ptxman
Joined: 7/31/2002 From: Calgary, AB, CANADA Status: offline
[QUOTE]Originally posted by Giant Scale ptxman, The wings look awesome. I need to core a wing in a similar manner but was not going to make the pattern that intricate. Would a simple triangular pattern work as well? Take a look at the tail section on this plane, I was going to core the wing with a similar pattern. Was it expensive to get the templates made? The wing panel I need to core is about 6ft long, I was going to make the templates out of formica or tempered masonite. [/QUOTE] I think a triangular pattern would work equally well, lots of pattern planes had this including sharp corners. I played with a lot of different geometries in cad came up with this because it best suited the application from a weight & strength compromise. There is little weight saved by honeycombing accross the ailerons & I like firm flying surfaces so that portion was omitted. I dont fly your big scale stuff, but my instinct would be to make the cells a bit smaller & make more of them. You will get more rigidity & remove about as much material, however, there are more cells to remove. I really think the continous remaining foam spar is a good feature. My templates cost roughly 200$C (125$U) for 2 wing, 2 stab, 1 rudder (all 1/16" 6061 aluminum) & and matching mdf panel templates used for blocking the foam (materials included). For reference this is a 2m span (78" 1100 in2 nominal area plug-in wing. I supplied the .dxf file. As mentioned before, prices seem to vary quite a bit so shop around. A wood based template like masonite will be cheaper in terms of material cost but the hotwiring cut quality will not be nearly as good. Formica would be better, metal is the best. I actually tried some laser cut 1/4" ply templates. They worked not bad for about 10 sets of wings & then the wire started to slowly burn little ticks here & there & start the hanging up process. If its just a one-off job for yourself, you may not care, my circumstances were different. You have to fillet all the cells in cad if you are exporting to a cnc router - the diameter of the bit will take care of that by default. The other thing I thought would work (but got talked out of) was first join both template materials together with spray adhesive, cnc cut both top/bot simultaneously to save some $ & then just carefully seperate them with acetone. The particular shop I used advised against it but I still think it would have worked. I should also mention there is a big strength difference by not having continuous sheeting over honeycombed panels, but thats a whole other discussion. Good luck!
