RE: Hostetler 33% Decathlon
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
33R0Super Decathlon
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Hostetler 33% Decathlon
    Page: <<   < prev  124 125 126 127 [128] 129 130 131 132 133   next >   >>
    Login
    RE: Hostetler 33% Decathlon - 10/15/2007 12:01:37 AM
    michou41a
    Status: offline
    oups here my 42% Cub J3, sorry, now my 42% Decatlon wing
    Click to see fullsize image.
    Click for fullsize
    _____________________________
    Aircraft Modelers Research
    (in reply to michou41a)
           Post #: 3176
    RE: Hostetler 33% Decathlon - 10/15/2007 2:19:58 AM
    Kellermann
    Status: offline
    Hey Michel,
    that's not fair, while we mortals build half of a stab you build a whole bunch of 42% scale models!!!
    You make whatever we dream of building being dwarfed by those planes...
    Hey, just kidding, congrats on those projects. I envy you, in the good sense.
    Marcus
    P.S. took the Electric Mutley to fly but in windy conditions it's scary, and I don't like to fly fullpower all the time, could damage the motor.
    So I decided to put a gasser back into it, traded in a 3W24 that's just right for the plane. Will build a lighter plane for the E-Motor.
    < Message edited by Kellermann -- 10/15/2007 2:21:17 AM >
    Take-off is optional, landing is mandatory
    http://cuttingedge.org/salvation.html - your life will never be the same...
           Post #: 3177
    RE: Hostetler 33% Decathlon - 10/15/2007 2:33:15 AM
    michou41a
    Status: offline
    Hello Marcus ;-) we have fun on those big one.....15 feet wingspan
    Click for fullsize
    (in reply to Kellermann)
           Post #: 3178
    RE: Hostetler 33% Decathlon - 11/4/2007 12:53:30 PM
    michou41a
    Status: offline
    here my 42% Decathlon
    Click for fullsize
           Post #: 3179
    RE: Hostetler 33% Decathlon - 11/4/2007 3:05:29 PM
    Big_Bird
    Status: offline
    Michael, that is an interesting drawing. It almost looks like the wing is under cambered and the vertical tail is exaggerated.
    Ken
    WACO Brotherhood #70
           Post #: 3180
    RE: Hostetler 33% Decathlon - 11/5/2007 12:38:59 PM
    Kellermann
    Status: offline
    Ken,
    that's an optical illusion. The wing profile is semi-symmetrical, however, since the fuselage sides incorporate both the wing root and both front and rear window frames, when you don't draw the profile on that part, it looks like it goes all the way to where the window frame ends, and because of that shape it looks like undercambered, specially when looked from that angle. That illusion is enhanced by the small cutouts for the former aligning tabs, which look as if they were spar cutouts.
    In fact, the wing profile ends at approx. half of the rear window, exactly at the point where the upper line has a small bend to form the slight bow of the rear deck...
    Although Michel's drawing is based on the EMHW Design, if you look at my design you'll see the same illusion, possibly even at WH's - provided the profile isn't drawn yet on the window frame.
    Just look at the picture below...take a special look at the second fuse, standing in the rear - there you see only the window frame almost identical to Michel's drawing...on the second picture the profile is drawn, and the illusion disappears.
    As for the rudder, although it looks oversided, it's possible also an illusion due to the isometric perspective.
    Marcus
    Click for fullsize
    Click for fullsize
    (in reply to Big_Bird)
           Post #: 3181
    RE: Hostetler 33% Decathlon - 11/5/2007 12:43:18 PM
    Kellermann
    Status: offline
    I just took Michel's drawing and drew the profile on it, the illusion is gone!
    Click for fullsize
           Post #: 3182
    RE: Hostetler 33% Decathlon - 11/5/2007 12:52:41 PM
    Kellermann
    Status: offline
    Michel, since you're investing so much time and effort into this design, may I make a small suggestion: please correct the instrument dashboard outline, it's not bowed like the EMHW design, but almost rectangular with rounded corners, as per the pic below...otherwise it's a beautiful design, and I look forward to see it in real...
    sorry I'm being the scale cop again, but that's immediately eyecatching...the first pic is of my Bellanca style model (as is the 3rd. pic, of the fullsize PP-ZPA I modeled), the others of fullsize ACA models.
    Marcus
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by Kellermann -- 11/5/2007 12:55:08 PM >
           Post #: 3183
    RE: Hostetler 33% Decathlon - 11/6/2007 1:06:58 AM
    Big_Bird
    Status: offline
    Thanks, I understand now.
    Ken
           Post #: 3184
    RE: Hostetler 33% Decathlon - 11/6/2007 1:15:36 PM
    Kellermann
    Status: offline
    Ken, I was sure you had understood it already, I just wanted to make sure others who read this understand the issue as well...
    how's the Waco doing?
           Post #: 3185
    RE: Hostetler 33% Decathlon - 11/6/2007 2:25:57 PM
    michou41a
    Status: offline
    Marcus, i bought the company who design and produce 33 and 40% Wacos kits, everything is in place to the next 10 run of 33% kits.
           Post #: 3186
    RE: Hostetler 33% Decathlon - 11/6/2007 3:00:26 PM
    Big_Bird
    Status: offline
    Marcus, on the Waco, the fuselage, both wing center sections and one wing panel are complete. Just finished another 3D electric EPP foamie.
    Michael, what's the name of the company?
    Click for fullsize
    Ken
           Post #: 3187
    RE: Hostetler 33% Decathlon - 11/7/2007 8:00:30 PM
    4unlimited
    Status: offline
    Hai all,
    Long time no speak !
    My garage aka hangar still is not finished yet . . . .. so the Decathlon project had to be postponed.
    But in the meanwhile I fly some "from-a-distance- look-a-like", a modified Rascal 110 with RotoMotor 35ccm engine and in-fuselage expansion-pipe.
    Some pictures (starting at the top of following page-link):
    http://www.rcgroups.com/forums/showthread.php?t=152028&page=6#post8357035
    Best regards from the Netherlands,
    Rick
    < Message edited by 4unlimited -- 11/7/2007 8:01:36 PM >
