SkrapIron
Joined: 5/18/2004 From: Pittsburgh, PA, USA Status: offline
"I want to run my truck as fast as hell for like 30 minutes, can I do it?? The future seems to be now..." The long and the short answer is no. I haven't run a 3600 cell yet, but the BEST run time that I have gotten thus far is 18 min on a gp3300 matched pack. That is running the Feigao 8s. A larger ( the 6s) motor will drain the battery faster. You will be able to get your truck up around nitro speed with a brushless setup, but it won't run as long as you want. ( remember, most Nitro vehicles only carry anough fuel for 15-20 min anyway!) A sensor based esc/motor used a processor to monitor motor rpm and adjust to the input voltage of your battery. A sensorless esc/motor simply delivers all available voltage to the motor, regardless of the battery. You need to run high quality matched cells to take advantage of a sensorless motor. Advantages? They are supposed to achieve higher rpm potential than sensor based models, but will draw almost twice the current from the battery when running. I have both. I think the Novak SS is a better bashing motor. It's cheaper, and you can use less expensive cells. The Feigao runs like an ape on fire. I haven't done any serious off roading yet, but it seems capapble.
_____________________________
If I can't be a role model, at least I can be a warning!
