Mix and match TX / RX?
Tower Hobbies
Logged in as Guest
  Printable Version
Megatech PF4000 4 Channel Aircraft Radio System
Seller:  Erick Royer
Details:   $65.00   |  7/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Mix and match TX / RX?
Page: [1]
Login
Mix and match TX / RX? - 9/4/2002 7:59:55 PM
golf_lake
Status: offline
Hi Mike I have just found this informative site and have read through a lot of the information posted and I see Hitec is totally committed to service.
I have just purchased a Sanwa Blazer as its features and price was right for me, I think after reading some of the posts here and the support Hitec gives to the hobbyist I may have made a mistake in selecting the Sanwa, I have not been able to find anything in support of this product on the net yet.
I am located in Australia and have a number of Hitec TX,s and receivers 29MHZ AM. I would like to ask you a couple of technical questions relating to these and the mix and match of different brands of receiver’s.
Now to my questions.
1 I have been told that you must use a different RX with a pistol grip type TX as they are different from stick types and not compatible. Is this correct?
2 I have a HP2RNB receiver and Hitec claim it is compatible with most AM TXs. What are the exceptions and is it compatible with the Sanwa Blazer.
3 Are these TX and RX sets factory tuned for upper and lower bands within there frequency, for example a unit manufactured for channel 12 is it tuned the same as a unit manufactured for channel 28 in the 29MHZ band.
4 These newer sets I understand are narrow band and the older types are not, I have a older Acoms AP-229 Mk111, would this be pushing thinks a bit far by using this older receiver with the newer narrow band TX.
5 Are you aware of a site that has information on Sanwa and Acoms
       Post #: 1
Mix and match TX / RX? - 9/11/2002 2:16:52 AM
MikeMayberry
Status: offline
Q1: Not correct. They use the same receiver.
Q2: You should be able to intermix the two however, I am not familiar with 29mhz. In 27mhz they are interchangable.
Q3: Hitec systems are center tuned and can accept any crystal. I don't know about the others.
Q4: I am not familiar with that unit. You may have problems with interferance it if is wide band.
Q5: Sorry no.
Good luck!
Mike.
(in reply to golf_lake)
       Post #: 2
Mix and match TX / RX? - 9/11/2002 11:52:22 AM
golf_lake
Status: offline
Thank you Mike, RE Q1. I could not understand why they would make 2 different receiver’s either but I was not prepared to ague with the Hobby shop or risk a model that travels at 50+ MPH to prove a piont.
The rest thanks for clarifying.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
