E sky 2 3D 4 in 1 receiver fried?anyone can help me?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mikado Logo XXTREME Combo - RTF
Seller:  Hegemonoius
Details:   $2,975.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> E sky 2 3D 4 in 1 receiver fried?anyone can help me?
Page: [1]
Login
E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 3:12 PM
Cossýe
Score: 100
Last Login: 3/20/2006
Status: offline
Dear all;
I've bought my Honeybee Esky 2 3D 2200mhA kit but I havent used a rc heli before this.I own a rc nitro car but unfortunately they aren' the same.....I like to learn from you how to use this ****???...I have a big problem now.My transmitter's everything was neutral and I guess 3D was open but dont remember well.I switch on TX then connected helis power pack and red light flashing then I do something which I don't know and some smoke came out of my main motor and also from the receiver box main motor is locked and smelled very bad.(is this happened because mode 1 mode 2 or 3D button or what? and what are those mode 1 mode 2,3d button)then with some tools I made the main motor work and it is working but from the 4 in 1 no electric comes to it and my main motor does not work now new 4 in 1 costs 80 USD to my country probably 100 $ as you now and I do not know what caused this,because of getting hot the tail rotors connection jack came outside of the 4 in 1 I have to re solder it .......servos worktail motor works but main motor doesnt get electric from receiver now and doesn't work....please help me..????
Hide Signatures
       Post #: 1
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 4:47 PM
bswole
Score: 100
Last Login: 11/30/2007
Status: offline
I had the same problem out of my piece of junk honeybee2. The transmitter smoked, and the reciever smoked. Then the main motor would get no power but everything else would work.
rcmachine on ebay is where I got it. They said send the transmitter and reciever back for replacement, but now they tell me someone tried to add a heatsink to the reciever, so the warrantee is void. I certainly didn't try to add any heatsink, and I don't know of any benefit of adding a heatsink to the reciever anyway. Basically, I think these HB2 helis are complete junk.
See my post titled "rcmachine: honeybee2 repair problems" for more detail.
If I were you, I'd try to send the board back for replacement. Hopefully the company you bought it from is reputable enough to not attempt to accuse you of adding a heatsink to the reciever.
Hide Signatures
(in reply to Cossýe)
       Post #: 2
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 7:54 PM
JeffElecRC
Score: 100
Last Login: 1/23/2009
Status: offline
Hi, Sorry to hear about your Honey-Bee problems. I haven't had any problem with mine. Sounds like the motor speed-controller FETS are burning out in your unit.
I dont want to be a ghoul, but if you replace these units, I was wondering if I could have the burnt-out units? I may be able to repair them, and if, as you say the only part that isnt working is the motor speed-control, it is still a good receiver.
Anyway, I'm willing to pay for shipping and whatever you may as for the burnt-out 4-in-1 boxes. Let me know, thanks.
Hide Signatures
(in reply to bswole)
       Post #: 3
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 8:58 PM
Cossýe
Score: 100
Status: offline
Thanks bswole for your answer I will search the topic you have written...
Hide Signatures
(in reply to JeffElecRC)
       Post #: 4
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:04 PM
Cossýe
Score: 100
Status: offline
Jeff you're not a ghoul but I'm in touch with the company I've bought from so I'm waiting for them to act...If I don't send the box to the factory I will get in touch with you thanks
Hide Signatures
       Post #: 5
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:12 PM
JeffElecRC
Score: 100
Status: offline
By the way, www.heli-fever.com sells 4-in-1s for $50 USD. They ship from China.
Hide Signatures
       Post #: 6
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:16 PM
Cossýe
Score: 100
Status: offline
Ok I will look at that site now thanks for help.......I tried to get the circuit board out of black plastic box but ı couldn't ıts like glued or something else to the box isn't it?
Hide Signatures
       Post #: 7
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:21 PM
JeffElecRC
Score: 100
Status: offline
Nope, no glue. Once you take the 2 covers off on either sides, the boards are mated to eachother on opposite side of a plastic divider with pins. If you look at the side with the 6-channel outputs, the channels 4 and 3 pins on the receiver are soldered to the opposite side of the receiver board, the mixer/gyro board has a matching socket. So you need to get a small slot-head screwdriver and gently pry up the board on the side with the channel outputs. The boards will then be seperate from the black case.
< Message edited by JeffElecRC -- 1/22/2005 9:35 PM >
Hide Signatures
       Post #: 8
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:25 PM
Cossýe
Score: 100
Status: offline
I m gonna try again now will see If I undestood true
Hide Signatures
       Post #: 9
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:33 PM
Cossýe
Score: 100
Status: offline
I have done it they re out thanks Jeff.....I will tell you what I see......think of the main motors 2 pins on the gyro board and back of the board there is a black line which is burned back side of theupper pin of the main motor when I scratched the burned area a metal surface is seen I will connect the battery now and try whats happening
Hide Signatures
       Post #: 10
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:43 PM
Cossýe
Score: 100
Status: offline
Oh god I plugged the main battery TX was switched on,"before I have unscrewed the main motor from the blades" raised the throttle a bit and made my metal little screwdriver as a bridge between two fried areas and motor worked I think I should soldier a little bit but if its a material mistake it will burn again ha?
Hide Signatures
       Post #: 11
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:45 PM
JeffElecRC
Score: 100
Status: offline
Give it a try, you probably can't really make things any worse.
Hide Signatures
       Post #: 12
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:50 PM
Cossýe
Score: 100
Status: offline
Yeah it's really true but my soldering machine doesn't work the cables and everything gets extremely hot when working is it normal?also the cables
Hide Signatures
       Post #: 13
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:51 PM
JeffElecRC
Score: 100
Status: offline
No, thats not normal for a soldering iron.
Hide Signatures
       Post #: 14
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 9:58 PM
Cossýe
Score: 100
Status: offline
No not the soldering gon gets hot the motor and the 4 in 1 cables I mean
Hide Signatures
       Post #: 15
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 10:00 PM
JeffElecRC
Score: 100
Status: offline
The motor, wires, and parts inside of the controller shoudl get hot eventually after 5-10 mins of flight...
Hide Signatures
       Post #: 16
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 10:10 PM
Cossýe
Score: 100
Status: offline
My battery pack is a white plastic covered and there is a paper glued on it and written chineese on the paper but two boxes marked with a pen they're 2200mah and 11,1V can this cause a problem like this because only main motor cable main motor and the battery main cables get extremely hot and they become softy that much hot think how it gets hot...may be my battery's voltage is not stable right?or something like a battery problem?
Hide Signatures
       Post #: 17
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 10:17 PM
Cossýe
Score: 100
Status: offline
oohh god ı plugged main motor cable to the tail motor's pins on the 4 in 1 box tail motors pins also fried and puffed...the pins solders melted and pins came out of their holes WHAT IS THE PROBLEM OF THIS ELECTRONIC **** I CAN'T UNDERSTAND
Hide Signatures
       Post #: 18
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 10:32 PM
JeffElecRC
Score: 100
Status: offline
Yikes! Check the voltage on your battery. I'm using 11.1 V 1000mah with success.
Hide Signatures
       Post #: 19
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 10:45 PM
Cossýe
Score: 100
Status: offline
I m gonna get new tools ı think cause my voltmeter is disappeared... thanks for your helps Jeff
Hide Signatures
       Post #: 20
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 11:02 PM
Cossýe
Score: 100
Status: offline
Jeff can the motor cause this like getting too much electric voltage or ampher from battery????
Hide Signatures
       Post #: 21
RE: E sky 2 3D 4 in 1 receiver fried?anyone can help me? - 1/22/2005 11:21 PM
JeffElecRC
Score: 100
Status: offline
Some basic principles of electronics:
If you have an 11.1 volt battery and connect it to a circuit designed for 11.1volts, it doesn't matter if the battery is the size of an ant or the size of a house, that circuit will draw the current it needs and is designed to draw. However that circuit will run for alot longer with the BIG battery because it has more capacity.
If you connect 13 volts to a circuit designed for 11.1 volts, the circuit will draw too much current and that excess current will be dissipated as heat.
So your 11.1 Volt 2200mah battery would only cause a problem if it was overcharged and providing say more than 12volts (I'm not sure about this, just guessing).
To answer your question: Yes. Too much voltage can smoke a motor.
< Message edited by JeffElecRC -- 1/22/2005 11:23 PM >
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.813RCU1
