RE: Hostetler 33% Decathlon    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Hostetler 33% Decathlon
Page: <<   < prev  158 159 160 161 162 163 164 [165] 166 167   next >   >>
Login
RE: Hostetler 33% Decathlon - 1/24/2013 5:22 PM
martinwpb
Score: 100
Last Login: 3/14/2013
Status: offline
Hi,
Actually im looking for somebody with a mold for the 33% hostetler canopy.
Dont feel like making one if somebody has one.
Thank
Hide Signatures
(in reply to Bobt2)
       Post #: 4101
RE: Hostetler 33% Decathlon - 1/24/2013 5:53 PM
Kellermann
Score: 105
Last Login: 3/1/2013
Status: offline
Well, I offered to pull off one of my 35% which perhaps would fit on the wider than normal 33%Hostettler design. Height would not be a problem, Just a matter of cutting off the bottm till fit.
Never mind. You´ll probably find someone closer to you anyway.
_____________________________
A good landing is one you could walk away from. A spectacular landing is when the airplane is reusable...!
Hide Signatures
(in reply to martinwpb)
       Post #: 4102
RE: Hostetler 33% Decathlon - 1/24/2013 6:06 PM
Bobt2
Score: 100
Last Login: 6/17/2013
Status: offline
so, does anyone have a clue where my cabin top problem lies?
Hide Signatures
(in reply to Kellermann)
       Post #: 4103
RE: Hostetler 33% Decathlon - 1/24/2013 10:22 PM
tflyrc
Score: 100
Last Login: 6/18/2013
Status: offline
Bob: On my 30% version I saw the same problem you show w/ your W1. Easy fix is to mark w/ pencil where W1 sits now. Then take both F13 and F14 and continue the notch where it now steps up all the way to where it hits F15. This will allow you to slide an attitional W1 flush w/ the fuse. Then you just sheet between both W1s and you are done. I may have some pics of mine way back in this thread, but I'll enclose some here to give you a visual.
Tom
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bobt2)
       Post #: 4104
RE: Hostetler 33% Decathlon - 1/24/2013 11:03 PM
Bobt2
Score: 100
Status: offline
exactally what i was thinking, the lines are already drawn, but i wanted to hear it from someone else before turning the saw on. i also guess that the f13/14 only going 1/2 into the spar box will be fine.
Hide Signatures
(in reply to tflyrc)
       Post #: 4105
RE: Hostetler 33% Decathlon - 1/25/2013 12:33 AM
tflyrc
Score: 100
Status: offline
Guess you have to conclude the wing struts are critial, as are the flying wires on tail.
Hide Signatures
(in reply to Bobt2)
       Post #: 4106
RE: Hostetler 33% Decathlon - 1/25/2013 1:01 AM
Bobt2
Score: 100
Status: offline
boy, i hope soooo! i will be putting it thru it's paces with scale aerobatics.powered by a da100.
Hide Signatures
       Post #: 4107
RE: Hostetler 33% Decathlon - 1/25/2013 3:36 PM
Bobt2
Score: 100
Status: offline
since i,m not going to be a scale purest with this bird, i think the simple way to retain the wings is to make the root ribs ply with eye hooks. that a few #64 rubber bands between them across the cabin roof will work fine to hold them in place.
Hide Signatures
(in reply to Bobt2)
       Post #: 4108
RE: Hostetler 33% Decathlon - 1/25/2013 9:53 PM
ludfleet
Score: 100
Status: offline
Hey Bob, Not sure if I understand what your main concern is with the wing mounting?? Is it the inserts? I haven't heard of a failure with this design. If you go back in the posts a ways you'll find "big bird" Ken Spears, he has built this plane to the plans and put it through it's paces with no problem. Maybe you ought to contact him with your concerns. He is an excellent builder and probaby would give you some guidance. Joe
Hide Signatures
(in reply to Bobt2)
       Post #: 4109
RE: Hostetler 33% Decathlon - 1/26/2013 1:08 AM
Bobt2
Score: 100
Status: offline
yea, those inserts in the root take up 1/2 the spar width. it has got to weaken it.out at the strut end you can at least put doublers inside the spar.
Hide Signatures
(in reply to ludfleet)
       Post #: 4110
RE: Hostetler 33% Decathlon - 1/26/2013 2:02 PM
Bobt2
Score: 100
Status: offline
ok, i went back and looked at the plan again.the inserts are in f13/14. not the spar,so the hole will be a lot smaller in the spar. still........
Hide Signatures
(in reply to Bobt2)
       Post #: 4111
RE: Hostetler 33% Decathlon - 1/26/2013 7:21 PM
Bobt2
Score: 100
Status: offline
all major building is now done. wings have been trial fitted to the fuse.wings need cap stripping and the struts fitted.
Click for fullsize
Hide Signatures
(in reply to Bobt2)
       Post #: 4112
RE: Hostetler 33% Decathlon - 1/26/2013 8:11 PM
Kellermann
Score: 105
Status: offline
Nice Job, Bobt2!
Marcus
Hide Signatures
(in reply to Bobt2)
       Post #: 4113
RE: Hostetler 33% Decathlon - 1/27/2013 6:42 PM
Bobt2
Score: 100
Status: offline
i,m also building a 1/3 balsa usa super cub. i have a spare set of those struts that are pre shaped bass. they are the exact same size as the decathlon. will save me hours of shapeing!
Hide Signatures
       Post #: 4114
RE: Hostetler 33% Decathlon - 1/27/2013 9:37 PM
ludfleet
Score: 100
Status: offline
Hey Bob2, I finished my wings so long ago that couldn't remember much about them. But I was out in the shop today, got looking at my wings and the plans. On yours, did you fill between the spars with bass wood at the strut mounting bay? that would greatly strengthen that area. I almost missed that when building mine, there is a note on the drawing to that effect. Yours is looking good you've made fantastic progress considering your set back. You'll probably finish before me. Joe
Hide Signatures
(in reply to Bobt2)
       Post #: 4115
RE: Hostetler 33% Decathlon - 1/27/2013 11:19 PM
Bobt2
Score: 100
Status: offline
yea, i filled in with 3 layers of scrap bass spar material front and rear
Hide Signatures
       Post #: 4116
RE: Hostetler 33% Decathlon - 1/28/2013 5:11 PM
Bobt2
Score: 100
Status: offline
buy the way, the room where the plane is had 4 1/2 ft of saltwater during sandy!
Hide Signatures
(in reply to Bobt2)
       Post #: 4117
RE: Hostetler 33% Decathlon - 1/30/2013 1:41 AM
Bobt2
Score: 100
Status: offline
whats slowing me up now it the tail blocks. theres enough blocks in the kit to build a boat, but what goes where is the puzzle.
Hide Signatures
(in reply to Bobt2)
       Post #: 4118
RE: Hostetler 33% Decathlon - 2/3/2013 3:08 PM
Bobt2
Score: 100
Status: offline
does anyone have any good tail shots, either full size or the model.i,m not happy with the way mine is coming out. and the plans show blocks above the stab onto the fin. but the fullsize pics don't show that.
Hide Signatures
(in reply to Bobt2)
       Post #: 4119
RE: Hostetler 33% Decathlon - 2/3/2013 5:29 PM
tflyrc
Score: 100
Status: offline
Bob: If the 33% drawings are like the 30%, the F-9 section view was incorrect on the drawing. There are no blocks on the 30%. The flying wires essentially hold the stab in place. As I had said earlier...they are functional flying wires. Enclosed is photo of the 30%. You can see that the stab is essentially free standing. You drap the fabic or other covering. The only blocks that I believe (remembering here) were shown were for cosmetics w/ helping to drap the covering. There may be some pics of Kens plan in the bones that show this same set up on the 30% early in the thread when he was just beginning to cover his plane.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bobt2)
       Post #: 4120
RE: Hostetler 33% Decathlon - 2/3/2013 5:37 PM
tflyrc
Score: 100
Status: offline
Bob: Check out the threads on Page 14. This shows Kens' 33% tail section. Hope this helps.
Tom
Hide Signatures
(in reply to Bobt2)
       Post #: 4121
RE: Hostetler 33% Decathlon - 2/3/2013 9:46 PM
Bobt2
Score: 100
Status: offline
yes, i saw the pictures. but with the covering on, it wasn't clear what was under it. thanks all
Hide Signatures
       Post #: 4122
RE: Hostetler 33% Decathlon - 2/4/2013 1:32 AM
ludfleet
Score: 100
Status: offline
Hello Bob2 and tflyrc, if the 33 and 30 drawings are different in that area where does the 30% get it's strength? the flying wires are not enough unless Hostetler has done something drastically different on that version. The flying wire would not do the trick on the 33%. the elevator rudder section seems pretty weak until you add the filler blocks. I scratch built mine so I just filled those areas in with scrap balsa and shaped it. I would guess that blocks from kit cutter that are not marked, would be a challenge to figure out. Be sure you put the blocks in they are needed. If you feel unsure call Wendell he's happy to help. Joe
Hide Signatures
(in reply to Bobt2)
       Post #: 4123
RE: Hostetler 33% Decathlon - 2/4/2013 11:51 AM
Kellermann
Score: 105
Status: offline
Fellows
let me throw in my .02c
If the wires do it on the original, why wouldn´t they on the model? The secret is on the lower wires: they anchor firmly on a fuselage tab on each side - I make it from one single piece of aluminum that crosses the fuse. The upper wires transfer the rigidity of the assembly to the rudder post. That makes for a rock solid assembly, provided there are no floppy joints.
I place a pair of hardwood cross beams diagonally midship - no one can twist my fuselage except something breaks. And that rigidity is transfered to the tail asembly throught the flying wires.
In my models there is no balsa block anywhere on the tail assembly. If there was, only for drapping the fabric covering. Nevertheless, if you do it right, even without any balsa block, the covering will take the correct shape when tautening.
I am enclosing a couple of pics - again, this is my design, WH´s ist probably different but the physics should be the same.
Cheers
Marcus
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4124
RE: Hostetler 33% Decathlon - 2/4/2013 12:04 PM
Kellermann
Score: 105
Status: offline
Here a couple of better photos of the fin/fuselage transition on some of my models - all done without a balsa block underneath.
Cheers
Marcus
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
