Glassing question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Glassing question
Page: [1]
Login
Glassing question - 1/19/2005 5:00 AM
Timberman
Score: 100
Last Login: 1/11/2009
Status: offline
I'm about to undertake in my first glassing project w/ a TF Seafury. I've looked at the Art's Hobby web page and I intend on using this as a quide; however, the thing that I'm not sure about how to handle glassing around control areas where hinges attach and the inside portion of the flaps. How do I handle the close tolerances in these areas? I was planning on not using any fiberglass cloth in these areas, just brushing on the resin but didn't know if that is the right way to handle it. Thanks for the help!
Hide Signatures
       Post #: 1
RE: Glassing question - 1/19/2005 5:43 AM
Gremlin Castle
Score: 110
Last Login: 5/17/2013
Status: offline
The glass probably won't add enough thickness to matter if you are using 1/2 or 3/4 oz cloth and do not let the resin build up above the cloth thickness. Brushing resin on the raw wood and sanding it after curing also works well.
quote:
ORIGINAL: Timberman
_____________________________
Up elevator is not always your friend.
Hide Signatures
(in reply to Timberman)
       Post #: 2
RE: Glassing question - 1/19/2005 9:29 AM
Henrik_Rosen
Score: 100
Last Login: 6/9/2008
Status: offline
I can recomend to use a(dont know the english word) small roll on brush. I attach a picture so you can see what I mean. I think that brush maked it all much easer.
Henrik Rosen
SWEDEN
Hide Signatures
(in reply to Gremlin Castle)
       Post #: 3
RE: Glassing question - 1/19/2005 3:25 PM
tubig
Score: 102
Last Login: 2/6/2013
Status: offline
on the TF spit i'm currently working on, i'm not going to glass the inside of the flaps....too tedious. i'm simple going to paint and fuel proof that area. besides you really can't see it anyway and adding resin will only add unnecessary weight.
Tim
Hide Signatures
(in reply to Henrik_Rosen)
       Post #: 4
RE: Glassing question - 1/19/2005 4:09 PM
Edwin
Score: 156
Last Login: 5/25/2013
Status: offline
Something else to consider is the quality of the glass. Most conforms very well. The stuff I've gotten from the hobby shop was junk. Only good for flat surfaces. Would not stay down over a 90deg bend. The last plane I did was a recovering job on a corsair. I didnt glass the seam areas of the flaps and hinges. Looked fine, nobody noticed.
Edwin
Hide Signatures
(in reply to tubig)
       Post #: 5
RE: Glassing question - 1/20/2005 4:48 PM
Timberman
Score: 100
Status: offline
What should I use 1/2 oz or 3/4 oz cloth?
Hide Signatures
       Post #: 6
RE: Glassing question - 1/20/2005 8:30 PM
Edwin
Score: 156
Status: offline
I would use the lightest you can find. Its not ment to add strength, just a good base for paint.
Edwin
Hide Signatures
       Post #: 7
RE: Glassing question - 1/21/2005 2:30 PM
tubig
Score: 102
Status: offline
ditto. i'm using CST's 0.6oz cloth because it's the lightest i could find.
Tim
Hide Signatures
(in reply to Edwin)
       Post #: 8
RE: Glassing question - 1/21/2005 11:33 PM
Darklotus
Score: 100
Last Login: 12/3/2012
Status: offline
Hi everyone.
I'm also going to be glassing my bird soon. I have made a few tests with hobbico 3/4 Oz. It seemed to do pretty good. My question is, is there something better out there then what I used? Any good suppliers for glass cloth? Since this is my first glassing job I will be doing are there any good site for technique, supply's, and how - to's ?
Colorado-rc.com
Hide Signatures
(in reply to tubig)
       Post #: 9
RE: Glassing question - 1/22/2005 1:23 AM
the-plumber
Score: 104
Last Login: 8/15/2006
Status: offline
http://www.cstsales.com/
http://www.acp-composites.com/
http://www.fibreglast.com/
and for more than you ever will have need to know about composites, there is always
http://www.jetracing.com/composites/composites.html
< Message edited by the-plumber -- 1/22/2005 1:24 AM >
Cheers,
Fred McClellan
Hide Signatures
(in reply to Darklotus)
       Post #: 10
RE: Glassing question - 1/22/2005 1:28 AM
the-plumber
Score: 104
Status: offline
quote:
ORIGINAL: Henrik_Rosen
Not bad for someone who uses English as a second language.
The term is 'roller' or 'paint roller'.
In the states, epoxy-specific rollers can be had here.
I cut the covers in half on the bandsaw to make 'em fit a 3" roller frame. Works really well for applying epoxy/glass finishes.
< Message edited by the-plumber -- 1/22/2005 1:30 AM >
Cheers,
Fred McClellan
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.482RCU1
