Sj 90 L - T
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Sj 90 L - T
Page: [1]
Login
Sj 90 L - T - 9/4/2002 11:25:45 PM
daven
Status: online
I have the engine on order for my corsair, and was wondering what prop would you recommend? And, what size fuel tank should I get for a comfortable 10-12 minutes of fly time?
_____________________________
Dave Norman
klasskote.com
supertrc.com
       Post #: 1
90LT prop - 9/5/2002 12:46:44 AM
bob27s
Status: offline
Hi Dave...
You may want to drop Dub or Dennis a note directly on this one just for conformation.
I believe you will also be running the Turbo-Jett muffler with this.
The 90T should run around 10 - 12K rpm with this set up. I would start out running an APC 13x6, and then work up to a 14x6 after the engine has run a bit.
At 11,000 rpm, you can expect about 1.25 ounce per minute at full throttle. I would expect that a 16oz tank should work pretty well to get you a solid 10 min.
I hope this is the info you are looking for.
Bob Brassell
(in reply to daven)
       Post #: 2
Sj 90 L - T - 9/5/2002 2:18:57 AM
daven
Status: online
Perfect.
Just what I wanted on the props, and yes I will be using a In-Cowl muffler with the engine.
I was hoping I could sneak by with a 14oz tank as it fits better with the battery up front, and I think I will need the extra nose weight. I think I will bench run it a few tanks to see if I can get away with 14oz.
Thanks,.
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 3
Sj 90 L - T - 9/5/2002 6:31:05 PM
bob27s
Status: offline
Any time Dave
I would imagine you could get away with 14 oz over 10 minutes without much of a problem, since you will likely not be running at full throttle all of the time.
But...then again... you are a pylon guy like me
(in reply to daven)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.285RCU1
