Aerosplat
GA, USA Status: offline
As promised, I am going to describe what I have done to attach the main wings. I just could not live with those screws / bolts through the wing into the wing tube. I asked the Administrator about the best way to post this, because it requires about 9 picture posts. He said to do it in a series of 9 posts with only one picture per post, so here goes. Some of you may glitch at the idea of using rubber bands to hold those beautiful wings on. I used rubber bands for years as the only way of holding wings in wing saddles, and I NEVER lost a plane due to rubber bands failing. All this through Inside and outside loops, fast rolls, and snaps, and never a failure. Also consider the forces at work on the Edge 540 wings. All the up and down loading, and front to back loading is being absorbed by that hefty aluminum wing tube. The only thing those wing screws (in my case the rubber bands) are doing is preventing the wings from pulling away from the side of the fuselage. You will never get a roll rate or spin rate fast enough to exert much force at pulling the wings outward. Enough justi |
