Johng
FL, USA Status: offline
Arrrrhg. I gotta get some stuff off my chect, then I'm unsubscribing. First: quote:
A more appropriate comment is, don't be so impressed by people's credentials. You can not be an engineer or scientist and accept statements just because someone has a PhD or is more senior. You will not be in a job long if you can't critically examine an argument. Professor's, PhD's, senior engineers, they all make mistakes. Even Einstien -- he seemed to be smart enough to figure out his mistakes and admit them. In these forums, especially, I couldn't agree more. Either you make a good argument or you don't. Whether you have a degree doesn't matter. Otherwise we all pull out our diplomas and there's nothing to discuss. As for downwash, it is a by-product of lift, not a cause of lift. That is what Ben was saying when talking about the pressure pulling the air down. As for the "infininte wing" argument, it is absolutely a valid prrof that lift is not caused by deflecting air, notwithstanding Lou's attempt to discount it. This can be demonsrated in a wind tunnel of any size, where there is not an "infinite mass" of air to work on. Yet still, there is lift (pressure change) where no downwash occurs. LouW also states that : quote:
For a lifting wing this net deflection is downward (the hand). It always happens and is always proportional to the lift being generated Which is true, but read carefully. Proportional means just that. It does not mean that there is a fixed relationship between lift and downwash among different wings. In order to turn a proportional relationship into an equation, you need a "K" multiplication factor. And in aerodynamics that is a measure of how efficient the wing is. It is a measure of how much lift a particular wing can make, per unit of downwash. This is why we make long glider wings for efficiency. They make more lift with less downwash. If downwash was a "cause" of lift, this wouldn't be possilble at all. It concerns me that some might read LouW's words and say - airplane A lifts more than airplane B, so it must deflect more air. And that just isn't true. Now here is a lttle tweak for people that can only think about wings as air deflectors. After 100 years of flight, billions of flights, airplanes now continuously in the air all around the world; If they are all deflecting air downwards, wouldn't the atmosphere be about 2 feet thick by now? The fact is, the air only deflects downwards if the streamline pictures you consider are clipped off prematurely, like the ones Siefring posted. In the short term, it deflects downwards. Then it rebounds to normal height. So where is the "negative lift" being applied to get the air back to normal height? (Not that I want an answer, I'm unsubscrbing. PM me if you want a serious discussion)
_____________________________
John
