Clean
Joined: 4/19/2002 From: Parkville, MO, USA Status: offline
www.rccombat.com is the RCCA homepage and the where you'd look for the rules on 2610. Basically, 1/12th scale WWII airplanes +/- 10% with 26 and under engines. JKAerotech makes some pretty good, easy flying, Easy building airplanes. If you have a 25FX do a Jug or build the TA-152. The Corsair is a cool airplane as well. You have a lot of wing and with enough power you can drag it around at a pretty respectible speed but all that wing makes it loop pretty tight. If you want to go fast, build one of their mustangs. Follow the building techniques and do your own airplanes the next time if you want with their techniques, you'll be pretty happy.
_____________________________
From Somewhere near Parkville, Mo. William Crane (aka Mr Clean) Rever Brother #168 Time Man of the Year
