RE: TF Piper Arrow II kit - who's building it?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: TF Piper Arrow II kit - who's building it?
Page: <<   < prev  7 8 9 10 [11] 12 13 14 15 16   next >   >>
Login
RE: TF Piper Arrow II kit - who's building it? - 1/29/2006 2:16:04 AM
Phil Bousquet
Status: offline
I suspect you are going to Lakeland in April. Are you staying at Frank's hotel? Have you found better accommodations?
If I get there early I could bring a plane and maybe sneak a flight in on Wednesday.
That would be a thrill.
Phil Bousquet.
(in reply to teamscalepilot)
       Post #: 251
RE: TF Piper Arrow II kit - who's building it? - 2/2/2006 4:00:46 PM
matatoe
Status: offline
Did anyone put a 4-stroke on this plane? Do you have a picture of the cowl? Do you have access to the muffler hose so you can fuel up or did you use an extra fuel tank line?
       Post #: 252
RE: TF Piper Arrow II kit - who's building it? - 2/2/2006 4:26:11 PM
teamscalepilot
Status: offline
I used t-fittings on the lines with pluged ends and tucked them in the cowling. using the OS .91 2c
(in reply to matatoe)
       Post #: 253
RE: TF Piper Arrow II kit - who's building it? - 2/9/2006 9:19:26 PM
matatoe
Status: offline
The directions say to use Bondo to finish the outside of the cowl. What did you use? Are there other products that would be good for this task?
       Post #: 254
RE: TF Piper Arrow II kit - who's building it? - 2/9/2006 9:56:22 PM
teamscalepilot
Status: offline
We used cowlings from fiberglass spec. I think I have an extra one....
       Post #: 255
RE: TF Piper Arrow II kit - who's building it? - 2/9/2006 10:14:59 PM
tailskid
Status: offline
Did you also use their glass cabin ?
_____________________________
# 93 in Club Saito
       Post #: 256
RE: TF Piper Arrow II kit - who's building it? - 2/10/2006 12:58:30 PM
teamscalepilot
Status: offline
I used the on that came with the kit because we used the interior kit also.
(in reply to tailskid)
       Post #: 257
RE: TF Piper Arrow II kit - who's building it? - 2/20/2006 3:21:18 PM
CL-415
Status: offline
Why not use the Fiberglass Specialties cabin top even if you are using the cockpit kit?
Also, I do not want to cover with Ultracote or any ***cote. But fiberglassing the corrugated surfaces is not such a fun thing either. Would covering the stabilator, tail, rudder, flaps and ailerons with only West Marine epoxy without glass cloth be strong enough?? Does Ultracote add that much strenght??
       Post #: 258
RE: TF Piper Arrow II kit - who's building it? - 2/20/2006 3:43:11 PM
teamscalepilot
Status: offline
If I used the fiberglass canopy I would have to cut out for the windows. this would make the windows to deep into the canopy. We painted the canopy white and masked off the windows. as far as plastic covering, this is a sore spot with many scale builders. If the aircraft you are modeling is shinny and new and your model looks the same at the judging distance that AMA discribes, and your documention shows it. The judges at the 2005 NATS had a 3 way tie for high static!! 2 aircraft were painted and 1 was plastic covered. guess which one was mine.
One nice thing about having the aircraft your documenting around is you can take 100s of pictures of it on a nice sunny day to show the shinny paint, and other details you may want to show the judges.
(in reply to CL-415)
       Post #: 259
RE: TF Piper Arrow II kit - who's building it? - 2/20/2006 3:54:51 PM
CL-415
Status: offline
What about strenght? Epoxy only, epoxy with glass cloth, ultracote...??
       Post #: 260
RE: TF Piper Arrow II kit - who's building it? - 2/20/2006 4:31:58 PM
teamscalepilot
Status: offline
That's an easy one! support your wing at the tips between 2 chairs and put a baby scale in the middle and apply pressure. The spar and sheeting will support all the flight loads that I would ever put on the aircraft. Look at all the big IMAC 1/3 jobs.
       Post #: 261
RE: TF Piper Arrow II kit - who's building it? - 2/27/2006 6:16:56 PM
CL-415
Status: offline
quote:
ORIGINAL: teamscalepilot
Here some pictures of the main gear door for the ARROW. Made from 3 layers of 1/64 ply. and using 1 hinge from Aerotech.
Special Thanks To David Turner for his help with the gear doors!!!
Do you have the link to Aerotech? I found 2 diferent web sites/company with that name but can't find anything about hinges from these companies.
       Post #: 262
RE: TF Piper Arrow II kit - who's building it? - 3/6/2006 11:33:47 PM
10Acious1
Status: offline
Hello to all,
Just saying hi, as I have just today purchased My Piper Arrow II. Will be checking in here regularly for ideas, info and of course help.
       Post #: 263
RE: TF Piper Arrow II kit - who's building it? - 3/9/2006 4:59:05 AM
tailskid
Status: offline
You have to make some decisions - retracts? it's a gottahave.... Flaps - another gottado!
Keep us up to date to your progress.
Jerry
# 93 in Club Saito
(in reply to 10Acious1)
       Post #: 264
RE: TF Piper Arrow II kit - who's building it? - 3/10/2006 5:22:12 PM
10Acious1
Status: offline
I have orderthe retracts from robart as I agree it is a must, I have also ordered the fiberglass cabin and all of the other parts from fiberglass specialties, as Well as i am going with the flaps and A full light system. It will be a project for sure when I am done. I just need the time now LOL
       Post #: 265
RE: TF Piper Arrow II kit - who's building it? - 3/10/2006 6:26:40 PM
CL-415
Status: offline
Teamscale,
What hinge did you use for main gear door. You mention Aerotech, but can'tfind anything on them. Do you have a web site??
       Post #: 266
RE: TF Piper Arrow II kit - who's building it? - 3/10/2006 6:31:50 PM
teamscalepilot
Status: offline
If you can't find the Aerotech models.com hinges I would try the small klett hinges.
       Post #: 267
