RE: Large scale pictures!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: Large scale pictures!!!!
Page: <<   < prev  8 9 10 11 12 13 14 15 16 [17]
Login
RE: Large scale pictures!!!! - 1/11/2007 4:34:03 AM
mikec456
Status: offline
Thanks they have a 29cc for $89.00 which should be ok for me since I only run it a few times a year. Plus I'm going to buy the Jet Pro pipe. I just replaced the stock wheels and tires with Pro line Moab 40's and Weld wheel aluminum bead lock rims but am still waiting on the 23mm adapters from crazynut racing. Has anyone tried the 29cc upgrade with the crankshaft?
(in reply to TheFgMan01)
       Post #: 401
RE: Large scale pictures!!!! - 1/11/2007 4:36:09 AM
IONIC-M
Status: offline
Teamchrome I dont have a part # right now for the shock pistions. I got them from hobbyteck. Call Troy at Largescale. He should be able to get them for you. FG makes them. I am using 7000 weight oil with them and no they dont seem to leak as much. They work very smooth!!
(in reply to teamchrome)
       Post #: 402
RE: Large scale pictures!!!! - 1/12/2007 2:08:37 AM
swatlien
Status: offline
Changed from white to black.... the black is all about business!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to mikec456)
       Post #: 403
RE: Large scale pictures!!!! - 1/12/2007 4:27:57 AM
kwakr
Status: offline
Me and a frien went out today to a dirt bike/atv hill.....had some fun
Now for the clean-up
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to swatlien)
       Post #: 404
RE: Large scale pictures!!!! - 1/22/2007 11:51:31 PM
irenaslavo
Status: offline
Caad5, I'm preparing car almost like yours, I took your picture as reference for my installation, I have problem with servos for hydraulic breaks, I install them exactly like your but when I made test both are working well but with opposite direction i.e the front break work the rear released, the front break work the rear break released , I'm using Y cable to connect both break servos , would you please tell me how you manage to let both working
quote:
ORIGINAL: caad5
Fitted with the following FG Components:
Alloy Front Upper Wishbones
Alloy Front Lower Wishbones
Alloy Front Uprights
Alloy Front Shock Tower
Alloy Servo Saver
Alloy Gear Plate
Alloy Gear Carrier
Alloy Engine Mounts
Alloy Diff Mounts
Alloy Rear Upper Wishbones
Alloy Rear Lower Wishbones
Alloy Rear Lengthening Set
Alloy Rear Uprights
Alloy Rear Shock Tower
Alloy Rear Spring Deflection Limitation Set
Alloy Ball Joints
Viscous Diff with extra 6 Fins - 12 Fins Total
Ball Drives
Wheelie Bar
MT Front Bumper Bar with Lights
MT Shell - Fully Painted
MT Roll Bar with Lights
Zenoah 26cc with Porting, Lightened Piston,Sealed Crank and Heat Shield approx 6+HP
Steel Pinion
Chrome Tuned Pipe
K&N Filter Set and Alloy Adaptor Plate
Front Magura Hydraulic Brakes
Rear Magura Hydraulic Brakes
Tank Ventilation Kit
Tank Foam
Special Fuel Filter (stops formation of bubbles)
(in reply to caad5)
       Post #: 405
RE: Large scale pictures!!!! - 1/23/2007 12:58:06 AM
Ironpede
Status: offline
Wow that is beautiful... almost makes me want a gas powered!
(in reply to irenaslavo)
       Post #: 406
RE: Large scale pictures!!!! - 1/23/2007 1:11:23 AM
caad5
Status: offline
quote:
ORIGINAL: irenaslavo
IrenaSlavo i used a 3 channel radio/receiver and plugged the throttle/rear brake servo into one channel and the front brake servo into another channel. Then I used channel mixing to set it up with a 60% front and 40% rear brake bias. I also set it up so when i throttle/accelerate, the front brake servo does not move because it does not have to go back like the throttle/rear brake one does. I did not use a Y cable.
< Message edited by caad5 -- 1/23/2007 1:12:44 AM >
       Post #: 407
RE: Large scale pictures!!!! - 1/7/2008 10:22:44 PM
blackrain
Status: offline
man these pictures are sweet
_____________________________
mugen mbx5t hott mod nova 528, , Cen nemesis picco 28, lst2 hott mod nova 528, hyper 8 buggy rb s5, hpi baja ss
(in reply to fourwheeler)
       Post #: 408
RE: Large scale pictures!!!! - 1/8/2008 8:56:36 PM
waqr
Status: offline
Here is my brand new FG MT Hummer:
       Post #: 409
RE: Large scale pictures!!!! - 1/8/2008 10:19:21 PM
dwayneh
Status: offline
Nice Hummer, but the MT above is just plain drool worthy. I'd spend all day just staring at it.
(in reply to waqr)
       Post #: 410
RE: Large scale pictures!!!! - 1/9/2008 3:12:47 PM
Dave ESPI
Status: online
caad5 , I hope to see a pic of your Blue FGMT blingbling showing up in the "not so pritty" thread sometime covered in mud or other sort of debris.........
Here is my "pre-muddified" baja SS
I think it turned out really nice.
And since we always LOVE to see the bottom of our cars aswell.... I applied stickers and them I put clear coat heavy packing tape over the chassis to protect it a bit.
And of course I have to sign my art aswell
Still a few sponsors and parts missing..... will be added soon.
LOOK ! FREE ADVERTIZING !
< Message edited by Dave ESPI -- 1/9/2008 3:24:13 PM >
HIROBO SRB QUARK = Heli of the year. Seriously; if you hate always fixing your helicopters, you will LOVE this one !
(in reply to dwayneh)
       Post #: 411
RE: Large scale pictures!!!! - 1/10/2008 12:23:22 AM
dwayneh
Status: offline
I really like the reversed flame pattern. Quite unique.
(in reply to Dave ESPI)
       Post #: 412
RE: Large scale pictures!!!! - 11/15/2008 9:40:29 AM
Mudgy
Status: offline
Dave, where are the scratches????
Looking shelf queenish, I would have to say........speaking of which, here is my chainsaw powered rail.
I may be up to third scale these days, as the wheelie bar now makes the damn car 8' long (used to be only - "ONLY" - 7' long)
getting the wing+wing frame sorted this weekend (hopefully)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 413
RE: Large scale pictures!!!! - 11/15/2008 3:15:51 PM
victory-rc
Status: online
My baja charging up with my carbon fiber body,and 2 photos of it with a desert rat body with a custom color of black sand pearl,it flipflops colors purple/blue/orange,and green.
WWW.VICTORY-RC.COM
(in reply to Mudgy)
