longdan
Joined: 10/18/2006 From: Auckland, NEW ZEALAND Status: offline
My Corsair ate dirt today I was flying it around quite nicely with a APC 9x6 prop, and as usual, it was fast. I thought I would see if I could slow it down by putting a MAS 10 x 4 prop on. I launched it, and, even with the engine screaming at full revs, it struggled to get up any flying speed. It sort of lurched around a bit, never more than 15-20 feet off the ground. and it was very unresponsive to any control inputs. It eventually dropped a wingtip and spiralled into the dirt. I managed to shut off the motor before it hit. I thought it was going to be matchwood, but the only damage was a broken prop (of course), broken wing mounting lug and cracked cowl. Not too bad I thought. Could have been much worse. I would have thought that the 10x4 would haul it up to flying speed quite easily. Not so. There was nothing wrong with the way the engine was running. In fact, it was probably revving a bit higher than with the 9x6. It just didn't want to fly. So once I get it fixed, I'll know not to use fine pitch props on it.
