RE: INCREDIBLE PLANE ! LOOK ! (Full Version)
All Forums >> [Radios, Batteries, Clubhouse and more] >> [Full Scale planes, cars, helis, boats] >> Airplanes - Full Scale
Message
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (10/21/2005 11:04:05 AM)
quote:
They are crashes waiting to happen.
U-N-B-E-L-I-E-V-A-B-L-E
vlizard -> RE: INCREDIBLE PLANE ! LOOK ! (10/22/2005 4:58:00 AM)
quote:
ORIGINAL: Johng
quote:
ORIGINAL: William Robison
Grant:
For the most part I can't disagree, but
quote:
...the tail on the A300. Well actually the failure was due to the pilots overloading the tail due to repeated rudder inputs.
is so much bull.
If a control surface can be broken or destroyed in normal flight regimes it is faulty.
"Repeated rudder inouts?" Are they supposed to count, and only kick the rudder pedals 15 times in a flight? Maybe 20? The FAA would never allow such a limitation,
I have no idea who put the pressure on who in this investigation to call it pilot error, but was it really pilot error? No. Not when the vertical fin breaks off in the climb out.
Bill.
Sorry Bill, I think you a quite wrong. Apply the same thinking to elevator, on any plane. You say "normal flight regimes" , well get that puppy in cruise flight and pull yoke full back, and assuming you are still conscious, push it full forward as fast as you can. Get out the abbacus , cause you will be counting the parts that fall off. The guy that broke that plane was stomping pedals like there were roaches under them, without good reason. He was going from left stop to right stop at a speed such that the plane was swinging to full yaw one way, just when he was applying full rudder the opposite way, creating higher forces than anyone anticipated. And it wasn't at all necessary. And while it wasn't in cruise flight, it was doing around 200 kts, in much thicker air than typical cruise, so the dynamic pressure (equivalent airspeed) was in the same league.
No plane, no part of any plane is beyond over-stressing, from Cessna to Lockheed, without having a FBW to take control away from the pilot. Your comment "If a control surface can be broken or destroyed in normal flight regimes it is faulty." cannot be lived up to by any manufacturer. That's like the old - make the planes out of the stuff they make the black box out of. You could, but you wouldn't have a very good plane. Same with this issue.
As I said before in this thread, 3 parties share responsibilities for that crash. The pilot for doing the mambo on the pedals, the airline for incomplete upset training, and Airbus for making the rudder much easier to move with a smaller travel than other models of the A300. But mostly the pilot for doing things to the airplane that made other pilots wonder what he was thinking. What wasn't a problem is the strength of the vertical surface. It withstood force equivalent to hanging two max gross semi trucks from the side of it.
But that Airbus that flew into the trees was a poor flight control design. If the airplane can get into a mode where it won't obey the pilot, it needs to have a little robot that taps the pilot on the shoulder and tells him what the plane it doing.
Sir u could not break the rudder on a friggin jenny at climb speed full left or right in any Cessna I've been in will hardly cause a bend. No aircraft that I can recall has had a yaw controlling surface fall of at anything less than max cruise. Just to be sure I've checked the ntsb and related sites and I can't find any NEWER registered AC that has lost a vertical control surface at any alt at any speed remotely close the the AIRJUNKS period.
vlizard -> RE: INCREDIBLE PLANE ! LOOK ! (10/22/2005 5:20:35 AM)
quote:
ORIGINAL: Willdo
quote:
ORIGINAL: vlizard
At the present rate of loss Airbus will catch Boeing in about 7 years best I can figure.
At the present rate of loss of what? - passengers? profits? aircraft sales?
Ok, as if you didn't know I was talking planes. If the numbers I get from the U.S. and European Gov "saftey" sites are to be believed. In Airbus's first 4 years of opereation they lost more passenger aircraft than Boeing, McDonnel Dougless and Lockheed did In 15years just prior. To put this in perspective. The 3 American manufactures mentioned in the times mentioned flew over 100,000 miles to Airbusses 1. In other words for every 1mile traveled by an Airbus the each of the three American Manufacturers traveled 100, 000. The U.S. grounded the entire dc 10 fleet for two crashes for heavens sake. I still wanna know how much the french and brit govs are bribing U.S. officials to let airbus fly their crap over my home. Here is where it gets real good. In the days before there was radar and planes were flew "seat of the pants" Boeing lost less aircraft per year than Airbus does now. No other Major manufacurer even comes or has came close to airbuses losses per aircraft built or miles flown. These are facts. Check the stastics for yourselves. There is a reason that when I fly I will not ride in a 737. They have lost two or 3 to a rudder failure! To put this in perspective. If the Boeing 737 was part of the Airbus fleet it would be their safest plane!!! I repeat I will not fly in any airbus for money. I have flown in ww2 vintage AC that I feel safer in. They are the equals of most of the cold war era Russian aircraft at best! Most are far worse safety wise.
Willdo -> RE: INCREDIBLE PLANE ! LOOK ! (10/22/2005 10:51:53 AM)
The airlines obviously are reading the statistics quite differently to you, and you don't have to fly if you don't want to of course!
I remember flying around the world in Boeing 747's right after the door blew out on one flight on the way to New Zealand, and I might add that it took the father of one of the victims sucked into the engines about four years and a lot of money, to convince Boeing that the door locking arrangement was faulty, ( I believe they eventually conceded).
The Boeings were not grounded then, and were not grounded in other cases as well, - however, I still believe in the Boeings and by the way, our national airline operates the 737, ( good reliable little workhorse despite the problem you mention) 747, 767, and are soon to receive the 777 .
- I do hope that the motive for your dissent towards the Airbus is not just blind patriotism.
Oh, and by the way, did I hear you mention corruption amongst your airline officials?
robert -> RE: INCREDIBLE PLANE ! LOOK ! (10/22/2005 2:36:42 PM)
Sounds like alot of national pride to me. I'd be just as worried about feul tanks blowing themselves, thrust reversers going off in mid flight, doors ripping off, bulkheads failing due to faulty repairs, engines falling off and so on. So Boeing have had their troubles too. Airbus did have planes falling out of the sky to begin with but nowadays, aircraft safety is extremelly good and both boeing and airbus appear to have exceptional reliability, especially on the more modern aircraft. But hey, national pride is at stake!
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 6:47:40 PM)
Breaking news [&o]
William Robison -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 8:35:43 PM)
Strykass:
I'm surprised it took you so long to crow. Must ahve been at least twelve hours betwedn the crash and your post.
Had it been an Airbus I'll bet we still wouldn't have heard from you.
Bill.
William Robison -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 8:37:27 PM)
Strykass:
And when it all comes down I'll bet further that it was not the fault of the plane.
Bill.
William Robison -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 8:54:06 PM)
Strykass:
From the Air Nigeria web site http://www.flyairnigeria.com/index.html :
quote:
Air Nigeria is the world's first and most innovative airline that offers direct, non-stop air service to over 75 countries and 185 destinations around the world. Our aircraft are built by the most skilled craftsmen and women on the face of this Earth, from the University of Zaria, Nigeria. Zaria, Nigeria is the global epicenter of all technological innovations.
Reaching speeds of Mach 5, our sleek, luxurious, propeller modified jet-liners are able to transport our customers with unprecedented speed and smoothness that other airlines have not been able to achieve. Come fly with Air Nigeria and experience a new way of luxury travel.
Our airline is the pride of our country. The prince of Nigeria wants you to experience our luxurious carrier as well as welcome you to our lush land of beauty, dreams, and opportunity. For this reason, he is now offering all passengers $10 advance fee payment flights to any destination. That's right. Only $10. You cannot find a better price or better airline to fly with.
"Come Fly The Nigerian Skies"
Their maintenance manager also said "We prefer the Boeing planes, with our shoddy maintenance they last a lot longer than the Airbus planes."
Haw.
Bill.
William Robison -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 9:00:46 PM)
Strykass:
To be fair, the operator of the 73 that just went in was Bellview Airlines.
I don't think there is a "Real" Air Nigeria.
Bill.
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 9:27:04 PM)
wow, don't get that angry! It was just a side note for Vlizard who went to far imho (moreover, he PM'ed me with a very harsh comment). I did not even try to see what happened exactly when I learnt that the airline is an african one.
I'm convinced Airbus does not have any better safety record than Boeing, they 're probably playing in the same league today.
Crash history would prove that design woes are rarely at the origin of these mishaps, which is not the case for cheap maintenance (fake spare parts are a REAL plague, even in big western airlines), poor pilot skills, ATC, or whatever...
As a passenger, the first thing I pay attention to is not the aircraft, but the airline that operates it. It makes sense to me.
Please, my name is Strykaas, not Strykass ;)
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 9:29:31 PM)
Last, please avoid comparing Airbus and Boeing as if they were 100 % different aircraft. They share quite a lot of sub-systems.
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 9:32:24 PM)
The second one took off last week...
[image]http://www.airliners.net/photos/photos/1/0/6/938601.jpg[/image]
William Robison -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 9:47:56 PM)
It's as if one white whale wasn't enough...
Captain Ahab, after all, had only one Moby Dick.
I don't know who started the comparison, but when we are talking about companies building air liners comparisons can not be avoided.
Bill.
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 9:54:31 PM)
I think I did, but many have taken it too seriously [&:]...
mulligan -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 10:16:50 PM)
Just wondering...
Does any of this my-plane-crashes-less-than-your-plane and national airline pride stuff have ANYTHING to do with RC??
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (10/23/2005 10:20:46 PM)
I think we are in the full scale sub forum ;)
Willdo -> RE: INCREDIBLE PLANE ! LOOK ! (10/24/2005 1:14:07 AM)
Looks like the childish bickering is just going to go on and on.
I do think that the last flurry of retorts, provoked by the crash is in very bad taste - fact is, they all crash for various reasons and we just have to live with that!
Don't knock the Boeings, they have been (and still are) great, and don't knock the A380, because not one of us knows how good or bad it is, just wait, and don't let loyalty to your respective countries make you produce stupid biased statements on how bad it's going to be!
- and yes, I'll probably face a barrage of more of the above! [8|]
blw -> RE: INCREDIBLE PLANE ! LOOK ! (11/5/2005 3:36:51 AM)
The orders for the Boeing 777 are kicking the crap out of Airbus 340 project. Airbus made repeated mistakes and Boeing went the other direction with the 777. Airbus pretty much alienated potential customers with their schizophrenic design process. The 777 will be all new, without sharing from other projects. The design is all modern since they basically started from scratch. It is way cheaper for carriers to operate. The biggest thing with operators is that engine changes on the 777 can be made in a day or two. Not swapping a bad engine out, but swapping engine types as when the big carriers sell off the aging fleet to smaller carriers who use different brand engines. I may be behind some of the latest news on orders, but last month Boeing had something like 330 orders for the 777 and Airbus had 30. The 340 and 777 compete for the same haul market, so Airbus is the big loser.
This whole thread started from envy, pure and simple. Once again, Boeing kicks butt without government bailouts/subsidies/kickbacks/political arm twisting/white flag waving/UN interventions, etc
William Robison -> RE: INCREDIBLE PLANE ! LOOK ! (11/6/2005 4:25:44 AM)
This is indeed the "Full Scale" forum, and there is no requirement for a tie-in to r/c modeling.
Strykaas has trumpeted the superiority of French aircraft, proven (he thinks) by the new white elephant known as the A-380 from Airbus.
Fact: Airbus is a government owned corporation no matter how they try to disguise it, it will not be allowed to fail no matter how great the cost to the European taxpayers.
Fact: Boeing is a true private corporation that competes successfully in the world market without subsidies.
Bill.
GRANT ED -> RE: INCREDIBLE PLANE ! LOOK ! (11/6/2005 6:40:58 AM)
quote:
ORIGINAL: blwblw
The A 340 has 938 orders not 30!! The 777 can not change engines from one type to another in a few days. I believe you may have mixed up the 777 (an 11 year old design) with the yet to be built 787.
If you are going to sprout off about how good boeing is at least get your facts straight.
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (11/6/2005 9:50:21 AM)
Bill,
Europe and USA are argueing about disguised subsidies made by government through R&D related to military programs. Indeed, Boeing now plays in both military and civil market...
Strykaas -> RE: INCREDIBLE PLANE ! LOOK ! (11/6/2005 3:47:29 PM)
Bill.
Hey, regarding the white flag, why wouldn't we want peace between good 'ol friends ??
blw -> RE: INCREDIBLE PLANE ! LOOK ! (11/7/2005 1:30:32 AM)
I had a couple of facts off, Grant Ed. No need to get your panties in a wad. I should have said Boeing 787s and Airbus 350s. I misread a report when I wrote that.
The engine swap comment stands. I didn't mention fuel economy and increased cargo capacities.
I'm not sure why you are getting wrapped too tightly over this and had to come off the way you did.
your turn to 'spout off'......
GRANT ED -> RE: INCREDIBLE PLANE ! LOOK ! (11/7/2005 7:03:41 AM)
I'm not tightly wrapped over this at all, didn't mean to sound that way but it does frustrate me when people make comments that are obviously incorrect.
Yes the 787 can change engine types in a matter of days but the 777 can not.
Page: <<   < prev  3 4 5 6 [7] 8 9 10 11 12   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.4838867
