Kellermann
Joined: 5/4/2003 From: Blumenau - SCSanta Catarina, BRAZIL Status: offline
Well, Ken, that's a question I can't answer - the only thing I know is that the difference is as commonly as described, although I tend to believe that both can be considered engines or motors, since both of them turn one form of energy into another... I just used the terms as commonly referred to... As for the AXI, I checked their HomePage and this motor is said to replace any 60-80cc Gas Engine. It's said to put out 3KW on 10Lipos. I sent an email to them describing my Decathlon, specs, weight, etc, and they confirmed that one is THE motor for this purpose. They have several categories described there, with specific weights + motor/batt/prop combos, ranging from 15lbs 3D Aerobatic clones to 33lbs trainer/tow planes - guess the SD rather fits this category. I don't now yet the specific weights, but my experience with the Mutley conversion is that even with a chunky 6s2p Lipo it's some 900 grams (some 32 oz) lighter that with the 3W24 along with choke and gas servos + linkages, tank and fuel lines, all of them removed for the electric version. It's known that the G-62 is a heavy(ier) engine (than others, like a ZDZ 60, for example). Therefore, taking it out as well as tank+fuel lines including the fuel filler, linkages and choke+gas servos, I estimate a difference of same proportion. I have yet to check the weight of the AXI Outrunner. I will document all these items on a spreadsheet and let you guys know. Meanwhile, MERRY X-MAS to you all!!
_____________________________
Take-off is optional, landing is mandatory http://cuttingedge.org/salvation.html - your life will never be the same...
