RE: Hostetler 33% Decathlon    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Hostetler 33% Decathlon
Page: <<   < prev  158 159 160 161 162 163 164 165 [166] 167   next >   >>
Login
RE: Hostetler 33% Decathlon - 2/4/2013 1:04 PM
Bobt2
Score: 100
Last Login: 5/25/2013
Status: offline
looks to me like a lot of ply/lite ply on yours. plus your stab appears lower than the wh. his stab is higher and unsupported and just pushed thru a 1/2 " thick, built up balsa fin. it appears very weak and i think the blocks are manditory.
Hide Signatures
(in reply to Kellermann)
       Post #: 4126
RE: Hostetler 33% Decathlon - 2/4/2013 1:48 PM
Kellermann
Score: 105
Last Login: 3/1/2013
Status: offline
You´re right, my design uses balsa ony to make the sandwich on the plycores and to sheet the wing. All else is 5/32 ply. Nevertheless, the stab rods go thru 1/2" like yours, except it´s ply. However, the rigidity comes from the wires and not from the base of the stab.
Guess the WH will need the balsa blocks, as you say.
_____________________________
A good landing is one you could walk away from. A spectacular landing is when the airplane is reusable...!
Hide Signatures
(in reply to Bobt2)
       Post #: 4127
RE: Hostetler 33% Decathlon - 2/4/2013 9:12 PM
ludfleet
Score: 100
Last Login: 5/23/2013
Status: offline
Hey guys, All I'm saying is that the fuse is not really rigid at least on mine and all the flying wires in the world will not solve the problem. I also sure the that on the real one the fuse is very rigid before flying wire were added. I've been looking to do something to stiffen the fuse. any ideas I'll be happy to take. Joe
Hide Signatures
       Post #: 4128
RE: Hostetler 33% Decathlon - 2/4/2013 9:22 PM
Kellermann
Score: 105
Status: offline
Joe I gave you already the hint: a couple of hardwood 1/4" sq. cross braces as on my pics, firmly epoxied in place, stiffen up the fuse - because of physics, there is no way to twist it unless something breaks.
Marcus
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ludfleet)
       Post #: 4129
RE: Hostetler 33% Decathlon - 2/4/2013 11:42 PM
John La Belle
Score: 100
Status: offline
Hi Guys I agree with Kellermans post on 2/4/13 that the tail wires take almost the full load. My 33% Decathlon was made using seperate stab halves with only 1/4 short alum. connector rods at fuselage and therefore the tail wires take all the stress as on the full size plane The attached picture shows that the only real strength can be the tail wires. I have really thrown this plane arround with its DLE110 and have full confidence in the tail assembly. I feel the weakest item on the Decathlon are the wing struts with their seperate ends for attaching. That is why I used soild 1/8x1.0" aluminum strips full length and built up on all 4 sides with pine for airfoil shapping cheers John
Hide Signatures
       Post #: 4130
RE: Hostetler 33% Decathlon - 2/4/2013 11:45 PM
John La Belle
Score: 100
Status: offline
Don't know where the picture went John
Hide Signatures
(in reply to John La Belle)
       Post #: 4131
RE: Hostetler 33% Decathlon - 2/5/2013 1:20 AM
Bobt2
Score: 100
Status: offline
john, i sure would like to see a picture of your removable tail. heres a pic of the 33% tail. the fin is now glued. but everything else is on hold while i look at all options
Click for fullsize
Hide Signatures
       Post #: 4132
RE: Hostetler 33% Decathlon - 2/5/2013 10:29 AM
John La Belle
Score: 100
Status: offline
Hi ; will try to attach a picture again, don't know why hasn't worked last couple times , the box actually said successful upload cheers john
Click for fullsize
Hide Signatures
(in reply to Bobt2)
       Post #: 4133
RE: Hostetler 33% Decathlon - 2/5/2013 6:47 PM
Bobt2
Score: 100
Status: offline
pretty! and that stabs removable?
Hide Signatures
       Post #: 4134
RE: Hostetler 33% Decathlon - 2/8/2013 1:20 AM
Bobt2
Score: 100
Status: offline
where can i find the acetate sheets. i need 12x24 sheets.x.030?
Hide Signatures
(in reply to Bobt2)
       Post #: 4135
RE: Hostetler 33% Decathlon - 2/8/2013 10:00 PM
tflyrc
Score: 100
Last Login: 5/20/2013
Status: offline
Check Balsa USA. Not sure but Lone Star Balsa may have some now as well.
Hide Signatures
(in reply to Bobt2)
       Post #: 4136
RE: Hostetler 33% Decathlon - 2/9/2013 12:30 AM
Bobt2
Score: 100
Status: offline
balsa usa = too small to cut the windshield
Hide Signatures
(in reply to tflyrc)
       Post #: 4137
RE: Hostetler 33% Decathlon - 2/9/2013 12:37 AM
Bobt2
Score: 100
Status: offline
actually balsa usa has some, but .020 instead of .030
Hide Signatures
(in reply to Bobt2)
       Post #: 4138
RE: Hostetler 33% Decathlon - 2/11/2013 8:58 AM
grover1
Score: 100
Last Login: 4/22/2013
Status: offline
Marcus .
Are you going to do a build log on your Pilot 1/4 scale Decathlon ?
In a new thread .I would love to see it built .
Greg
Hide Signatures
(in reply to Bobt2)
       Post #: 4139
RE: Hostetler 33% Decathlon - 2/11/2013 4:19 PM
Kellermann
Score: 105
Status: offline
yes i will but on another fórum - will start soon on flyiing giantts (wrong spelling on purpose)... look for it there.
actually it is exactly the same as my 30% but in reduced measurements.
Hide Signatures
(in reply to grover1)
       Post #: 4140
RE: Hostetler 33% Decathlon - 2/11/2013 10:18 PM
grover1
Score: 100
Status: offline
Marcus
I just looked at your Decathlon on Giants it looks good but .
On you sit you say
quote:
For those looking for the original PILOT kit, and for those who prefer a slightly smaller version, here's the alternative: Super Decathlon 1/4 scale for 20-30cc
That is misleading it is not a copy of the original PILOT kit .
It is just a copy of your 30% kit
$999.00 US +15% Shipping & Handling for a 25% Scale with no
quote:
WHEELS, TAILWHEEL, LINKAGE HARDWARE, RADIATOR, LANDING LIGHT, DORSAL ANTENNA
There are no written instructions
that is a high price for a 25% Scale kit
You can get a RADIOWAVE 26% PITTS 12 SHORT KIT for $599.99 and it has 2 wings
< Message edited by grover1 -- 2/11/2013 10:40 PM >
Hide Signatures
       Post #: 4141
RE: Hostetler 33% Decathlon - 2/11/2013 11:37 PM
Kellermann
Score: 105
Status: offline
Well I was just going to clarify that point. It is NOT the Pilot Decathlon, it´s a reduced MMF Decathlon with Fibreglass parts laminated from molds taken from Pilot Kit parts, as well as the overall dimensions were adjusted having the Pilot plan at hand.
So it will be a Hybrid, yet an alternative for those who wanted to get the Pilot kit which are no longer available. After covering no one will tell the difference.
I will correct the info on the site. As well as some of the prices, although my kit IS more expensive than others. No way to compare with asian-origin kits. This is not your run-off-the-mill kit.
All my kits are done one-by-one, they´re laser cut, the parts are laminated by a pro and all the hardware I DO BY MYSELF. And this hardware included even pre-built scale door hinges and pre-drilled, ready-to-assemble Wing Struts. Both items are a pain in the neck to get done for most modelers. And I want that to be done right, so I do it, and guarantee the overall quality of the kit.
Just ask all the guys who purchased my kit and built them. They are all happy and get their value for money.
Last but not least, they´re exactly the same amount of work as a 30% or 35% kit, so the lower price is merely perceptional.
Have a nice week ya all.
Marcus
< Message edited by Kellermann -- 2/12/2013 12:15 AM >
Hide Signatures
       Post #: 4142
RE: Hostetler 33% Decathlon - 2/11/2013 11:50 PM
grover1
Score: 100
Status: offline
Thank you for the info on your kits .
Sorry
I didn't know it comes with hardware included even pre-built scale door hinges and pre-drilled, ready-to-assemble Wing Struts .
Hide Signatures
       Post #: 4143
RE: Hostetler 33% Decathlon - 2/12/2013 12:17 AM
Kellermann
Score: 105
Status: offline
Meanwhile, I checked the webpage. It seems that Google translator played some tricks on translation, which caused the mislead.
In the original portuguese phrases it was more evident. I tried to change the phrase anyway to avoid further confusion.
Still working on the prices.
Rgds
Marcus
< Message edited by Kellermann -- 2/12/2013 1:41 PM >
Hide Signatures
       Post #: 4144
RE: Hostetler 33% Decathlon - 2/14/2013 1:16 AM
Bobt2
Score: 100
Status: offline
i,ve been working on the struts the last few days. the balsa usa pre shaped bass struts worked perfect. i tried the jury struts using the brass bands and didn't like them, so i copied big bird, except i used 4-40 bolts to keep the hole in the sturt as small as possible. when done i will add a locknut and cut the screw to proper lenght.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4145
RE: Hostetler 33% Decathlon - 2/14/2013 10:50 AM
Kellermann
Score: 105
Status: offline
There is only one way to do things right: doing things right! Whenever size of material allows to copy the real thing, there is no way to do it better!
Well done!
Hide Signatures
(in reply to Bobt2)
       Post #: 4146
RE: Hostetler 33% Decathlon - 2/20/2013 5:29 PM
ludfleet
Score: 100
Status: offline
Hey Bob2, I made the straps as per plan and after aseeing yours I'm changing. However, I found these thumb screws that I am going to use. You can get them in 6x32 8x32 sizes. These eliminate the silver soldered joint. Besides, they look pretty good to. See attached photo I found that the straps squash the strut some when tigthened and make a mess of your paint job putting them back on, so I'm all for eliminating them. Joe
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4147
RE: Hostetler 33% Decathlon - 2/24/2013 6:06 PM
Bobt2
Score: 100
Status: offline
so, how many of us admit to screw-ups? must have been 1 to many late nites or too much coffee. looking over everything before final sanding of the wings.....i put the aileron servos in different bays in each panel. no one will ever know when it's covered and assembled, but i will................ thats a 1st for me....... i guess now that i passed 65 it will happen more often????????????
Hide Signatures
       Post #: 4148
RE: Hostetler 33% Decathlon - 2/25/2013 10:53 AM
ludfleet
Score: 100
Status: offline
Hey Bob, I will admit , I made the same mistake. I put the servo mount one bay off on my second wing. I did fix my screw-up, don't know what I was thinking. It get's worse when your 75. Joe
Hide Signatures
(in reply to Bobt2)
       Post #: 4149
RE: Hostetler 33% Decathlon - 2/25/2013 12:55 PM
Bobt2
Score: 100
Status: offline
the wing mount would be easy to fix, but ripping the aileron open to get to the horn mount would be a royal pain.it will stay as is.
Hide Signatures
       Post #: 4150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
