Sport_Pilot
GA, USA Status: online
Most 4-stroke engines have a maximum recommended ground RPM of 11,000 to 13,000 RPM. Note OS engines vary by that much. http://www.osengines.com/engines/surpass.html Unless you go into an extended dive at full power you shouldn't have any valve float problems if you keep static RPM below these numbers. Saito doesn't seem to have this spec listed on their site. Valve float doesn't automatically mean damage to the engine, though a cracked valve spring is possible. IMO the damage isn't expensive enough to unduly worry about it. As for as drinking fuel. More power = more fuel. The TT. 91 eats up more fuel than any non supercharged .91, and it has more power. But service is terrible! Next time I will go with another brand. The first four strokes were low on power, used less fuel, and limited to 10,000 RPM (sometimes less, I think the first OS was limited to 9,000 RPM).
