RE: Carden 35% Extra Build
Tower Hobbies
Logged in as Guest
  Printable Version
Top Flite GS Stab Relocation Kit - Kit
Seller:  tony-howard
Details:   $12.50   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: Carden 35% Extra Build
Page: <<   < prev  1 2 3 4 [5]
Login
RE: Carden 35% Extra Build - 10/21/2005 11:43:16 PM
jmiracle
Status: offline
that's where I set mine for it's first flights. It was very stable at this location....nearly perfect. I did end up adding a couple oz of weight in the tail to move it back a smidge more and it's still extremely stable.
You won't have any problems with that CG.
(in reply to Jack28)
       Post #: 101
RE: Carden 35% Extra Build - 12/8/2005 4:02:57 AM
Jack28
Status: offline
Well I finally got to maiden the Carden Extra 330S, All I can say is WOW !!, what a great airplane. The DA-100 started with no problems and ran great. I taxied away and took off ,did a few patterns around the field, it required No trim at all. This plane really does everything great, rolls are like the are on a rope, and I can't believe how slow and stable it is landing. I am really impressed with this Airplane. Thanks to all who answered my posts during the build. Here are some pics from the field, By the way the graphics were designed and cut by Aerographix. (www.Aerographix.biz), They really make the plane stand out in my opinion. Thanks again ,Jack.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Jack George
(in reply to jmiracle)
       Post #: 102
RE: Carden 35% Extra Build - 12/8/2005 1:46:20 PM
rcplanefan
Status: offline
Really nice looking plane, Jack. I have owned two of the 40%'s and I can tell you that you will continue to be impressed as long as you own this one! Nice.
Ken
       Post #: 103
RE: Carden 35% Extra Build - 12/8/2005 2:03:13 PM
jmiracle
Status: offline
Jack,
Your Extra looks great. Glad to hear the maiden went well. I feel the same way about mine....so much so I plan to purchase another 35% Extra kit to keep as a spare!
(in reply to rcplanefan)
       Post #: 104
RE: Carden 35% Extra Build - 1/5/2006 12:26:23 AM
mihelich
Status: offline
Hello everyone,
Well, I am now the proud owner of a 35% Edge 540 kit from Carden.
It will be coming from via the "brown man" this Friday. Looks like I will be having a fun weekend.
I look forward to being part of this great Carden family and will be posting my build progress
and asking questions if needed along the way.
Tom Mihelich
If practice makes perfect and nobody's perfect..why practice.
       Post #: 105
RE: Carden 35% Extra Build - 1/5/2006 12:49:44 AM
Flyin Woodbutcher
Status: offline
Glad to hear it Tom , I hope this means that they are going to get the 40% Edges next. I"ve had one on order for 3 months, also the DA 150s are not avaliable.
Kent
(in reply to mihelich)
       Post #: 106
RE: Carden 35% Extra Build - 1/13/2006 12:17:42 AM
Jim B
Status: offline
We must be the luckiest people alive! My son and I order 35 and 40% extras from Dennis and Caroline and got them both very quickly, reportedly this doesn't always happen due to high demand, and ordered our DA 100 and 150 on monday and they're on their way. I really enjoy building my 35%er more than my son's 40%er...I think i feel less nervous and less intimidated of the size. These are fantastic kits, they remind me of the MK pattern kits from the 80's. The quality of the wood and the precision of the cuts requires NO prep work before gluing.
Jim B
(in reply to Flyin Woodbutcher)
       Post #: 107
RE: Carden 35% Extra Build - 1/13/2006 12:33:01 AM
Flyin Woodbutcher
Status: offline
still no word on my Edge yet
feeling neglected Kent
(in reply to Jim B)
       Post #: 108
RE: Carden 35% Extra Build - 4/2/2006 8:15:17 PM
zzw26n
Status: offline
jmiracle and Jack,
May I ask what throws are recommended for Low Rate & High Rate for the 35% Extra ??
And how much expo did you use?
thanks, Ward
       Post #: 109
RE: Carden 35% Extra Build - 4/2/2006 11:40:39 PM
jmiracle
Status: offline
Ward,
I can't say anymore exactly how much throw I'm using.....i've tweaked it quite a bit since it first flew last spring. I started by setting high-rates for all the throw I can get without binding.
Low rates are
Ail: 62% throw/40% expo
elev: 55% throw/45% expo
rudder: 100% throw/35% expo
high rates are
Ail: 125% throw/65% expo
elev: 130% throw/65% expo
rudder: 135% throw/60% expo
Hope this helps.
quote:
ORIGINAL: zzw26n
jmiracle and Jack,
thanks, Ward
(in reply to zzw26n)
       Post #: 110
RE: Carden 35% Extra Build - 4/3/2006 1:40:39 AM
zzw26n
Status: offline
thanks jmiracle,
Right now I can get 40-45 degree's from elevators for high, Ailerons around 30 degree's and rudder around 40-45 degree's.
so, elevators would be 55% or 22 degree's for low rate, sounds about right?
       Post #: 111
RE: Carden 35% Extra Build - 4/3/2006 1:50:11 AM
jmiracle
Status: offline
yup....sounds about right....if i remember right, i got right around 45 degrees on my elev.
just a note.....i tend to setup my planes on the soft side....i've never liked a really touchy plane.
       Post #: 112
RE: Carden 35% Extra Build - 4/3/2006 2:01:04 AM
zzw26n
Status: offline
jmiracle, your fast ............ thanks. Your numbers look correct, thanks again.
Ward
       Post #: 113
RE: Carden 35% Extra Build - 4/11/2006 4:50:29 AM
vertical ts
Status: offline
Is there anyone using this plane for IMAC that could tell me where they have their cg?Thank you in advance
       Post #: 114
