samsrc
ON, CANADA Status: offline
Frank, It's nice to see you involved with this thread and I would love to hear any other suggestions you may have regarding the Yak. Sam from Toronto. quote:
ORIGINAL: Futabaman quote:
ORIGINAL: No Glo Any of you guys thinking about baffleing the cowl? I had a situation with a Sukhoi that required this to direct air flow. I know this cowl is wide open but I'm considering doing this on mine to aid cooling, opinions?? Photo shows the fix for the overheating engine on the SU-31...Walt I don't have baffles in the cowl on mine, and have had no issues with overheating. I've even flown multiple back to back flights in high 90's temp. and it didn't show any cooling related issues. One thing that I did find out was to move the engine forward, so that the prop is a couple of inches away from the front of the cowl. This will help thrust/airflow around the cowl and give you better performance. Frank
_____________________________
www.samsrc.com Team JR/Spektrum
