martyg
TX, USA Status: offline
It's super easy on this airplane, as the thrust line and wing/stab incidences are all 0-degrees. In post 35 above, I transferred the motor thrust line from the plans to the fuselage. The procedure is to jig the airplane to the workbench, so it doesn't move around. Tilt the fuselage fore/aft until this line is level. Use a regular spirit level to measure. Then use the incidence meter on the wings, and make sure both of them read zero. Try different places along the spans to check for wash-in/out. (You want zero everywhere) If you see a degree or more off from this, something will need to be adjusted. If you can keep all measurements within +/- 1/4 to 1/2 degree, you are ready to rock 'n roll. Same procedure for the horizontal stab. Some meters come with prop shaft adapters, so you can measure the motor alignment too. Don't get too obsessive with this tool! A good eyeballing will get you close, an should be done anyway as a reality check. But like I said earlier, its good to be able to measure accurately to make sure.
_____________________________
-- Marty
