Aerosplat
GA, USA Status: offline
krs Just as you are, I was uncomfortable with placing the regulator between the needle and carb. But at Bill's insistence, I mounted it that way. IT WORKS . Here is a little better explanation of my comments above: I said the needle became more sensitive and precise after installing the Cline. I tune all my engines with a tachometer. I peak the high speed, then back off about 150 rpm rich for flying. Before the Cline I was running the high speed needle about 2 turns out from closed. With the Cline I have it about 3/4 turns out. Before the Cline, peak was less defined. RPM would vary 50 -100 rpm without touching the needle. I would search for peak within about 4 clicks on the needle. With the Cline, rpm is stable within 50 rpm. Peak search is within two clicks. To back off rich without the Cline I was using 2 - 3 clicks. With the Cline 1 - 2 clicks will do it. Before the Cline, idle rpm would vary 75 - 150 rpm around the 1800 range. With the cline, idle is stable within 50 rpm at 1750. If anyone wants I can post some pictures of how I mounted the CLINE.
_____________________________
---- Robert ---- "If you put a big enough engine on it, even a brick will fly. But it will never 3-D"
