FoamCrusher
CA, USA Status: offline
The Mega is a little larger in diameter than the Speed 400, so you have to do a little cutting. First you cut both rings through at the top so the motor will slide in. Then you may have to redrill or enlarge the motor mount holes on the plate so the holes in the motor line up. I had to do that on one of the two motor mounts I have used. Finally, after bolting up the motor, take some plastic strapping or carbon fiber tape and form a 1/2 circle on top of the motor mount rings across where you cut them. Glue these braces in place (it is easier to do with the motor in place) and it will be rock solid. Some people just run two releatively large zip ties around the motor and through the foam, but those look ugly IMO. When using the Mega, you will want to put some reenforcement under the motor mount to spread the load in the event of a crash. I have used bidirectional strapping tape on one plane and very thin birch ply from a craft store on another. Don't skimp. Make the reenforcement cover about a 4" square area under the mount, or the first hard crash where you don't get off the throttle quickly enough the motor will tear the back of the plane off. It can be repaired with Shoo Goo or the like, but it will not look great. FC
_____________________________
FoamCrusher
