jaejw1
Score: 100 Joined: 2/9/2005 Last Login: 11/20/2009 From: dana point,
CA, USA Status: offline
i dont understand why you guys just dont use a smaller spur gear,, and start from there,, find out what the stock ratio is,, and the smallest spur you can use,, use it,, and then use gearing around the original ratio,, ... the only thing is that,, there is less mass to turn,, look at it this way.. ratio 5:1 180/36 120/24 110/22 100/20 90/18 80/16 75/15 70/14 looking at this,, you tell me which gearing would be faster,, and give more torque... .. if you look carfeully,, they all have the same ratio,, but as the gears get smaller,, the speed and torque go up.. and you can use the smallest with a 48pitch,, i use 48p in my rc18t and my gearing is 51/10 it was 55/11... and my micro rs4 is 58/26... ... .. like i said find the smallest spur that will fit your ride,, and go with the same stock ratio,, and start from there,, and only change the pinion,, one i takes less time and effort,, and while at the track time is everything.. .. so take my car for example,,, stock gearing is 87/18 which is a ratio of 4.833:1.. the smallest spur i can use is 78t.. and keeping the same ratio i would go with a 16t pinion,,,, and from there i could go up or down,, .. but i currently run a 81 spur,,, and i have geared it to 81/20 and im loving it,, cant see using a 93/23 gearing,, just too much metal and plastic to spin.. this is my take on things,, and i may be wrong,, but it is working for me...
_____________________________
motor review http://www.rcuniverse.com/forum/fb.asp?m=7472571 tire review www.rcuniverse.com/forum/m_6000527/tm.htm
Hide Signatures
