wind junkie
NY, USA Status: offline
Poof, Did you put bends on both push rods to trap the fuel tubing? I normally only put a bend only on the push rod going to the carburetor for these reasons: 1) the throttle servo rod can slide completely off and disconnect for better forgiveness if the motor should completely separate 2) having fuel tubing on the motor push rod makes it easier to FIND the push rod in the grass. The throttle end is usually the one that gets thrown the farthest, and a simple Z bend sometimes comes off the throttle. (a clevis to the carb arm could fix this, but I'm cheap and lazy) 3) if I angle up the bend on the carb end, I have an instant "handle" to fine tune my idle or high speed. The radio trim will always be perfect from crash to crash, but I find if the motor separates, I hook it up again, set for throttle cut, and give a gentle pull on the carb rod to re-set the correct position mechanically through the slip joint.
_____________________________
Arguing with an engineer is like wrestling a pig. Everyone gets dirty and the pig likes it.
