RE: Mystery Solved! How to select the proper gearing for your electric RC!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Mystery Solved! How to select the proper gearing for your electric RC!
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Mystery Solved! How to select the proper gearing fo... - 3/13/2005 7:41 PM
Speedmunkey
Score: 100
Last Login: 3/24/2006
Status: offline
Skrappy, I got your article and it looks very good. We need some pics or something to spice it up. Anyone got a few hundred spur gears lying around that they can snap a picture of? I have a grand total of 6 lol.. I do have like 20 pinions I could take a picture of..
I've got an idea, gimme 5 minutes..
_____________________________
Over the mountain, kissing silver inlaid clouds
Watching my body disappear into the crowd
Hide Signatures
(in reply to SkrapIron)
       Post #: 76
RE: Mystery Solved! How to select the proper gearing fo... - 3/13/2005 7:51 PM
Speedmunkey
Score: 100
Status: offline
And here we go.. Thing this illustrates which is which? We have to dumb it down so anyone can understand it. It would be nice to assume no one worried about gearing would be confused as to which gear was which, but you can never underestimate a newbie.. lol
And yes guys, I'm aware that I've butchered that Losi motor guard.. You should too
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Speedmunkey)
       Post #: 77
RE: Mystery Solved! How to select the proper gearing fo... - 3/13/2005 9:31 PM
jakjr
Score: 100
Last Login: 10/28/2009
Status: offline
quote:
ORIGINAL: Speedmunkey
Not spur gears, but pretty close
Click for fullsize
{o,o}
|)__)
Hide Signatures
       Post #: 78
RE: Mystery Solved! How to select the proper gearing fo... - 3/13/2005 9:46 PM
Speedmunkey
Score: 100
Status: offline
B.C. Rich has always made some strange looking critters. I'm more of a strat guy myself.
Click for fullsize
Hide Signatures
(in reply to jakjr)
       Post #: 79
RE: Mystery Solved! How to select the proper gearing fo... - 3/13/2005 10:53 PM
S.A.E.W.O.T.
Score: 100
Last Login: 8/19/2005
Status: offline
isa' 12.18 a good over all ratio?... like 12.18 turns of the motor turns the wheels once? 4 off roading? and i have a wheel and gear ratio of 3.2?.....what does that mean?
Hide Signatures
       Post #: 80
RE: Mystery Solved! How to select the proper gearing fo... - 3/13/2005 11:05 PM
jakjr
Score: 100
Status: offline
12.18 sounds about right for an ST, but it depends on the tires your running.
Nice
Ive always like gibsons (wish they werent so expensive ) but my grandpa likes strats (he has 3 of them).
(disregaurd the stuff in the background of this pic)
Click for fullsize
< Message edited by jakjr -- 3/13/2005 11:12 PM >
{o,o}
|)__)
Hide Signatures
(in reply to S.A.E.W.O.T.)
       Post #: 81
RE: Mystery Solved! How to select the proper gearing fo... - 3/13/2005 11:16 PM
Speedmunkey
Score: 100
Status: offline
Why disregard it? I've owned practically every item there at one point or another, cept for the MXR pedal.
Hide Signatures
(in reply to jakjr)
       Post #: 82
RE: Mystery Solved! How to select the proper gearing fo... - 3/14/2005 2:25 AM
C3Racing
Score: 100
Last Login: 10/4/2006
Status: offline
quote:
ORIGINAL: SkrapIron
The stock Evader gearing, for the photon is deliberately undergeared. It is done so to compensate for the lack of performance of the Photon motor. You will do better to tinker with the pinion gear to get a baseline. From there, you can fine tune it with a new spur gear.
Welcome to a bright new world!
Photon what !! i got rid of that 2 wks later.. i got a chameleon 2 pro and a reedy quad mag!!
Square peg in Round hole. It will fit, just get a bigger hammer.
Hide Signatures
       Post #: 83
RE: Mystery Solved! How to select the proper gearing fo... - 3/14/2005 2:53 AM
S.A.E.W.O.T.
Score: 100
Status: offline
yea my photon speed motor lasted about 2 weeks, then it jus startin' bein' dum! so i went out a got a mvp stock!
< Message edited by S.A.E.W.O.T. -- 3/14/2005 2:54 AM >
Hide Signatures
(in reply to C3Racing)
       Post #: 84
RE: Mystery Solved! How to select the proper gearing fo... - 3/14/2005 6:30 PM
savage_beast99
Score: 100
Last Login: 5/11/2005
Status: offline
you think thats bad try the stocker in a xxxt sport rtr 2, mine lasted 4 runs before a teeeennnnyyy pebble got into the motor and ripped apart several turns.
Hide Signatures
       Post #: 85
RE: Mystery Solved! How to select the proper gearing fo... - 3/14/2005 6:55 PM
savage_beast99
Score: 100
Status: offline
here is a question, i used the calc on the site, the stock setup for my xxxt comes out as 1.874!! did i do something wrong or did losi just overgear the snot out of the stock setup?
Hide Signatures
(in reply to savage_beast99)
       Post #: 86
RE: Mystery Solved! How to select the proper gearing fo... - 3/14/2005 9:17 PM
Speedmunkey
Score: 100
Status: offline
Probably overgeared it.. What's the numbers?
Hide Signatures
       Post #: 87
RE: Mystery Solved! How to select the proper gearing fo... - 3/15/2005 2:53 AM
mkranitz
Score: 111
Last Login: 11/18/2009
Status: offline
quote:
ORIGINAL: SkrapIron
I think I'm going to edit the article, and use your speed calculator verbatim. It's alot less convoluded than my explaination. Although we get the same results, yours is easier to understand.
Skrappy,
I hope the calculator is doing its job accurately. If not, let me know and I can change it.
Michael
The customer is always right but only if the customer is polite.
Hide Signatures
       Post #: 88
RE: Mystery Solved! How to select the proper gearing fo... - 3/15/2005 2:58 AM
Speedmunkey
Score: 100
Status: offline
Micheal, I checked a few different gearings yesterday and it was right on the money.
heheheh you called him Skrappy too lol! Now he needs a new avatar, something like this:
Hide Signatures
(in reply to mkranitz)
       Post #: 89
RE: Mystery Solved! How to select the proper gearing fo... - 3/15/2005 3:52 AM
jakjr
Score: 100
Status: offline
What would be neat is it had a pull down menu with tranny ratios for all the popular cars.
{o,o}
|)__)
Hide Signatures
       Post #: 90
RE: Mystery Solved! How to select the proper gearing fo... - 3/15/2005 6:09 AM
mkranitz
Score: 111
Status: offline
Speedo,
It just occurred to me that the Gear Ratios for a bunch of cars area already in our Product Guide. I'm adding a link to the GearWizard now.
mk
< Message edited by mkranitz -- 3/15/2005 6:15 AM >
Hide Signatures
       Post #: 91
RE: Mystery Solved! How to select the proper gearing f... - 3/15/2005 6:22 AM
mkranitz
Score: 111
Status: offline
Links to GearWizard are now in the "Community" button!
Hide Signatures
(in reply to pezz)
       Post #: 92
RE: Mystery Solved! How to select the proper gearing fo... - 3/15/2005 1:12 PM
Speedmunkey
Score: 100
Status: offline
Micheal, I looked at the product guide and I couldn't find the list. Got a direct link for it?
Hide Signatures
       Post #: 93
RE: Mystery Solved! How to select the proper gearing fo... - 3/15/2005 4:49 PM
S.A.E.W.O.T.
Score: 100
Status: offline
do u think u could make a gear calculator that kinda like this?
motor rpm: 40,000
pinion size: 19
spur size: 87
transmission ratio: 2.66
tires size (mm): 124
top speed = 37.4 mph
roll out = 12 mm
that would be kool so like u kinda have a base line 2 see how fast ur car is goin! it won't be 100% acrurate but jus 2 give u an idea!?
Hide Signatures
       Post #: 94
RE: Mystery Solved! How to select the proper gearing f... - 3/16/2005 6:42 PM
changss
Score: 100
Last Login: 4/27/2008
Status: offline
w00t!! thanks skrapiron and everyone's contribution to this! I've been struggling with this scary gear ratio for a long time, searching for information on the web, but still don't know what gear ratio should I use with different motors. now i've a rough idea of what should I do can wait to fine tune my TRF415 with my 9T motor...
Hide Signatures
(in reply to pezz)
       Post #: 95
RE: Mystery Solved! How to select the proper gearing fo... - 3/16/2005 6:54 PM
Speedmunkey
Score: 100
Status: offline
changss, use Skrap's forumla to get in the ballpark, then fine tune it by feeling of the motor after a few laps.. You should be able to hold your finger on the can for 5 seconds without having to pull away. If it's that cool, you are golden. If it's hotter, you need to drop a tooth and try again. Don't forget to check it, cuz a hot mod like a 9t can go south REALLY fast from the heat.
Hide Signatures
(in reply to changss)
       Post #: 96
RE: Mystery Solved! How to select the proper gearing fo... - 3/20/2005 11:00 PM
changss
Score: 100
Status: offline
woooooo~~ yes you are right, just tried it out today, and the motor got soooooo hot (burning!! ) after a few mintues... well, i put on a pinion with "some extra teeth"... I guess I should start from the recommanded solution =P
Hide Signatures
       Post #: 97
RE: Mystery Solved! How to select the proper gearing fo... - 3/21/2005 3:31 AM
SkrapIron
Score: 100
Status: offline
That's the Idea. Use the formula as a BASELINE. Then, you can fine tune your performacnce, up or down, depending on the conditions that you are running under.
Enjoy!
If I can't be a role model, at least I can be a warning!
Hide Signatures
       Post #: 98
RE: Mystery Solved! How to select the proper gearing fo... - 3/22/2005 12:05 AM
twostep
Score: 100
Last Login: 10/14/2009
Status: offline
OK. This formula seems very well put together and useful.
My question is........
How do i apply this to what type of motor im running. If i want my number to be as close to 0 as possible, what makes gearing my 10turn different from gearing my 27turn???
I Hope i explained my question properly.
Hide Signatures
       Post #: 99
RE: Mystery Solved! How to select the proper gearing fo... - 3/22/2005 2:34 AM
SkrapIron
Score: 100
Status: offline
It does not matter what motor you select. Follow the gearing selector. The speed of your truck/buggy is determined by the RPM of the motor, not the gearing selected. If you over-gear, even a low turn motor, you may gain a few mph more, but increase the risk of damage to your motor, esc and battery. The Formula is INDEPENDENT of the motors number of turns.
Hide Signatures
(in reply to twostep)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.344RCU1
