Can't get "Vettre" scenery to work
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Can't get "Vettre" scenery to work
Page: [1] 2 3   next >   >>
Login
Can't get "Vettre" scenery to work - 2/19/2005 1:28:48 PM
jjordan-RCU
Status: offline
Hi all...
I downloaded the "vettre" scenery, unzipped the file into its folder in the "scenery" folder and changed the jpg files to bmp files. I also checked the "texture" file and it was set to 2048. I'm only getting a black screen and can barely make out the aircraft...I'm at a loss?????
Thanks in advance for help...
John
_____________________________
John Jordan
___________________
       Post #: 1
RE: Can't get "Vettre" scenery to work - 2/19/2005 5:28:16 PM
tukkus
Status: offline
did you download the patch?
This is a HOBBY so we don't need no steeenkin' reasons to use four stroke engines.
(in reply to jjordan-RCU)
       Post #: 2
RE: Can't get "Vettre" scenery to work - 2/19/2005 5:50:12 PM
4 stroken ron
Status: offline
I have the same problem as John, well almost, I just get a black screen and computer lock-up when I tried to open it. I finally deleted all the "vettre" files so I could use my AFP. What patch are you talking about? I downloaded the latest patch for AFP when I bought and installed it. Is there a patch for "vettre"? Also what is this thing about "texture"? I haven't made any changes there.
Ron
(in reply to tukkus)
       Post #: 3
RE: Can't get "Vettre" scenery to work - 2/19/2005 9:42:08 PM
tukkus
Status: offline
First off... do you have AFPD or AFP?
Right now don't worry about the texture...the texture has more to do about performance then the blackened screen
(in reply to 4 stroken ron)
       Post #: 4
RE: Can't get "Vettre" scenery to work - 2/19/2005 9:52:24 PM
4 stroken ron
Status: offline
AFP
Ron
       Post #: 5
RE: Can't get "Vettre" scenery to work - 2/20/2005 1:39:55 AM
tukkus
Status: offline
Ron do you know how to convert the .jpg files to .bmp files?
       Post #: 6
RE: Can't get "Vettre" scenery to work - 2/20/2005 1:47:36 AM
tukkus
Status: offline
also Ron.....if you have the Vettre folder in the scenery folder with all the jpg.'s converted to bmp.'s make sure you also have these 3 files in the scenery folder..
* vettre.geo
after i downloaded the file and opened it i saw those 3 files and the vettre folder...so make sure those 3 files go in the scenery folder and not the Vettre folder
       Post #: 7
RE: Can't get "Vettre" scenery to work - 2/20/2005 2:16:03 AM
4 stroken ron
Status: offline
OK, did all that and this time it WORKS!!!! I thought I had done all that before, but I guess I nad screwed something up.
Thanks for the help. I'm going flying.
Ron
       Post #: 8
RE: Can't get "Vettre" scenery to work - 2/20/2005 6:28:44 AM
NdFrSpeed
Status: offline
Will the vettre work in AFPD or is it strickly for AFP
Bob
       Post #: 9
RE: Can't get "Vettre" scenery to work - 2/20/2005 6:59:01 AM
4 stroken ron
Status: offline
I Believe it will work in (D) You can give it a try, and if it don't work, just delete it. Won't be no harm done.
Ron
(in reply to NdFrSpeed)
       Post #: 10
RE: Can't get "Vettre" scenery to work - 2/20/2005 3:43:40 PM
tukkus
Status: offline
yes, Vettre works in Deluxe
       Post #: 11
RE: Can't get "Vettre" scenery to work - 2/20/2005 9:19:58 PM
NdFrSpeed
Status: offline
Well someone give me a hand,,ive tried everything ,,keep getting black screen and black planes,,,converted Jpegs to bmp,,,still doesnt work,,made sure i had the corrects files in the scenery folder ,,still black screen,ive tried it 4 or 5 times same results each time,,
Bob
       Post #: 12
RE: Can't get "Vettre" scenery to work - 2/20/2005 9:51:11 PM
tukkus
Status: offline
....i don't uderstand why you are having problems but you must be doing something wrong....uninstall everything about Vettre and try again with these instructions...
Installation:
1. Extract this ZIP-file to the 'scenery'-folder of your AeroFly Professional installation.
There will be a new folder 'vettre' created which contains several pictures and files. In addition after extraction these three files should be located in the 'scenery'-folder:
* vettre.geo
If not, simply move them to there.
2. Then go into the 'vettre'-folder and convert the JPEGs into BMPs.
NOTE: do not rename the files. That does not work. You have to load them into a graphics viewer such as 'IrfanView' or 'ACDSee' and store them again in the BMP format.
       Post #: 13
RE: Can't get "Vettre" scenery to work - 2/20/2005 10:38:59 PM
NdFrSpeed
Status: offline
tukkus
Thats excactly what ive been doing,,,but for converting im useing photoshop instead,,maybe thats the problem,,,ive been doing it excactly like you just listed,,,but im useing photoshop to convert the jpegs to bmp,,,i wonder is something there is going wrong.
Bob
tukkus
I went and downloaded IrfanView and did excactly like you said,,,got the excat same results,,,AFPD works perfect of m system,,ive downloaded dozens of planes,,but when i download the scerney and change jpegs to bmp,this is what i get
Click to see fullsize image.
Click for fullsize
< Message edited by NdFrSpeed -- 2/20/2005 11:35:47 PM >
       Post #: 14
RE: Can't get "Vettre" scenery to work - 2/20/2005 11:44:10 PM
dafid
Status: offline
NdFrSpeed, tukkus
I have done this as you have and other people have, followed yours and their instructions many times, and i cant get it to work. all i can say is it works on some computor systems and not others why i dont know.
P.S. I get the same prob as NdFrSpeed and i convert jpg to bmp via irfanview.
"I Need some search lights" (vettre scenery) IN AFPD. Also ive tried GEO file to alter lighting ect,you can read it but page is locked cant alter.
Regards Dave.
Click for fullsize
Click for fullsize
