Red Scholefield
FL, USA Status: offline
quote:
ORIGINAL: redbirdy quote:
ORIGINAL: Flying Geezer Actually, you'll never get a full charge at 70 mAh charge rate, but you can charge with the wall mole and use what capacity you get. There is more mis-information given given on battery care than about any other subject. Anyone mind explaining this? Why wouldn't a 70ma charger eventually charge a 1700 ma battery pack? Is the rate of natural discharge greater than what's being delivered after the battery reaches a certain threshold capacity? Does anyone know what the discharge rate for idle nimh packs are? Is it a certain percentage of what the capacity is? Is this rate of discharge independent or dependent on what the capacity of the battery is? Actually it probably would charge it eventually. The rule of thumb has been that the minimum charge to reliably recharge a pack is C/20, which for a 1700 mAh pack would be 85 mA. 70 mA is not that far off. For some reason people seem to think these rule of thumb numbers for batteries are sacred. They are not, but the further you get away from them the less chance of success. Another rule of thumb is that C/50 is required to maintain them at a full state of charge. Nature does not work with nice round numbers nor is it consistent all the time. Things like age, temperature, previous charge/discharge history come into play here. A number of things come to play in the charge scenario, not the least of which is the charge efficiency and the rate of self discharge. Self discharge can vary, again depending on a number of parameters from 1%/day to 5% or more and is not linear, meaning it loses more in earlier than later. Charge efficiency can also vary from battery to battery again with a number of parameters coming to play with efficiencies varying in the range of 70 to 95%. Then add in the fact that the actual capacity of the cell can vary as much as 20% and I think you can see that hard numbers just won't work. Stick as close as you can to the rule of thumb numbers and you will be much happier. Wander far off and things can start to deteriorate.
_____________________________
Red S. AMA 951 Leader Member
