irenaslavo
Joined: 12/13/2005 From: monterial, QC, CANADA Status: offline
Caad5, I'm preparing car almost like yours, I took your picture as reference for my installation, I have problem with servos for hydraulic breaks, I install them exactly like your but when I made test both are working well but with opposite direction i.e the front break work the rear released, the front break work the rear break released , I'm using Y cable to connect both break servos , would you please tell me how you manage to let both working quote:
ORIGINAL: caad5 Fitted with the following FG Components: Alloy Front Upper Wishbones Alloy Front Lower Wishbones Alloy Front Uprights Alloy Front Shock Tower Alloy Servo Saver Alloy Gear Plate Alloy Gear Carrier Alloy Engine Mounts Alloy Diff Mounts Alloy Rear Upper Wishbones Alloy Rear Lower Wishbones Alloy Rear Lengthening Set Alloy Rear Uprights Alloy Rear Shock Tower Alloy Rear Spring Deflection Limitation Set Alloy Ball Joints Viscous Diff with extra 6 Fins - 12 Fins Total Ball Drives Wheelie Bar MT Front Bumper Bar with Lights MT Shell - Fully Painted MT Roll Bar with Lights Zenoah 26cc with Porting, Lightened Piston,Sealed Crank and Heat Shield approx 6+HP Steel Pinion Chrome Tuned Pipe K&N Filter Set and Alloy Adaptor Plate Front Magura Hydraulic Brakes Rear Magura Hydraulic Brakes Tank Ventilation Kit Tank Foam Special Fuel Filter (stops formation of bubbles)
