OperaGhost
MT, USA Status: offline
chronus, dont take my comments personally-i am sorry you had a bad experience with walkera (hobbyjapan2000 most of all). I also have, and seek to make my experiences both positive and negative available to all. a note regarding setting the motors up, this should be done with any direct drive system, btw... the walkeras at least seem to come set very 'tight'. i did what the instructions say, tho (and chronus will love this...) you are lucky if you get instructions in english... 1st, loosen the tail rotor mount. move it back, away from the motor EVER SO SLIGHTLY!!!! you dont even need to see it move back. just take a lil bit of tension out between the gear teeth and the tail boom gear. Retighten. Next, loosen the motor up, it should shift. again, it should shift only slightly. retighten. Some say you should also do the tail boom itself, i have not found it necessary. The goal is to get the gears to mesh, without burying the teeth into the valley of the next gear. Just loosen it up a bit. I did this with my 35 before running it first time, and a friend of mine did not. the difference is amazing. his would spool down in 2-3 seconds, whereas mine would take 10 or so seconds to spool down. we adjusted his, and its now the same way. now, a question for you guys...i have a bad servo 'twitch' on my 35, it stops when the xmitter is turned off. it doesnt seem to affect it when its flying, as in, if there is input, it stabilizes. but sitting on the ground 2 of my servos twitch to no end. i dont know if this is due to interference, although i doubt it. The same friend has no problems like this with his 35. again, it doesnt seem to matter when there is control input-but i cant think of this 'twitch' as a good thing! any ideas? again, let me restate my opinion as to walkera products. the product is fine, just needs tweaking as do any of these helis. the problem is the distributor (HJ2000). and chronus, all of our boxes say HELICOPTER, not PLANE, lol. j/k keep the opinions coming guys-lets just keep them constructive.
