RE: KMP New Spitfire Mk XIV    Gallery
Logged in as Guest
    Search This Thread
Printable Version
warbirds
Seller:  hi joe
Details:   $1,900.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KMP New Spitfire Mk XIV
Page: <<   < prev  42 43 44 45 46 47 48 [49] 50 51   next >   >>
Login
RE: KMP New Spitfire Mk XIV - 9/16/2009 8:42 PM
TwinTurboZ
Score: 100
Last Login: 6/14/2013
Status: offline
I knew I would regret not taking pictures of the building process. But what I will do is in the next couple of days I will draw out exactly what we did and explain how we did it.
Hide Signatures
(in reply to transatlanticflight)
       Post #: 1201
RE: KMP New Spitfire Mk XIV - 9/17/2009 3:29 AM
transatlanticflight
Score: 100
Last Login: 10/7/2012
Status: offline
Great...looking forward to it.
Hide Signatures
(in reply to TwinTurboZ)
       Post #: 1202
RE: KMP New Spitfire Mk XIV - 10/14/2009 7:27 AM
tevans55
Score: 123
Last Login: 6/18/2013
Status: offline
Well, I lost my Spitfire 10 days ago to a bird strike. I was flying at Warbirds Over Louisville at the end of the day. Fortunately the plane landed in a tall bush which kept everything in the fuselage intact...didn't even crack the canopy. I bought a new one from TBM and am surprised at all the operational changes especially in the tail. Mine has the two piece stab with the pull-pull set up for the elevator and the rudder. The tailwheel is now in a more scale location but I will be changing that tail wheel setup to a more scale looking gear. It looks like the tubes for the pull-pull are going to be in the way of my DB interior which also survived the crash. Not sure what to do about that yet. The detail on the fuse is much better now. I am afraid the plane is going to be heavier in the tail with a heavier tail gear and aluminum tube in the stab. I guess I'll find out in about a month.
_____________________________
Nothing difficult is ever easy.
Spitfire Brotherhood #44
Hide Signatures
       Post #: 1203
RE: KMP New Spitfire Mk XIV - 10/30/2009 4:54 AM
ghostrider168
Score: 105
Last Login: 4/7/2013
Status: offline
Hi, I just started building this plane and enjoying every minute of it. I am deciding on an engine for her and wondering how much difference there is between a Saito 150 and Saito 180. I know the size and weight are very close.
For people whom had installed the Saito 150, is it enough power for big loops? What is the estimated maximum speed with full throttle? I once in awhile do enjoy buzzing the runway full speed and don’t mind the extra power. However, if the Saito 150 is sufficient then I rather just use that.
If you have suggestion for another type of engine, I am all ears.
Gary
Hide Signatures
(in reply to tevans55)
       Post #: 1204
RE: KMP New Spitfire Mk XIV - 10/30/2009 6:18 AM
tevans55
Score: 123
Status: offline
Ghostrider-
The 150 will be plenty of speed to do large loops. The 180 may be the best choice since we have all had to add a significant amount of weight to the nose to make this plane balance. I added an SR 3500 mAh battery to my engine mount for added nose weight and I still had to add lead on the other side of the mount.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ghostrider168)
       Post #: 1205
RE: KMP New Spitfire Mk XIV - 10/30/2009 8:12 PM
Old Navy Flyer
Score: 105
Status: offline
Tevans55 -
Is the cowl on the new Spitfie similar in design and color to the original model? I am considering an engine change this winter and may need to repplace the new cowl.
John
"Sweet dreams and flying machines in pieces on the ground."
Hide Signatures
       Post #: 1206
RE: KMP New Spitfire Mk XIV - 10/30/2009 11:35 PM
TwinTurboZ
Score: 100
Status: offline
Yes the cowl and entire paint scheme is the same in all three versions. For some reason the spitfire pictured on the KMP website shows a different color scheme. I don't know if this was a prototype or just really bad lighting, but all versions have the exact same color scheme. The only difference is the invasion stripes on the later versions, and the small nose art.
Hide Signatures
(in reply to Old Navy Flyer)
       Post #: 1207
RE: KMP New Spitfire Mk XIV - 10/31/2009 12:15 AM
Old Navy Flyer
Score: 105
Status: offline
Thanks TwinTurboZ. I'll check into replacement cowl availability from KMP or TBM if the engine change requires it.
John
Hide Signatures
       Post #: 1208
RE: KMP New Spitfire Mk XIV - 10/31/2009 1:08 AM
TwinTurboZ
Score: 100
Status: offline
I also know vqwarbirds.com carries the ESM line of kits, and may have parts as well.
Hide Signatures
       Post #: 1209
RE: KMP New Spitfire Mk XIV - 11/3/2009 8:22 AM
tevans55
Score: 123
Status: offline
Old Navy Flyer-
Sorry for the delay in reply, but I wanted to get a picture for you. No the gray color is definately different between my two planes. It is brighter on my new plane and I don't remember where I read it but someone associated with ESM said there are variations in the paint from batch to batch. The good news is that "Brun Hilda" is much brighter on my second plane. The gray color is actually more different than it shows in this photo. You probably could match it easy enough at a paint store and then airbrush to match your gray.
Tim
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1210
RE: KMP New Spitfire Mk XIV - 11/3/2009 10:18 PM
Old Navy Flyer
Score: 105
Status: offline
Tim,
Thanks for the info and photos. If I make the engine change, I'll order a repacement cowl and will paint the gray as necessary. I hope you get your Spitty back in the air soon.
John
Hide Signatures
       Post #: 1211
RE: KMP New Spitfire Mk XIV - 11/12/2009 1:07 AM
tevans55
Score: 123
Status: offline
Well I have built a new ESM Spitfire and reused all of the internals from the last plane. To my surprise when it came time to balance the instructions indicate the CG is 120mm from the leading edge. The instructions from the ESM Spitfire last year indicate the CG is at 107mm. That is a big change considering the planes dimensions have not changed. Mine is a little nose heavy at 120mm (good) and a little tail heavy at 107mm (bad). Have any of you guys flown this plane at 120mm CG and what were your results?
Hide Signatures
       Post #: 1212
RE: KMP New Spitfire Mk XIV - 11/30/2009 11:59 PM
ghostrider168
Score: 105
Status: offline
How do you gentlemen mount the retract air tank? Photos would be greatly appreciated.
Hide Signatures
       Post #: 1213
RE: KMP New Spitfire Mk XIV - 12/1/2009 12:11 AM
George C
Score: 100
Last Login: 6/1/2013
Status: offline
I just used I piece of sponge to mount and then taped it with some duct tape inside the fuse. Nothing fancy but has worked just fine.
Hide Signatures
       Post #: 1214
RE: KMP New Spitfire Mk XIV - 12/1/2009 8:23 AM
nemesis4u
Score: 159
Last Login: 11/20/2012
Status: offline
STARTING ON MY "DEMO ESM SPITFIRE HERE SHORTLY"
http://www.vqwarbirds.com/aircraft.html
GOING WITH AN AEROVATE/RCGF 26cc rear exhaust Gas engine with a KELEO IN COWL MUFFLER made for NARROW TYPE COWLINGS such as the P-51B/D , SPITFIRES....
I will be using SIERRA PRECISION RETRACTS made specifically for this ESM SPITFIRE
http://www.vqwarbirds.com/products/access/SIERRASPITFIRE.html
POSTING this coming weekend...
-LOOKING FORWARD TO your input...
-TOMAS
VQ WARBIRDS
"KEEP 'EM FLYING"
R/C WARBIRDS / RC TANKS ENTHUSIAST
VQ WARBIRDS, KMP, & RCV
Hide Signatures
(in reply to George C)
       Post #: 1215
RE: KMP New Spitfire Mk XIV - 12/1/2009 10:03 PM
ghostrider168
Score: 105
Status: offline
Tomas,
That is great! I thought about using the RCGF 26cc engine on this plane. It would be prefect with the weight of a gasser. However, the thought of cutting up the cowling discourages me. I love to see how you and Keleo come up with the solution. If this works out, I’ll be the first inline to get the new engine and the muffler. Look forward for your post.
Ghostrider
Hide Signatures
(in reply to nemesis4u)
       Post #: 1216
RE: KMP New Spitfire Mk XIV - 12/2/2009 5:05 AM
tevans55
Score: 123
Status: offline
Ghostrider168-
This is my second ESM Spit so I decided to try something different. I attached the tank to the wing so that I don't have to deal with all the plumbing attachments. It also holds air a long time. I tested it at 100 psi and a week later it still had 82 psi. I also put the valve and servo on the wing.
Tomas-
Save yourself $40-$50 and put a set of Century Jet retracts on your Spit. These are the prototypes on mine and they have been working great.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by tevans55 -- 12/2/2009 5:30 AM >
Hide Signatures
       Post #: 1217
RE: KMP New Spitfire Mk XIV - 12/3/2009 4:55 AM
ghostrider168
Score: 105
Status: offline
Tevans55,
Your setup is awesome! I love how you did the air refill by the wheel well. Also, I noticed you have a rocker switch on top of a micro servo. Is this for an on board glow driver? How much ballast do you have to install up front in order to balance at CG? Again, love your setup and hope you don’t mind me stealing some of your ideas.
Ghostrider
Hide Signatures
       Post #: 1218
RE: KMP New Spitfire Mk XIV - 12/4/2009 10:46 PM
tevans55
Score: 123
Status: offline
Ghostrider-
Go ahead and steal away!! That's why we do this so that we can extract ideas and methods from each other. The switch on the servo is for the landing light that is attached to the port landing gear. It is a ram light that I molded a cone shaped housing on the rear of. I used JB Weld to make the cone shape on the back of the light. I put the fill valve and receiver switch by the starboard wheel so that I can reach eveything when I get down to fuel and start the engine. I can reach everything and it is somewhat hidden from view. On my last Spit I had the switch in the back of the wheel well and that worked great until the switch went bad and I had to change it out.
I don't know how much weight I have added to the nose but it is more than a pound. On one side of the engine mount I have an SR Batteries 3500 mAh NiCd and on the other side of the engine mount I kept adding lead until the plane went nose down a little at 110mm back from the leading edge.
< Message edited by tevans55 -- 1/28/2010 4:41 PM >
Hide Signatures
       Post #: 1219
RE: KMP New Spitfire Mk XIV - 12/8/2009 6:49 AM
TwinTurboZ
Score: 100
Status: offline
Does anybody have a set of the original retracts that came with this spitfire? I am looking for an extra set (preferably not used) of the 1st generation air up spring down retracts. I have attached a picture of what they look like. I know there were plenty of people that did not like them and switched them out. So I am guessing there may be a lot of them just sitting on a shelf. Shoot me an e-mail if you have an unused pair and would like to part with them.
Thank you in advance.
Adam
Click for fullsize
Hide Signatures
       Post #: 1220
RE: KMP New Spitfire Mk XIV - 12/9/2009 5:07 AM
Shihtzutan
Score: 100
Last Login: 6/6/2010
Status: offline
Shot you an email TwinTurboZ, it's as you said . . . didn't like them didn't use them.
Hide Signatures
       Post #: 1221
RE: KMP New Spitfire Mk XIV - 12/17/2009 1:03 AM
aviation421
Score: 100
Last Login: 6/12/2013
Status: offline
quote:
ORIGINAL: tevans55
I did see that CG change in the new ESM spitfire manual, I have not tried it yet.......
Has anyone tried it?
Anyone?
Anyone?
Please?
Hide Signatures
       Post #: 1222
RE: KMP New Spitfire Mk XIV - 12/18/2009 12:52 AM
tevans55
Score: 123
Status: offline
Aviation421-
Since noone has flown this plane at 120mm CG I have balanced mine at 110mm because I know it flies well at 107mm. The weather has been to cold to fly so I have not maidened at this CG. Maybe someone will fly it at 120mm before Spring and let us know!
Tim
Hide Signatures
(in reply to aviation421)
       Post #: 1223
RE: KMP New Spitfire Mk XIV - 1/6/2010 11:11 PM
vasek
Score: 147
Status: offline
Just recently I came across a Model Airplane News article about weathering the KMP Spit,
not bad see for yourself:
http://aerofe.dropcreative.net/files/dressupwarbird.pdf
in this article there's a mention of a previous MAN complete product evaluation of the KMP Spitfire... has anyone seen it? is it interesting?
Remember: Speed is life!
Hide Signatures
       Post #: 1224
RE: KMP New Spitfire Mk XIV - 1/27/2010 7:10 AM
TwinTurboZ
Score: 100
Status: offline
I am still looking for a set of the original air up spring down retracts. I posted a picture of them above in post #1220. If anyone has some and you want to get rid of them, please shoot me a PM and let me know how much you want for them.
Thanks in advance,
Adam
Hide Signatures
(in reply to vasek)
       Post #: 1225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.523RCU1
