RE: CMP Hellcat
Tower Hobbies
Logged in as Guest
Users viewing this topic: guj487e
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP Hellcat
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: CMP Hellcat - 6/22/2005 3:10:54 AM
Richard L.
Status: offline
Hi Fred, did you check Tower? You might be stuck with an MA 14x7 3-blade.
_____________________________
http://www.WarbirdObsession.com/
Tamiya Panther, Tamiya King Tiger(3), Tamiya Tiger I, HL Tiger(3), HL Panzer III(2), HL Panther, HL Pershing, HL Bulldog, WSN T-34/85, HE Leopard 2A5
(in reply to ffdq)
       Post #: 226
RE: CMP Hellcat - 6/22/2005 3:14:42 AM
Richard L.
Status: offline
cjordan, I slightly curve the wire out, just enough for the pliers to grip onto. Then turn the tail wheel to 90 degree and bend the wire perpendicular to the fuselage. Another word, don't bend the wire straight back because there is no room between the wire and the vertical fin for the pliers.
(in reply to Aero D)
       Post #: 227
RE: CMP Hellcat - 6/22/2005 3:51:42 AM
Aero D
Status: offline
Ah, that makes sense, I'll give it a try. Thanks again for your help.
Give me a transmitter, or give me death!
(in reply to Richard L.)
       Post #: 228
RE: CMP Hellcat - 6/22/2005 2:25:59 PM
ffdq
Status: offline
Richard,you may be right about the 14/7 hope it works ok
thanks Fred
       Post #: 229
RE: CMP Hellcat - 6/22/2005 5:06:48 PM
hookemut
Status: offline
Hi,
Just a fellow F-6er. Like you, I could NOT figure out how to properly (or even improperly!) make that @#$%^ 90 deg bend! So I sweet talked a buddy into milling me a little aluminum tail wheel fork assembly which then has set screws into the wire running down from the rudder. That way, the 90deg bend was done in a vice!
       Post #: 230
RE: CMP Hellcat - 6/22/2005 5:24:22 PM
hookemut
Status: offline
Hi ffdg,
I am also flying this Hellcat. I am using an OS 1.08 two-stroker turning a Graupner 14X7 three-blade prop. The Graupner page at Hobby Lobby shows the 14X7 for the OS FS 120 as well-
http://www.hobby-lobby.com/grprop.htm#3%20Blade
The Graupner props are really hi quality, and take black paint nicely.
Good Luck,
Jim
(in reply to ffdq)
       Post #: 231
RE: CMP Hellcat - 6/22/2005 10:00:31 PM
zxj14
Status: offline
Hi can any one pkease tell me what retracs to use on this hellcat please help send reply to gospeedracer40@hotmail.com thank you Joe
(in reply to PeteJoMan)
       Post #: 232
RE: CMP Hellcat - 6/22/2005 10:02:31 PM
zxj14
Status: offline
And how to find CMP on the internet thank you all again for your help in this matter. joe
(in reply to zxj14)
       Post #: 233
RE: CMP Hellcat - 6/22/2005 10:47:11 PM
ffdq
Status: offline
thanks looks like they have them .
thanks Fred
(in reply to hookemut)
       Post #: 234
RE: CMP Hellcat - 6/22/2005 11:18:37 PM
zxj14
Status: offline
Hi could you tell me what retracs you used on you hellcat. Joe at gospeedracer40@hotmail.com
(in reply to ZapRC)
       Post #: 235
RE: CMP Hellcat - 6/22/2005 11:44:39 PM
Richard L.
Status: offline
Hi, both Century Jet and Sierra Precision make rotating retracts for this plane.
(in reply to zxj14)
       Post #: 236
RE: CMP Hellcat - 6/22/2005 11:45:03 PM
ffdq
Status: offline
take a look at sirra,s,they cost more but they have a set just for them,and work great
Fred
(in reply to ffdq)
       Post #: 237
RE: CMP Hellcat - 6/23/2005 3:29:06 AM
LynnR
Status: offline
When cutting the channel out of the spar for the air cylinder on the CJ's is anybody going back and re-inforcing? Elaborate please. LynnR
(in reply to ffdq)
       Post #: 238
RE: CMP Hellcat - 6/25/2005 3:52:42 AM
Aero D
Status: offline
Hey RAM-3500,
Did you use the stock wheels that came with the plane?
(in reply to ram3500-RCU)
       Post #: 239
