Kellermann
Joined: 5/4/2003 From: Blumenau - SCSanta Catarina, BRAZIL Status: offline
Don, IMHO if you are not going to use ultra precise digital servos, you may consider just wiring the wing servos servos in parallel or use a Y-harness. As said, I used 2 JR 537 coupled mechanically without any form of matching, I just used 2 brandnew servos and of course, tested the whole assemply before installing it. There was no differential that would force one servo and drain the battery. BTW, the plane looks good! Marcus
< Message edited by Kellermann -- 10/9/2008 1:50:05 PM >
_____________________________
Take-off is optional, landing is mandatory http://cuttingedge.org/salvation.html - your life will never be the same...
