RE: what engine for xxx-nt
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: what engine for xxx-nt
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: what engine for xxx-nt - 1/15/2005 1:02:49 AM
Jammin_Lee
Status: offline
how many rpms does the os pack
_____________________________
XXX-NT
(in reply to Jammin_Lee)
       Post #: 26
RE: what engine for xxx-nt - 1/15/2005 2:11:51 AM
David D
Status: offline
I don't know i got half way through my breakin and it was movin nicely and rpm's and horsepower aren't every thing drivability and reliablility are what i like and os has both of them.
       Post #: 27
RE: what engine for xxx-nt - 1/15/2005 4:20:06 AM
Jammin_Lee
Status: offline
so which engine could u show me the site where this engine that i could find the exact engine to fit in my xxx-nt and it does fit in there without having to buy something right
XXX-NT
(in reply to David D)
       Post #: 28
RE: what engine for xxx-nt - 1/15/2005 6:24:02 AM
ThunderbirdJunkie
Status: offline
realistically, the .12 CV-R has about as much power as any "normal" driver can use.
Trust me, as new as you are, you don't wanna get a crazy engine.
and if your Mach 15 is a rear exhaust, you will need at least a new header, possibly header AND pipe.
Some people can mess up an anvil with a rubber hammer
       Post #: 29
RE: what engine for xxx-nt - 1/15/2005 2:15:21 PM
David D
Status: offline
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUJ72&P=7 There it is the only thing is if the carb comes like that you will have to put it on the right way but that engine will work with the stock exhaust if your engine is a side exhaust to if not you will need a header.
(in reply to ThunderbirdJunkie)
       Post #: 30
RE: what engine for xxx-nt - 1/15/2005 4:29:00 PM
sledmanass
Status: offline
Get the OS .12 CV-R, youll be very happy with it, im gona get it next year after i beat on my stock .18 some more
http://www.geocities.com/nitroandelectricrc/home.html
       Post #: 31
RE: what engine for xxx-nt - 1/15/2005 4:53:26 PM
Jammin_Lee
Status: offline
i want a slide carb will i have to do something or buy something for that and so what your saying is that i can just put it in my truck without buying anything
XXX-NT
(in reply to sledmanass)
       Post #: 32
RE: what engine for xxx-nt - 1/15/2005 4:56:46 PM
Jammin_Lee
Status: offline
how about this engine is this a better engine than the cvr and do i have to add anything or buy anything to put it in my truck O.S. .12 TR (P)-T 5 Port
XXX-NT
       Post #: 33
RE: what engine for xxx-nt - 1/15/2005 5:06:59 PM
Jammin_Lee
Status: offline
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCNA3&P=7 there is the exact place of it and how is this engine the adam drake engine http://www.nitrohouse.com/images/TRIS12SE-450.jpg and this engine the novarossi Rear Exhaust .12 w/Slide Carb. MR12 SG Crank Turbo
XXX-NT
       Post #: 34
RE: what engine for xxx-nt - 1/15/2005 5:23:18 PM
David D
Status: offline
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBM06&P=7 you will need this to convert to slide carb and it will end up looking like this it is my nieghbors xxx-nt.
Click to see fullsize image.
Click for fullsize
       Post #: 35
RE: what engine for xxx-nt - 1/15/2005 5:40:22 PM
Jammin_Lee
Status: offline
all that is is dirt
but which motor is best out of those i named tho
XXX-NT
       Post #: 36
RE: what engine for xxx-nt - 1/15/2005 5:56:53 PM
David D
Status: offline
Ya i keep telling him to clean the truck but he refuses as to the engine that is an old novarossi and you should probably stay away from them as in bashing they are way to expensive for that. The tr is an on-road engine, but some people still put them in stadium trucks though you eould need the linkage kit and a new exhaust header and the model you showed is and sg shaft which won't work in the xxx-nt. I think you should just stick to the cv-r it would be easy to put in and it is meant for off road.
       Post #: 37
RE: what engine for xxx-nt - 1/15/2005 5:59:09 PM
David D
Status: offline
Look here it shows the two shafts so you eill understand which you need http://forums.radiocontrolzone.com/showthread.php?t=186990
       Post #: 38
RE: what engine for xxx-nt - 1/15/2005 7:14:01 PM
Jammin_Lee
Status: offline
Sirio .12 EVO 2 , 5 Port
XXX-NT
       Post #: 39
RE: what engine for xxx-nt - 1/15/2005 7:15:48 PM
Jammin_Lee
Status: offline
is that engine side exhaust or rear exhaust
XXX-NT
       Post #: 40
RE: what engine for xxx-nt - 1/15/2005 7:24:23 PM
Jammin_Lee
Status: offline
and what does the mach .15 engine have and what would the xxx-nt stock pipe need side or rear exhaust
XXX-NT
       Post #: 41
RE: what engine for xxx-nt - 1/15/2005 7:36:28 PM
David D
Status: offline
Look at the dynamite and if it looks like my nieghbors exhaust it is side if it looks different it is prabably rear exhaust and the sirio will not be a good bashing engine it is an all out race engine it eill be slightly harder to tune it will wear out faster and will cost more for piston sleeves and parts.
       Post #: 42
RE: what engine for xxx-nt - 1/15/2005 9:17:55 PM
ThunderbirdJunkie
Status: offline
quote:
ORIGINAL: xxx-nt kid
Dude, seriously, this should be a dead issue.
Is this truck your first nitro? If so, you're better off waiting till you blow up your little Mach .15 before you upgrade...and when you upgrade...Why would you go crazy with an engine if you're not racing competitively every weekend?
       Post #: 43
RE: what engine for xxx-nt - 1/15/2005 9:25:00 PM
Jammin_Lee
Status: offline
yea i just want to know what the second engine is that i will be gettine and evaderst man so get the os engine for bashing
XXX-NT
       Post #: 44
RE: what engine for xxx-nt - 1/15/2005 9:26:55 PM
Jammin_Lee
Status: offline
also if ill be bashing 90% of the time should i upgrade to all graphite or stay with the stock stuff i wont be driving in weather under 40degrees
XXX-NT
