opjose
MD, USA Status: offline
I was wondering if anyone could answer my question about the following. I tried breaking in and adjusting the engine as per the included documentation. With the needle set to 3 turns and the idle mixture set to 2-3mm the engine would not start, other than an initial second of turnover because of it being primed. After a lot of playing around I've been able to make it run fairly well, but I'm bemused by how far off I am on this engine from what the documentation states. To get it to run properly and to be able to break it in, I had to; - First adjust the idle mixture (low speed screw) until there was almost NO gap visible between the pin and the receptacle. I know that fuel flows around the mixture "pin" so this does not cut it off, but this is a far cry from the 2-3mm stated in the manual. Is this too far in? It does idle properly this way. It seems to pinch test fine. - Until I adjusted the idle mixture to the above, I could not find a point where the engine ran properly at high throttle. Once the idle was set I finally kept backing out the high speed mixture knob until it began to run and then started the pinch testing. It now runs but I have the knob almost FIVE turns out instead of the factory 1 1/2, or the 3 turn "rich" setting the manual suggests. Pinch testing sounds fine. There are no fuel flow problems that I can find, and with this configuration the engine does run with a "but"... And that is, that as the throttle is reduced slowly there is a point where you can hear the engine decrease in speed in a non linear manner. As if there is a "bump" along the way... so to speak. The engine does NOT die out going from high to low many times, or vice versa... So do I merely accept these settings or should I suspect that something is amiss? Thanks for any and all replies.
_____________________________
- Build em'', fly em'', crash em'' and build more.
