EAA Headwind (need throws)
Tower Hobbies
Logged in as Guest
  Printable Version
Stearman Biplane - RTF
Seller:  WarbirdII
Details:   $3,500.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Vintage & Antique RC >> EAA Headwind (need throws)
Page: [1]
Login
EAA Headwind (need throws) - 1/18/2005 7:45:43 PM
Zen Buddah
Status: offline
I recenty completed building the EAA Headwind (plan CF364 Flying Models) and can't wait to
get it up in the air. One thing that I noticed was that the plans and magazine article does not indicate the rudder and elevator throws (three channel). Does anyone know what the throws are or have a comparible/similiar plane that I could pattern the throws after.
The dimension of the EAA Headwind are 25 in fuse, 38 in wing, weight about 3lbs, wing core about 6.5 in, rudder at widest part 3 in.
ZB
       Post #: 1
RE: EAA Headwind (need throws) - 1/21/2005 5:20:55 AM
susquach
Status: offline
Zen,
not sure I can be much help to you, but I'll pass-on what I can. Some years ago I drew-up and built a 90" Headwind. It flew great using throws that would be correct for a Cub. So, for lack of a better idea, you might just want to start with settings appropriate for a Cub, Baby Ace, Pietnpol, ect. Most likely, whatever looks right, will probably work as the Headwind is a sweet natured plane. Good luck with it!
(in reply to Zen Buddah)
       Post #: 2
RE: EAA Headwind (need throws) - 1/21/2005 4:53:53 PM
Bax
Status: offline
Usually, if you use a max of 20 degrees to start, you'll do OK on initial flights. You'd then adjust the amount of throw to suit the way you want the model to fly.
Rudder usually isn't too critical. Many people just set it up to get as much throw as possible. On a 3-channel model, though, you need to be more careful so that you get enough control but not too sensitive.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to susquach)
       Post #: 3
RE: EAA Headwind (need throws) - 1/21/2005 9:07:13 PM
Zen Buddah
Status: offline
Thanks for the advise, I will set the rudder throws to about 1.5" and elevator to about .75" and see how that works for me.
Real quick question..
Now, how do you get rid of Snow?
Zen
(in reply to Bax)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.219RCU1
