RE: Sig Hog Bipe Build
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Hog Bipe 60
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Kit Building >> RE: Sig Hog Bipe Build
    Page: <<   < prev  18 19 20 21 22 23 24 [25] 26 27   next >   >>
    Login
    RE: Sig Hog Bipe Build - 7/24/2008 2:25:47 PM
    chashint
    Status: offline
    I have my engine mounted per the plans and it works fine.
    _____________________________
    regards,
    Charlie
    (in reply to HugoW)
           Post #: 601
    RE: Sig Hog Bipe Build - 7/25/2008 12:56:08 PM
    MasterAlex
    Status: offline
    quote:
    ORIGINAL: chashint
    Ahhh, glad to hear as that's the route I'm going. I figured that was the right answer since I hadn't really heard of anyone complaining of thrust issues with the motor mount.
    I haven't forgotten about the Hog guys (for anyone who still cares). I haven't been back in the basement for building purposes at all since I last posted in this build thread. It's been a busy Spring/Summer with RC and other life commitments. I plan on starting a new project this fall, but not before finishing the Hog. As soon as I return to the bench, I'll resume/complete the thread.
    -MA
    The 1st step is admitting you have a problem ... okay, I admit it, RC is my obsession!
    (in reply to chashint)
           Post #: 602
    RE: Sig Hog Bipe Build - 7/25/2008 9:38:38 PM
    preparation_h
    Status: offline
    I've had it with my bipe. Can't figure it out.
    If I hit the gas it wants to climb......throttle down and it wants to dive. How do I check wing incidence without a meter. The both "appear" that they are parallel. Anybody else have this issue?
           Post #: 603
    RE: Sig Hog Bipe Build - 7/27/2008 2:34:06 AM
    *JCB*
    Status: online
    quote:
    ORIGINAL: preparation_h
    isn't this what all planes do?
    i guess if you problem is too radical, you may have missed the 1.5deg of downthrust that the firewall is supposed to have in in. I built mine according the the manual without using an incidence meter on the wings or stabilizer and it flies just fine. But i also made sure that the downthrust was correct...
    Shake Things Up!
    (in reply to preparation_h)
           Post #: 604
    RE: Sig Hog Bipe Build - 7/27/2008 5:14:22 AM
    Hircflyer
    Status: offline
    quote:
    ORIGINAL: *JCB*
    What he said....mine flys great with just a little of down elevator...but with the downthrust on the engine
    Finally! Everyday is a weekend
    (in reply to *JCB*)
           Post #: 605
    RE: Sig Hog Bipe Build - 7/27/2008 9:53:55 PM
    Backfired
    Status: offline
    Picked up a Sig Hog Bipe at a sale this weedend. The plane is completey built except for motor mount, servos, balancing, and maiden. Unfortunately no manual was included and it's not available from the Sig web site. I emailed them but no response yet. I need recommended CG, throws, recommended servo type and placement in the plane. Also the fuel tank moves fore and aft. I assume it needs to be tied down or a wood support added to the rear of the tank. Any help would be greatly appreciated.
    The person that built the plane did an excellent job it's beautifully built and covered. He was recently moved to a nursing home and is not in good health. He never got to fly this beauty and I intend to be certain that it's finished right and survives the maiden.
    (in reply to RCKen)
           Post #: 606
    RE: Sig Hog Bipe Build - 7/27/2008 11:24:25 PM
    redipsekud
    Status: offline
    Hello Backfired
    cg as per manual cg is measured from the leading edge of the top wing
    25% 3-5\8 GOOD PLACE TO START
    30% 4-1\8 better elevator responce and quiker snaps
    35% 4-5\8 approach this cg with caution
    thrws are
    aileron 5\8 up snd down
    elevator 3\4 up and down
    rudder 1-1\4 left and right
    as for servos,i just used standard 3004 futaba servos but thats really a builders choice issue.same deal for placement,i prefer to put servos as close to the control surface as possible
    and the tank,also a builders choice issue,i stuffed foam paddeng around mine,never had a problem
    anyways, hope this helps,and good luck on your new plane
    (in reply to Backfired)
           Post #: 607
    RE: Sig Hog Bipe Build - 7/27/2008 11:25:22 PM
    chashint
    Status: offline
    quote:
    ORIGINAL: chashint
    Straight from the manual.
    CG: Measured from the leading edge of the top wing with the plane in the upright position.
    25% - 3 5/8" Good place to start if this is your first biplane.
    30% - 4 1/8" Better elevator response and quicker snaps.
    35% - 4 5/8" Approach this CG with caution. Unexperienced pilots may find this to be to extreme for their ability.
    Aileron:
    5/8" up/down
    Elevator:
    3/4" up/down
    Rudder:
    1 1/4" left/right
    regards,
    Charlie
           Post #: 608
    RE: Sig Hog Bipe Build - 7/27/2008 11:26:40 PM
    chashint
    Status: offline
    drats redipsekud beat me
    regards,
    Charlie
           Post #: 609
    RE: Sig Hog Bipe Build - 7/28/2008 1:07:26 AM
    Backfired
    Status: offline
    Thanks for the quik replys.
           Post #: 610
    RE: Sig Hog Bipe Build - 7/30/2008 1:55:53 AM
    Backfired
    Status: offline
    Good news, Bad news.
    I emailed Sig on Saturday and they have not yet responded to my request for a manual.
    I phoned them today and had an electronic copy of the manual in two minutes.
           Post #: 611
    RE: Sig Hog Bipe Build - 7/30/2008 2:16:03 AM
    chashint
    Status: offline
    I have not tried emailing Sig before, but the one time I needed something a person answered the phone and two days later I had a new rudder in my mailbox.
    regards,
    Charlie
           Post #: 612
    RE: Sig Hog Bipe Build - 7/30/2008 12:26:35 PM
    Backfired
    Status: offline
    Has anyone flown this plane with a .65 four stroke? I purchased the plane with a Saito 65 4 stroke which is the smallest size motor recommended by Sig. I don't plan to do any 3d flying but want a fun flying sport plane and a safe maiden.
           Post #: 613
    RE: Sig Hog Bipe Build - 7/30/2008 5:10:50 PM
    chashint
    Status: offline
    In my opinion the 65 four stroke will not have enough guts for a Hog Bipe.
    Most of the people seem to use 91 class four strokes with a few Saito 82's and 100's thrown in for good measure.
    edit here..........
    I just reread your post, if the plane came with a 65 mounted in it was it ever flown before you got became the owner ?
    If it was then obviously the 65 can fly the plane.
    I still think the plane "needs" a 91 class four stroke though.
    regards,
    Charlie
