New video tutorial for installing AFP(D) aircraft
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> New video tutorial for installing AFP(D) aircraft
Page: [1]
Login
New video tutorial for installing AFP(D) aircraft - 1/19/2005 9:41:50 PM
STLPilot
Status: online
For anyone wanting to learn how to install an aircraft for AFP or AFPD here ya go!
I'll probably make some more tutorials for FAQ's.
I hope this helps a lot of you guys that are having problems installing the aircraft.
Enjoy!
Click here to view the Flash tutorial
< Message edited by AFSalmon -- 6/10/2006 2:38:09 AM >
_____________________________
Here At The Wall
       Post #: 1
RE: New video tutorial for installing AFP(D) aircraft - 1/20/2005 3:29:57 AM
Sokhar
Status: offline
nice work should save you answering that question 8 million times more LOL
< Message edited by Sokhar -- 1/20/2005 2:22:06 PM >
http://img90.exs.cx/img90/7515/sokhar2.gif
(in reply to STLPilot)
       Post #: 2
RE: New video tutorial for installing AFP(D) aircraft - 1/21/2005 1:41:30 AM
Mudsurfer1234
Status: offline
what did you use to make that? i would like to try it for my VTOC recording
Scott Shoemaker
(in reply to Sokhar)
       Post #: 3
RE: New video tutorial for installing AFP(D) aircraft - 1/21/2005 9:08:44 AM
STLPilot
Status: online
Sorry, it won't work for VTOC.
Here At The Wall
(in reply to Mudsurfer1234)
       Post #: 4
RE: New video tutorial for installing AFP(D) aircraft - 1/21/2005 8:25:56 PM
Mudsurfer1234
Status: offline
darn
Scott Shoemaker
       Post #: 5
RE: New video tutorial for installing AFP(D) aircraft - 1/21/2005 9:49:18 PM
Ian.W
Status: offline
flash MX or flash corperate im guessing. nice bit of work dion
Ian Watson
Team Flightpower
       Post #: 6
RE: New video tutorial for installing AFP(D) aircraft - 2/2/2005 3:10:12 AM
triggerdog
Status: offline
The flash tutorial is great, but it didn't work for me installing planes to aerofly pro. Do the planes work on deluxe only or did I do something wrong, I think I did everything exactly as described.
Lee
       Post #: 7
RE: New video tutorial for installing AFP(D) aircraft - 2/3/2005 12:05:27 PM
triggerdog
Status: offline
I discovered the problem with my AFP not recognizing dl planes was that I had to install the patch to update AFP. The planes work fine now.
(in reply to triggerdog)
       Post #: 8
RE: New video tutorial for installing AFP(D) aircraft - 2/9/2005 6:54:14 PM
captinjohn
Status: offline
Is it easy to burn this tutorial vidio on a floppy disc or compac disc...so I can paly it about 100 times!! Thanks
I never met a engine I did not like!
       Post #: 9
RE: New video tutorial for installing AFP(D) aircraft - 2/13/2005 1:41:02 PM
dgcalhoun
Status: offline
How do you save the file to a disk"
(in reply to captinjohn)
       Post #: 10
RE: New video tutorial for installing AFP(D) aircraft - 2/13/2005 2:32:37 PM
STLPilot
Status: online
Sorry ... you can't it's Flash. Just use the pause feature.
It should only take you 1 or 2 times until you can do it on your own.
Here At The Wall
(in reply to dgcalhoun)
       Post #: 11
RE: New video tutorial for installing AFP(D) aircraft - 2/13/2005 3:18:18 PM
dgcalhoun
Status: offline
Thanks for quick response to my question!
       Post #: 12
RE: New video tutorial for installing AFP(D) aircraft - 2/23/2005 2:00:56 AM
shawnskx100
Status: offline
will this work the same if i was using the reflex XTR sim.
thx,
shawn
       Post #: 13
RE: New video tutorial for installing AFP(D) aircraft - 6/10/2005 5:56:51 AM
Dk0r
Status: offline
How about a radio calibration tutorial? .. Ive spent an hour on this and I cant get my Futaba 6exa working right. The slightest touch of any controll max's out the jittry calibration bar. Have reset the radio to factory defaults. All trims set to +/- 0. Not sure what PPM mode is, but the manual here has no relevance regarding it (hit cntrl+f to search pdf contents) http://www.futaba-rc.com/manuals/6exa-manual-v1_1.pdf
Dont know what else to do. Cant get AFPD settings zero'd out. /sigh
< Message edited by Dk0r -- 6/10/2005 6:15:18 AM >
(in reply to shawnskx100)
       Post #: 14
RE: New video tutorial for installing AFP(D) aircraft - 6/10/2005 11:35:42 AM
STLPilot
Status: online
Are all your channel jittery or just a couple?
Here At The Wall
(in reply to Dk0r)
       Post #: 15
RE: New video tutorial for installing AFP(D) aircraft - 10/2/2005 10:42:43 PM
AirNerd
Status: offline
Hey STL when I clic to veiw it shows the OMP on the bottom of the page but I see nothing in the box
       Post #: 16
RE: New video tutorial for installing AFP(D) aircraft - 2/5/2006 5:26:07 PM
WRK
Status: offline
When I try to go to the flash tutorial I get:
"You don't have permission to access /aeroflyvids/install/index.htm on this server."
What is wrong??
Flierbk
