hilleyja
WV, USA Status: offline
quote:
ORIGINAL: -pkh- quote:
ORIGINAL: hilleyja ...With an OS .25FX I already have an airplane that is quite fast. What would moving up to the OS .23SX or OS .40LA improve on? More speed??? ... You blasted the guy for considering a .40 LA he had lying around, claiming it was way too big and powerful for these .25 size planes... I was merely pointing out that it was in the same class (for weight and power output) as the .25 FX and .32 SX engines, which are both commonly used in .25 sized birds... I don't think I would use the words "blasted". You are correct that it is just MY humble opinion and IS based on personal experience. More of my humble opinion: The .25FX is definitely at the top end of power for this bird -- the .32SX is OVERKILL, only useful with throttle management. With the .25FX I have to be careful on full dynamic turns and full power straight flights -- the airplane wobbles at full speed (witnessed this with both the Corsair and the P-51) with just a little wind. With the .32SX, most of the time you will be flying at half throttle because full throttle will be too much. You are also right that the .32SX is a popular engine to max power a 25-size bird. Under most circumstances this is a good marriage, e.g., Tequila Sunrise. The .32SX is rated by OS to be stronger than the .40LA but, you can't dispell the grunt power that comes from cubes. The LA makes its power at a lower rpm range than the SX and as long as you stay with the larger props (10" or 11" you will find both engines very comparable and at the upper range of props, the LA maybe a little stronger. Of course, if you slip an 8" or 9" on the SX look out -- the LA will be left way behind. This puts the .40LA in the same category as the .32SX on this bird -- OVERKILL. Again, just my HUMBLE OPINION. And, BTW, if all I had hanging around my workshop was an OS .40LA, I would mount it on this airplane and enjoy the hell out of it. Thankfully, I have other alternatives (OS .15CV-A, Magnum .28XL, OS .25FX, GMS .32, and even a Webra Silverline .40, all of these engines are useable -- BUT, the OS .25FX is the best of them all, IMHO)
< Message edited by hilleyja -- 7/12/2005 9:35:26 PM >
_____________________________
Jim Hilley AMA #671825 RCCA# 758 Twist 150 Brotherhood #14
