nexxa
QC, CANADA Status: offline
All the mods discuss about in this tread was on my first one. First I flew it stock, after 3 or 4 flights I lost one ailerons and half of the elevator in the air. During the winter I decide to revise all, dual ailerons servos, bigger rod for elevator, carbon.... new covering, wheels! At the end the plane came out maybe 10 oz heavier. A real pain to hand launch. My second Mustang, I assemble it in a weekend, and I didn’t start a thread with this one. Here the mods I made: (not really modifications, it’s more like: additional care to!) - Review all joins in wing and fuselage with thin CA (glue the ailerons, elevator, rudder first before putting CA everywhere). Revise the firewall with epoxy. - Use standard CA hinges, not these provide in kit - Use metal, ball bearings servos for ailerons and elevator. Hitec 225 will do the work without trouble. If I made a season with my cheap SL300 (plastic, no ball bearings, no high torque) the Hitec will do the work easily. - Reinforce with one or two layer of fiber glass and epoxy the cowling (bottom). Prevent crack on landing. Or install a skid to protect engine head, carb and cowling on landing. - Elevator, the one you will put the control horn, add a ply or fiber glass under the control horn. Cover a bigger surface to distribute the stress. With time, the control horn will come of with a part of elevator. This mod, I didn’t do it! That’s why there is no more Mustang!! For the CA (review all joins). I do this on all my models. Habitually I shrink the covering to remove all wrinkles, install all the control surface. Before gluing the wing half together, I drop CA inside and play with the wing to make it run everywhere. Same for the fuselage. The wing on the Mustang is well built and strong. I abuse them a lot and they never broke apart. Have fun...
< Message edited by nexxa -- 12/12/2007 1:49:47 PM >
