RE: CMP Hellcat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP Hellcat
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: CMP Hellcat - 2/16/2005 11:28:50 PM
ffdq
Status: offline
RICHARD,I HAVE A SET OF DARRELS NEW RETRACTS FOR THE CMP F6F.THEY HAVE NO TOE IN ADJUSTMENT EITHER SO DOES THIS MEAN THEY WILL CAUSE THE PLANE TO NOSE OVER ALL THE TIME OR WHAT WILL CAUSE THIS HAPPEN.I THOUGH THESE WERE THE BEST ON THE MARKET.
THANKS
(in reply to Richard L.)
       Post #: 51
RE: CMP Hellcat - 2/17/2005 12:34:47 AM
Baldeagle
Status: offline
Does your retracts have a forward rake when installed? Instead of 90 deg angle maybe 100 or so. Thanks Rich
_____________________________
Rich
(in reply to ffdq)
       Post #: 52
RE: CMP Hellcat - 2/17/2005 12:35:05 AM
Richard L.
Status: offline
No, toe-in doesn't necessarily cause the plane to nose over on landing. If you are using cheap wheels that have play in them, then the front of the wheels will angle out on landing, creating a slight toe out. Slight toe out will increase the chance of nosing over, that's all.
< Message edited by Richard L. -- 2/17/2005 12:36:33 AM >
http://www.WarbirdObsession.com/
Tamiya Panther, Tamiya King Tiger(3), Tamiya Tiger I, HL Tiger(3), HL Panzer III(2), HL Panther, HL Pershing, HL Bulldog, WSN T-34/85, HE Leopard 2A5
(in reply to ffdq)
       Post #: 53
RE: CMP Hellcat - 2/17/2005 12:36:18 AM
Richard L.
Status: offline
These retracts have more than enough forward rake when installed. They are 100° retracts.
(in reply to Baldeagle)
       Post #: 54
RE: CMP Hellcat - 2/17/2005 12:59:21 AM
Richard L.
Status: offline
Below are three top views showing three different toe-in angles. I don't think 1 degree will be enough. Either 1.5 or 2 degrees would work.
Edit: added arrow to each picture
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Richard L. -- 2/18/2005 5:09:55 AM >
       Post #: 55
RE: CMP Hellcat - 2/18/2005 4:40:01 AM
HotelSierra
Status: offline
Richard, I'm not sure if it's the illusion of the photo examples, but isn't toe-in or toe-out from front to back of the wheel. From the look of your pictures, it looks like you're illustrating toe-in as an angle from top-to-bottom of the wheel?
       Post #: 56
RE: CMP Hellcat - 2/18/2005 5:02:59 AM
Richard L.
Status: offline
Sorry, those are top views. You are looking straight down at the wheels from above. The front of the plane is at the top of each picture. I will draw in arrows.
(in reply to HotelSierra)
       Post #: 57
RE: CMP Hellcat - 2/18/2005 5:28:05 AM
Richard L.
Status: offline
       Post #: 58
RE: CMP Hellcat - 2/18/2005 5:31:26 AM
SunShyne
Status: offline
quote:
ORIGINAL: Richard L.
she is a beut Richard!
www.TheBossIsAway.com
Revver Bro #86
       Post #: 59
RE: CMP Hellcat - 2/19/2005 4:07:40 AM
Baldeagle
Status: offline
Has anyone found a paint that will match the blue and the gray?. Thanks Rich
Rich
(in reply to SunShyne)
       Post #: 60
RE: CMP Hellcat - 2/21/2005 1:25:56 AM
Baldeagle
Status: offline
Richard How do you think the cat would fly with a Magnum 91 FS.? I know I will have to add nose weight. Thanks Rich
Rich
(in reply to Phantom pty)
       Post #: 61
RE: CMP Hellcat - 2/21/2005 1:49:56 AM
Richard L.
Status: offline
It will fly scale with a Magnum 91FS with no power in reserve. You won't be able to do a big loop with it. Keep in mind that the Hellcat is king in the Pacific.
       Post #: 62
RE: CMP Hellcat - 2/21/2005 1:56:33 AM
Richard L.
Status: offline
< Message edited by Richard L. -- 2/24/2005 3:38:18 PM >
       Post #: 63
RE: CMP Hellcat - 2/21/2005 3:04:42 AM
tailskid
Status: offline
Rich, what happened?
Jerry
# 93 in Club Saito
