nexxa
QC, CANADA Status: offline
No, it's not a flat piece of carbon. It's a Rod 1/8" (round). I install these 2 rods to add stiffness to the stab. When it’s done, no worry to break in half the elevator if you’re pulling the elevator to the max in a big dive. It will stand the force. But if you reinforce the stab, it will break at another weak point. Yes you can laminate both side of elevator and screw your control horn on it. Just remove the covering, place your CA hinge and put thin CA. Like the Diamond dust. Me I use 1/16 plywood both side, maybe 1 1/2" by 3/4". All these mods are not required if you fly your corsair gently, with a .15 or .25. Mine was equipped first with an OS.25, in second with an OS.32SX with full tune pipe. Always full throttle, always pulling hard on the elevator for High G turn, high speed pass.... a lot of stress. Mine broke in half after only three flights, and the engine was still in broke in process! The second one, the control horn was still screw to the elevator section, but this section was no more part of the elevator!!! The elevator fails where the control horn was screw. For the rudder on the corsair, there are no worries about the weight if you're using a micro servo. Use the extra rod provide in the kit. The Corsair is light and the wing loading is low. The extra weigh will not affect its flight characteristic. On mine, I put front and rear wheels. Maybe ± 8 oz of extra weight. With the OS.25 it take off in only 20 feet (APC 10X3 or 10X4) and the landing was very easy. If you have the patience to do the mod, go for it. On landing, with a small crosswind, the rudder is very helpful. Are just to put the plane on a small knife edge when making a low pass, it worth the work! I will check tonigh if I could find some pictures...
