RE: Accel Katana GS70 Assembly thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Katana GS 70 ARF
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Accel Katana GS70 Assembly thread
    Page: <<   < prev  1 2 3 4 5 6 7 [8] 9 10   next >   >>
    Login
    RE: Accel Katana GS70 Assembly thread - 8/18/2005 9:14 PM
    Bill Killillay
    Score: 100
    Last Login: 12/13/2008
    Status: offline
    quote:
    ORIGINAL: dougwill
    Thanks! Bill K.
    Wondered if there was life out there. Ditto on the wanting to correct weak fusealage beforhand. Have you flown the one you got yet?
    Doug W.
    Nope, I stripped the covering back, have re-enforced the sided, and have not gone any further yet as time has not allowed. I hope to cover it back up and finish the assembly this weekend. I still have to order some servos too so it will be a couple of weeks. I went over the fuse pretty careful and I did not notice any of the stuff that most people hammered on this plane for... I beefed it up anyway though.
    BK
    _____________________________
    Bill K.
    Hide Signatures
    (in reply to dougwill)
           Post #: 176
    RE: Accel Katana GS70 Assembly thread - 8/22/2005 8:51 PM
    hooverin howie
    Score: 100
    Last Login: 11/12/2007
    Status: offline
    I bought an Accel Hobby Katana 70 from "accelfly" off of eBay. Said that the fuselage was not glued properly at the factory. I did the suggestions that they had given and my right wing broke off in mid flite. Lost the wing and a good servo but found the other parts. The wing joiner was terribly insufficient for the wing. It was just a piece of 1" x 1/8" light ply. I know I will never buy another one of these planes.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Hide Signatures
    (in reply to Bill Killillay)
           Post #: 177
    RE: Accel Katana GS70 Assembly thread - 8/22/2005 9:13 PM
    VanWidick
    Score: 100
    Last Login: 10/16/2012
    Status: offline
    My brother has had the same problem.
    I have the GS 40 version and have never had a problem with it at all and thats one of the main reasons I got the 40 size.
    Sorry to hear that has happened to you, your not the only one.
    Here is some video of the GS40 hovering it on the deck.
    Katana GS40 Video
    Enjoy it.
    Van
    < Message edited by depfife -- 8/23/2005 2:20 AM >
    Hide Signatures
    (in reply to hooverin howie)
           Post #: 178
    RE: Accel Katana GS70 Assembly thread - 8/22/2005 11:53 PM
    Bill Killillay
    Score: 100
    Status: offline
    quote:
    ORIGINAL: hddunbar
    My 70 is a once piece wing. Was your's also? That's kind of scary... I hope mine don't do that. Where you doing something harsh when it happened?
    Bill K.
    Hide Signatures
           Post #: 179
    RE: Accel Katana GS70 Assembly thread - 8/23/2005 12:21 AM
    hooverin howie
    Score: 100
    Status: offline
    I was in a nice easy bank turn , not my usual yank & bank. Just lining up to the field for a landing and the wing just exploded. It was a sad sight. I bought it on eBay from accerlfly and I think that he and Accel Hobby's are the same person. I usually just fly, or I should say practice to hover with the Katana 70 and I had just finished that and was coming around to end of the field to land. Had maybe 1/3 throttle and boom in the turn.... I loved how it hovered and being inexpensive a great one to practice with. I will probably buy another one but open it up and put in a good ply wing joiner. Good luck with yours.
    Hide Signatures
           Post #: 180
    RE: Accel Katana GS70 Assembly thread - 8/23/2005 1:18 AM
    Mr Golfer
    Score: 100
    Last Login: 1/13/2013
    Status: offline
    WELL I HAD THE SAME KIND OF PROBLEM ON MY GS70. I WAS HOOVERING IT, CAME OUT OF THE HOOVER STRAIGHT UP PUT A SLOW ROLL ON IT AND ( BAAAAAAAMMMMMMMMM) THERE WENT HALF OF THE WING. COURSE U CAN GUESS WHAT HAPPENED NEXT, DESTROYED MY STAIO MOTOR (DAM). CALLED ACCEL UP AND EXPLAINED TO THEM WHAT HAPPEN AND THEY SAID THEY HAVE NEVER HEARD OF THAT BEFORE. THEY GAVE ME A DISCOUNT ON ANOTHER ONE AND I AM STILL FLYING IT AND IT IS DOIN GREAT SO FAR ( KNOCK ON WOOD)
    Hide Signatures
           Post #: 181
    RE: Accel Katana GS70 Assembly thread - 8/23/2005 3:20 PM
    mwm341
    Score: 100
    Last Login: 4/8/2012
    Status: offline
    I got a GS70, also via accelfly on eBay. Taking the advice I've seen here, I've just finished CA'ing everything I can get at around the wing mount.
    As for the wing: I worked through the servo hatch, using milled fiberglass and thin CA to beef up the main spar/wing joiner on both right and left sides, and CA'ed the center section that I removed the MonoKote from. I'm going to take this further - CA'ing all inside corners and around all the holes in the fuse.
    Do people think this might be enough? Or are there more and/or better ideas out there?
    Hide Signatures
    (in reply to VanWidick)
           Post #: 182
    RE: Accel Katana GS70 Assembly thread - 8/23/2005 9:51 PM
    hooverin howie
    Score: 100
    Status: offline
    I will get another one and remove all the covering! I like to cover, Ha Ha. But as I stated before the add on eBay said nothing of a problem in the wing gluing process and said it was a poor job of glue in the fuse. I bought another one and like I said I will remove all covering and make sure the same thing doesn't happen again.
    Hide Signatures
    (in reply to mwm341)
           Post #: 183
    RE: Accel Katana GS70 Assembly thread - 8/23/2005 9:59 PM
    Bill Killillay
    Score: 100
    Status: offline
    quote:
    ORIGINAL: hddunbar
    I'm wondering if I should strip the covering on the wing on mine now or chance it. Oh and the guy selling them on eBay is no longer registered. Not sure what happened, but he's gone. I manged to get to planes at a steal of a deal, but he's gone now.
    Bill K.
    Hide Signatures
           Post #: 184
    RE: Accel Katana GS70 Assembly thread - 8/25/2005 8:33 PM
    hooverin howie
    Score: 100
    Status: offline
    His name is Winnie Wang and email is accelfly@gmail.com and he is working with me on getting me a replacement plane far the S/H & $15.00 extra so I guess I'm going through with it. I loved the plane when it was flying. A Satio 100 and 15"x4W prop and hang all day long. Got to love it. I will however strip covering and reinforce the wings center and put in some spruce spares instead of the balsa spares. It went bang so fast I thought I had a mid air but I was the only plane up.
    Hide Signatures
           Post #: 185
    RE: Accel Katana GS70 Assembly thread - 9/23/2005 6:33 PM
    RCBOZO
    Score: 100
    Last Login: 12/2/2009
    Status: offline
    I have seen more Kat 70's on eBay. I was wondering if anyone else was having problems with the wing's exploding? My pocket book would appreciate the price of the ones on eBay. There has to be something bad wrong for them to just let them go for over $100 off of retail!
    It''s never too late to have a Happy Childhood!
    AMA# 763492 -IMAA# 40348 www.thistledownflyers.com
    Hide Signatures
           Post #: 186
    RE: Accel Katana GS70 Assembly thread - 9/26/2005 6:29 AM
    krayzc-RCU
    Score: 104
    Last Login: 5/22/2013
    Status: offline
    i got 2 planes off ebay from the new name or new supplier (lol) nsupply. i have the pitts and the katana; 65 for the katana and 54 for the pitts. I have not cut the kits open and don't plan to so if there is a problem i will have the exploding basla....bummer
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    smooth as silk!
    Hide Signatures
    (in reply to RCBOZO)
           Post #: 187
    RE: Accel Katana GS70 Assembly thread - 10/2/2005 8:15 PM
    RCBOZO
    Score: 100
    Status: offline
    I went ahead and got the Katana 70! I have a Saito 100 for it. I bought mine off eBay from nsupply and I was going today to leave feedback and they are No longer a registered user!!!! I guess I will not be getting any good feedback from them now!
    Anyway If it breaks, I just hope at least I get a couple of months out of it before then.
    Hide Signatures
    (in reply to krayzc-RCU)
           Post #: 188
    RE: Accel Katana GS70 Assembly thread - 10/2/2005 9:58 PM
    jhondeen
    Score: 100
    Last Login: 10/18/2005
    Status: offline
    Does anyone heard about the TMPRO Kat V2 70 ? It seems like someone did some thinking designing
    the 2 piece removable wing, is it?
    I am on waiting anyhow...
    Hide Signatures
           Post #: 189
    RE: Accel Katana GS70 Assembly thread - 10/23/2005 2:30 AM
    Zman39
    Score: 100
    Last Login: 9/15/2012
    Status: offline
    Flew my kay70 from ebay last weekend and this weekend. I really like this plane. Has a Saito 1.00. plenty of power. Here is a pic
    Click for fullsize
    Hide Signatures
    (in reply to jhondeen)
           Post #: 190
    RE: Accel Katana GS70 Assembly thread - 10/28/2005 11:23 PM
    markktm
    Score: 100
    Last Login: 3/10/2007
    Status: offline
    Their back........ Nsupply is back on E-Bay. Same planes, prices look about the same but the discription is a little diferent.
    Hide Signatures
    (in reply to Zman39)
           Post #: 191
    RE: Accel Katana GS70 Assembly thread - 11/1/2005 4:02 AM
    eagledancer
    Score: 110
    Status: offline
    well guys i bit the ebay bullet and bought one too. this one says prob with fuse so i will be stripping the covering back and i am thinking of sheeting the sides with some 1/64 ply. or do you guys think this is overkill? guess i will mod the wing some i really dont want to loose a wing panel
    I once had a drinking problem.....I divorced it, now shes someone else''s problem
    waco brotherhood # 140
    Hide Signatures
    (in reply to markktm)
           Post #: 192
    RE: Accel Katana GS70 Assembly thread - 11/1/2005 5:28 AM
    rclement
    Score: 100
    Last Login: 4/3/2012
    Status: offline
    Hey guys, I got one of the Katana 40s from Nsupply and noticed that the right side of the fuse was debonding a little bit. Not complaining just mentioning it. Anyway I reglued the disbonded parts and it flies like a bandit. One of the instructors at the field flew it this weekend and really wrung it out. Still flies awesome.........
    The hardest part of this hobby?......waiting for the UPS truck.
    Hide Signatures
    (in reply to eagledancer)
           Post #: 193
    RE: Accel Katana GS70 Assembly thread - 11/1/2005 5:59 AM
    krayzc-RCU
    Score: 104
    Status: offline
    i have been busy & have not had a chance to get to mine but one of these days i will be on the deal
    smooth as silk!
    Hide Signatures
    (in reply to rclement)
           Post #: 194
    RE: Accel Katana GS70 Assembly thread - 11/1/2005 9:19 AM
    awat65
    Score: 105
    Last Login: 2/25/2013
    Status: offline
    Be careful about this guy nsupply. He charged my credit card for a profile plane I won from him on Ebay. He never shipped the plane and kept telling me to wait. I waited 6 weeks and no plane. I contacted my credit card company and got the charge reversed. It sounds like most of his dealings he shipped, but I was not one of those.
    Hide Signatures
           Post #: 195
    RE: Accel Katana GS70 Assembly thread - 11/2/2005 3:29 AM
    krayzc-RCU
    Score: 104
    Status: offline
    nsupply shipped mine right away back in the day
    smooth as silk!
    Hide Signatures
    (in reply to awat65)
           Post #: 196
    RE: Accel Katana GS70 Assembly thread - 11/5/2005 1:58 AM
    wahoo
    Score: 147
    Last Login: 5/23/2013
    Status: offline
    I bought the Kat 70 from Ebay (Nsupply) and he shipped it immediately. But all this talk about fuse and wing trouble has me a little concerned. Its not worth risking the engine and electronics if theres a known problem. I'm not much of a gambler to assemble it and take my chances. Nor do i enjoy re-engineering an ARF. Its all i can do to get an ARF ready to fly let alone stripping covering and reinforcing things. What to do what to do ??
    John
    When ever I feel like expressing my own opinion... I just ask an RCU moderator. Better safe than sorry I always say.
    Hide Signatures
           Post #: 197
    RE: Accel Katana GS70 Assembly thread - 11/5/2005 2:11 AM
    Dewey2
    Score: 100
    Status: offline
    quote:
    ORIGINAL: wahoo
    John
    Sell it to me for cheap
    Hide Signatures
    (in reply to wahoo)
           Post #: 198
    RE: Accel Katana GS70 Assembly thread - 11/5/2005 2:35 AM
    wahoo
    Score: 147
    Status: offline
    What would be ideal is if i could find someone that would build this thing for me cheap, with me paying them for the service along with shipping both ways.
    John
    Hide Signatures
    (in reply to Dewey2)
           Post #: 199
    RE: Accel Katana GS70 Assembly thread - 11/5/2005 2:59 AM
    Dewey2
    Score: 100
    Status: offline
    Well if you haven't found anybody by next Thursday, and have a box it will fit in after its built drop me a pm.
    Hide Signatures
    (in reply to wahoo)
           Post #: 200
    Katana GS 70 ARF
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.953RCU1
