: Hostetler 33% Decathlon - 1/1/2013 3:31 PM
ludfleet
Score: 100
Status: offline
Hey Bob, Look-in good. You have a lot more abition than I do. I just can't seem to get my butt in gear. It's all built just have to get servos mounted and push-rods made then get to covering.
Hide Signatures
(in reply to Bobt2)
       Post #: 4066
RE: Hostetler 33% Decathlon - 1/1/2013 9:37 PM
Bobt2
Score: 100
Status: offline
a quick heli flight in the front yard for new years day and back to the wing construction
Click for fullsize
Hide Signatures
       Post #: 4067
RE: Hostetler 33% Decathlon - 1/6/2013 7:59 PM
RickP
Score: 105
Last Login: 5/10/2013
Status: offline
I don't see a sailplane tow hook installed yet, what's going on? ;-)
RickP
Hide Signatures
(in reply to Bobt2)
       Post #: 4068
RE: Hostetler 33% Decathlon - 1/7/2013 12:30 AM
Bobt2
Score: 100
Status: offline
don't worry, it will be there.
Hide Signatures
(in reply to RickP)
       Post #: 4069
RE: Hostetler 33% Decathlon - 1/9/2013 12:55 PM
Bobt2
Score: 100
Status: offline
so, i have a question. it appears to me that the 6-32 inserts in the spars would weaken the load carring abilty by a bunch. no one has had any issues with this?
Hide Signatures
(in reply to Bobt2)
       Post #: 4070
RE: Hostetler 33% Decathlon - 1/9/2013 7:14 PM
ludfleet
Score: 100
Status: offline
Hello Bob, Yes I have been concerned with using those threaded inserts, looked at other options and decided to use them. there is a huge amount of stress at those locations especially where the struts mount. I couldn't find another way without some other problem popping up. If you have any good ideas please let me know. I would change to something else if it looks good in a heart beat. I've never posted a question about these inserts, but have never read where they have failed on the Hostetler design. Maybe the plywood webbing in that area is all it needs. I agree with you, the inserts really weaken the spar.
Hide Signatures
(in reply to Bobt2)
       Post #: 4071
RE: Hostetler 33% Decathlon - 1/9/2013 7:34 PM
RickP
Score: 105
Status: offline
quote:
ORIGINAL: Bobt2
Bob,
This thread is huge and I don't have an image of the area in question. Can you please post a photo of the area, or point me to a PDF of the plans so I can take a look and comment?
Kind regards,
Rick
Hide Signatures
(in reply to Bobt2)
       Post #: 4072
RE: Hostetler 33% Decathlon - 1/10/2013 12:57 AM
Bobt2
Score: 100
Status: offline
rick, you are the engineer. theres a 1/4 x 1/2 basswood spar.they want to drill into the spar in 2 places, 1 close to the root to hold the wing and struts on.well, when you drill 1/4 " hold into a 1/2" wide spar, theres not a lot left for strength.hard to photo the plans, drop by the shop over the weekend.
Hide Signatures
(in reply to RickP)
       Post #: 4073
RE: Hostetler 33% Decathlon - 1/10/2013 10:34 AM
John La Belle
Score: 100
Status: offline
HI Guys; I had the same concern with the screws in the spar so I used a 10/32 blind nut inside the inboard wing ribs and bolts from the inside of the fuselage cabin. it must go thru 2 cabin ribs so I used a piece brass tubing for a guide to line up the bolts with the blind nut in the wing has worked out well maybee an option for you to consider cheers John
Hide Signatures
(in reply to Bobt2)
       Post #: 4074
RE: Hostetler 33% Decathlon - 1/10/2013 12:04 PM
Bobt2
Score: 100
Status: offline
actually, thats the way you mount the wings on the balsa usa super cub. it's a pain to get your hands inside the cabin door with a allen key and than get up to the wing mounts.it works but..........
Hide Signatures
(in reply to John La Belle)
       Post #: 4075
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
