jaejw1
Score: 100 Joined: 2/9/2005 Last Login: 11/20/2009 From: dana point,
CA, USA Status: offline
forgive me for not reading ALL of the posts on this thread,, just way too long,, but i did read the first several posts,,, my question /discovery is this,, while playing with my rc18t mini stadium truck with the mamba 8000kv motor inside,, i had it geared 60/12 (5:1)with an internal gearing of 2.5:1,,, the car ran really fast,, very fast infact,,, played with it with 6cells,7 cells, 8 cells and also 10 cells,, all of which were much faster than the previous,, my mamba then died,, and i replaced it with a new motor,, now i have 55/11 gearing again 5:1 the same as 60/12 BUT,,, this current gearing set up is much faster than the previous 60/12,,,, eventhough both have the same ratio,,, they do not share the same speed,, maybe im dreaming but i have tried to get this answered because i would like to make my xcellerator faster than it is now but in using the same ratio or close to it,, xcellerator is currently 90/18 (5:1) with an internal of 2.6:1... i was thinking of doing 87/17 which gives almost the same ratio,, of 5.117:1 question,,, will using smaller gears,, both pinion and spur make the car faster if the ratio is the same as stock,, or what the current usage is,, it worked for my rc18t can it work for my 1/0th stadium truck,,, my guess was that it was less rotatig mass on both ends,, allowing the motor to spin with ease.. thanks,, and again sorry for not reading the entire thread and if this has been answered before please let me know,, ......
_____________________________
motor review http://www.rcuniverse.com/forum/fb.asp?m=7472571 tire review www.rcuniverse.com/forum/m_6000527/tm.htm
Hide Signatures
