Ron Daniels
Joined: 11/5/2002 From: Kitchener, ON, CANADA Status: offline
I don't think that you need to be a war-monger to appreciate the WWII fighters. They were the first of the very high performance airplanes, and, as such had imperfections and varying approaches to the technical challenges of going such speeds. A formula for success had not yet been arrived at. As such, even within the same role (ie interceptor), they have a great deal of diversity of design, within the basic parameters of their type. In addition, as "mission" airplanes, they carried a wide range of armaments and equipment that is not needed on a civilian airplane. Sometimes this equipment was even retro-fitted to the airframe. This makes for a lot of neat little details for us to enjoy copying on our models. The huge array of paint schemes, the propensity for paint chipping and peeling, and the dirt that accumulated on these outdoor-stored, heavily used airplanes gives the opportunity for some more detailing that opens the door to making the model truly emulate a particular full-scale in a particular state of repair. Finally, the limited roll-rates and climb rates, as compared to contemporary fighters give a grace to their movement that they would not have, if they were capable of 400ยบ/second roll-rates. As many of our WWII models are capable of the latter rate (I know mine are set up for between 0.5 and 1 second/roll - for use in emergencies, and for control at low speeds), there is a challenge to flying them in a prototypical manner. It is not a challenge of reflexes, but rather a challenge of patience, timing and subtle movement. Interestingly, if you look at the roll data of WWII airplanes, it is usually quoted at a given stick force, and varied greatly with speed and altitude (as the stick force required varied). Our servos have enough power to give full movement at any speed. This is the basis of our ability to out-roll the full-scale at high speeds. Their aileron throw was dependent on speed, air density, and the upper body strength of the pilot! Hopefully, building and flying these airplanes will allow the remaining pilots of the full-scale airplanes to remember the power, grace and pleasure of peacefully flying the originals, without having to re-live the terror and risk of combat. Ron Daniels
_____________________________
Maker of RWDRC kits.
