RE: Pitts M12 26% plans available soon
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Pitts M12 26% plans available soon
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Pitts M12 26% plans available soon - 12/13/2005 7:00:26 PM
bbt
Status: offline
Olivier,
very strange that you post a reply right now ... I was just sending you a private Email. You should get it soon.
Probably Belgian telepathy
Cheers,
BB
(in reply to lolipop)
       Post #: 151
RE: Pitts M12 26% plans available soon - 12/13/2005 7:46:01 PM
rgunder
Status: offline
I believe that I have debugged the download script. If anyone else has problems with the download please let me know.
Thanks.
_____________________________
www.gundersonaerodesign.com
www.laseredgecutters.com
       Post #: 152
RE: Pitts M12 26% plans available soon - 12/13/2005 10:03:50 PM
agertlof
Status: offline
Could someone please tell me how to explain to the printer how to print the file so that I get the proper size of plans when they are done being plotted.
Mine that I asked about yesterday are not to scale and are about 10" short on both the wig and the fuse since they both measure 58.25"
Thank you
Art
(in reply to rgunder)
       Post #: 153
RE: Pitts M12 26% plans available soon - 12/13/2005 10:16:33 PM
rgunder
Status: offline
Art,
The paper size for each of the plans sheets is 40" x 128". The heavy border line is only 36" wide, however. So the printer needs to either print on paper that is at least 40" wide, or must center the drawing on a 36" sheet, and NOT scale to fit the sheet. The likely cause of the printing problem is that the printer is scaling the 40" drawing down to a 36" width. Hope that helps.
(in reply to agertlof)
       Post #: 154
RE: Pitts M12 26% plans available soon - 12/15/2005 4:21:46 PM
lolipop
Status: offline
hy ! that's the european modeller again
special thanks to the belgian desiner
plan are great great great ! (great ³ lol )
the printers/ploters may need a calibration sometimes
i saw it a few years ago on a old system printer./plotter
il consist in ; drawing a square from a well known size, print/plot this square and measure directly on the paper to correct plotter's settings in regards of the "well known" measure of the square.
this might help if the answer of rgunder was not a total solution but i believe he got the good solution
bye ;-)
       Post #: 155
RE: Pitts M12 26% plans available soon - 12/21/2005 6:18:46 AM
rgunder
Status: offline
Hello Everyone.
Time to spark a great debate (pun intended). I want to hear opinions on engines for the Pitts. Gas or Glow? O.S., MVVS, Zenoah, Fuji, Magnum, others...? 2-stroke or 4-stroke? Hmmm... can't wait to hear back on this.
Rich
       Post #: 156
RE: Pitts M12 26% plans available soon - 12/21/2005 11:59:32 AM
lolipop
Status: offline
well,
a friend told me a DA50
i dont have a DA but well a ZG62.
I think that on medium or large models engine's choice is very wide so advices too.
My ZG is a bit heavier but more and less the same power...? with a good exhaust...?
In regard of the final weight too... i began to modify a bit the model's parts (adding holes in ply wood parts)
gonna feed back here...
olivier
       Post #: 157
RE: Pitts M12 26% plans available soon - 12/21/2005 3:33:56 PM
ALW Phantom
Status: offline
I may be a bit bias about this, but Im thinking this is a great canidate for a conversion engine. Cost came up as a subject near the begining of the thread about getting the kit cut, so why not continue cutting some of the costs and do an engine converion instead of buying one. Now I will duck behind my imaginary shield and fend off all the shots headed my way ..... DUCKING ....
       Post #: 158
RE: Pitts M12 26% plans available soon - 12/21/2005 3:34:28 PM
rgunder
Status: offline
Olivier,
I like both of your engine selections. The DA50, beyond being a great engine just looks great. My concern with the DA50 is the prop size. To keep the prop diameter down, a 3-bladed prop would be required, and the DA50 will swing a 20" 3-blade! But again, great engine.
Has anyone had experience with the Fuji-Imvac BT-43?
< Message edited by rgunder -- 12/21/2005 3:35:36 PM >
       Post #: 159
RE: Pitts M12 26% plans available soon - 12/21/2005 8:35:31 PM
hum3767
Status: offline
As I have the first parts now on my workbench, I am currently thinking about the following two engines:
- a ZG62 is currently doing a fit check on my workbench together with the parts of the cowling; that might work; and I am flying this engine on an Extra 230 with the new SEP props (German manufacturer) of size: 3 blade 20"x10"
- I like the design of the Rotomotor 35VPi. Seems to be lightweight and powerful. Would probably fit into the cowling and weighs far less than a ZG62.
Now my problem: Is it possible with a light motor to reach the correct CG without additional trimming mass? Does somebody already have experience with this design, e.g. the prototype?
Greetings, Bernd
       Post #: 160
RE: Pitts M12 26% plans available soon - 1/2/2006 4:40:14 PM
flybug
Status: offline
hum3767, can we see some pictures of your build. Keep us posted.
My grandfather always said that living is like licking honey off a thorn. - Louis Adamic
(in reply to hum3767)
       Post #: 161
RE: Pitts M12 26% plans available soon - 1/18/2006 5:07:54 AM
rgunder
Status: offline
For those of you who did not get the email announcement, I would like to let you know about a price reduction on the Pitts short kit.
Here is the excerpt from the email that I sent out earlier:
"The first piece of news is that we have worked to reduce the cost of the Spirit of Pitts short kit, and we are passing the savings on to you! As of sending this email, the price for the short kit has been reduced by $30 to only $195!! And we have changed our shipping policy for domestic orders to save you even more. Now all domestic orders are shipped for a fixed $8.50 regardless of order size. That is an additional $4 savings from our former prices. Our international customers will still pay actual shipping costs.
We have also introduced some options for the Pitts, including wing tubes for only $54.50 for the full set, and 3/16 inch thick 6061 aluminum landing gear for only $31! Be sure to take advantage of these new lower prices and order your short kit and accessories today! Simply go to the Pitts product page at www.gundersonaerodesign.com/products/pitts.htm to place your order or use our new offline order form at www.gundersonaerodesign.com/orderform.pdf . For our international customers, please visit www.gundersonaerodesign.com/orderform.pdf to order."
Thanks.
< Message edited by rgunder -- 1/18/2006 5:10:19 AM >
(in reply to flybug)
       Post #: 162
RE: Pitts M12 26% plans available soon - 1/18/2006 1:30:19 PM
mikeperik
Status: offline
rgunder,
There are some problems with the 'Products' page. If I select any of the items under 'Short Kits', I get a 'Mal formed URL' error from my browser. It looks like you use '\' in the URL path instead of the non-evil '/'. Also, there is additional '\' on the end of the URL.
Mike
< Message edited by mikeperik -- 1/18/2006 1:31:50 PM >
       Post #: 163
RE: Pitts M12 26% plans available soon - 1/18/2006 2:49:00 PM
rgunder
Status: offline
Mike,
Thanks for the catch. That is what I get for testing the page in IE The page has been fixed and has been tested in Mozilla. Please let me know if you have any other problems.
(in reply to mikeperik)
       Post #: 164
RE: Pitts M12 26% plans available soon - 1/20/2006 12:24:28 AM
