XJet
Joined: 3/31/2003 From: Tokoroa, NEW ZEALAND Status: offline
RaceCity has nailed it. Alcohol (methanol) requires heat to vaporize and in winter, there's far less heat around :-) You might have noticed (if you live in a humid area) that when you run your Saito in summer, you get condensation forming on the intake tube. This is because the vaporization of the methanol as it travels up the intake tube is sucking the heat out of that metal -- so it gets cold. So cold in fact, that the moisture in the air condenses on it. It is this vaporization-induced lowering of temperature that causes carburetor icing in aircraft and which requires them to have manifold heating when operated in certain conditions. If there's insufficient heat around then very little of the methanol will actually vaporize before it hits the combustion chamber. This is important because, believe it or not, liquids do not burn (combust). Only the vapors released by liquids burn and in order to release those vapors, the liquid has to be at or above a certain temperature. This is why you can drop a lighted match into a bucket of kerosene (Jet A1) and all it does is go out -- there's no bang, no ignition, nothing. At ambient temperatures, a puddle of Jet A1 doesn't release sufficient vapor to support combustion. In fact, to get it to burn, Jet A1 has to be broken up into tiny droplets (with lots of surface area) and/or heated. So, to get your engine started and keep it running, you have to either use some other fuel component that *will* vaporize at the prevailing ambient temperature, or ensure that your engine is warm enough to allow the methanol to vaporize. One solution (as pointed out by others) is to add small amounts of a more volatile liquid such as acetone or lighter-fluid. Another (as others have pointed out) is to pre-heat your engine using hot water. Looking on the bright side, your engine should produce more power when fed with tje colder, denser air of winter :-)
_____________________________
When I'm not here, I'm at RCModelReviews
